SSH - How to disable Console Management Menu?
Locked
DaftDevin
Post by DaftDevin »
Greetings!
I had a problem with my SSH keys and had to enable Telnet. I fixed the issue and turned Telnet back off. Now, whenever I ssh in, I get this screen and have to hit "Q" then "Y" to exit out. I don't see a way to turn this off. I'm assuming it's an artifact from enabling Telnet, as it didn't happen before. Does anyone know where I can turn this off and just go straight to a shell prompt? I looked around in both init.d and in my home drive and didn't see anything that looked like it could be it. Thoughts?
  |  Console Management - Main menu                                         |
  |  1: Show network settings                                               |
  |  2: System event logs                                                   |
  |  3: Reset to factory default (password required)                        |
  |  4: Activate/ deactivate a license                                      |
  |  5: App management                                                      |
  |  6: Reboot in Rescue mode (w/o configured disk)                         |
  |  7: Reboot in Maintenance Mode                                          |
  |  Q: Quit (return to normal shell environment)                           |
OneCD
Re: SSH - How to disable Console Management Menu?
Post by OneCD »
Hi and welcome to the forum. :)
viewtopic.php?f=142&t=157400
DaftDevin
Post by DaftDevin »
Oh man. I searched quite a bit and missed that. Thank you so much.
alexey_larionov
First post
Post by alexey_larionov »
Sorry, what is the answer?
I also have this problem, without any connection to TELNET though
dolbyman
Post by dolbyman »
the answer is in the link the OneCD posted.
Kevm256
First post
Post by Kevm256 »
This can be set in control panel now:
Control Panel > System > General Settings > Console Management > Enable Console Management
https://www.reddit.com/r/qnap/comments/ ... &context=3
cmsea
First post
Post by cmsea »
OneCD wrote: Tue Oct 20, 2020 4:26 am Hi and welcome to the forum. :)
ths
Locked
Return to “Miscellaneous”
