Hello all,
I have a QNAP TS-563.
While configuring IP access control, it seems I may have blocked ALL IPs inadvertently accessing the NAS. I did see a couple of lines on the access IP list (10.1.x.x.x.x or something ?)
Even if I plug in a LAN cable, make my IP 169.254.100.99/255.255.0.0 - I see the NAS on the QFINDER Pro app but cannot get access. I can ping it.
Any ideas ?
Mark
Cannot Access NAS - ALL IP Blocked
Re: Cannot Access NAS - ALL IP Blocked
a 3 second reset with the button on the back should fix it ..
then make sure you really need access control .. why are people inside your network attacking your NAS? .. and (if applicable) why are you exposing your nas to the wild wild web ?
Thanks. Trying now. I use it to access plex media files remotely. Not going to be doing that anymore so will block it from the web.
Will let you know.
Will let you know.
3 second reset worked thanks dolbyman.
