bcclient issue TS-212
I have TS-212 that runs great except when the bcclient process runs away. (Then its a brick)
I read another thread listing firmware downgrades to solve the issue, but that thread was 8 years old.
This unit has the latest firmware they released for the TS-212 Firmware: 4.3.3.1432
I am not sure what this process really does other than eat 70-93% of my CPU.
What calls bcclient?
and do I really need it?
The More I learn The Less I Know...
Re: bcclient issue TS-212
According to some people, this process is the QNAP program responsible for communicating with Qfinder.
You could try to kill it, if you don't need to use Qfinder it wouldn't hurt anything, but it will be respawned automatically.
crazy process: /sbin/bcclient
Thanks for the reply.
Seems like that would be a settable option.
F.Y.I.
I just added an hourly cron job to the admin crontab.
kill $(ps -ef | grep "bcclient" | grep -v grep | awk '{print $1}')
Now it should check every hour for the bcclient process and kill it if it finds it...
Yeah, alternatively you could use daemon_mgr to shut bcclient down permanently and prevent automatic respawns (which otherwise happen when you kill it with kill).
You only need to do this once after the NAS has booted up.
(replace 'stop' with 'start' if you need to bring it up again)
I confirmed that Qfinder is unable to locate the NAS when bcclient is not running.
# /sbin/daemon_mgr bcclient stop /sbin/bcclient
- OneCD
Or use the much shorter:
killall bcclient
chmod -x /sbin/bcclient
I have an TS-419pII with the same bcclient issue. I tried this daemon_mgr code. But I got a replay thatMousetick wrote: ↑Thu Dec 24, 2020 3:51 am Yeah, alternatively you could use daemon_mgr to shut bcclient down permanently and prevent automatic respawns (which otherwise happen when you kill it with kill).
You only need to do this once after the NAS has booted up.Code: Select all
/sbin/daemon_mgr
I guess the firmware on your NAS is too old and it doesn't have a daemon_mgr command?moserroger wrote: ↑Mon May 03, 2021 4:38 pm I have an TS-419pII with the same bcclient issue. I tried this daemon_mgr code. But I got a replay thatwasn't found. How to make it work?Code: Select all
/sbin/daemon_mgr
Try the command suggested by @OneCD two posts above:
killall bcclient
Firmware is: 4.3.3.1624
What about respawn?Mousetick wrote: ↑Mon May 03, 2021 10:40 pm Try the command suggested by @OneCD two posts above:Code: Select all
killall bcclient
Does it actually respawn?
To block execution:
# chmod -x /sbin/bcclient
# killall bcclient
# chmod +x /sbin/bcclient
I will try and see.
Update: it returned:
killall: /sbin/bcclient: no process killed
Will I have to kill it again after every restart?Mousetick wrote: ↑Tue May 04, 2021 1:10 am To block execution:To undo:Code: Select all
# chmod -x /sbin/bcclient # killall /sbin/bcclient
or simply restart NAS.Code: Select all
Can I add the code to autostart.sh?
Yes, unless you add it to autorun.sh.
Yes. Beware you will no longer be able to use QFinder to locate or connect to the NAS, in case it matters.Can I add the block execution to autostart.sh?
Worked! Thank you!Mousetick wrote: ↑Tue May 04, 2021 2:19 am Yes, my bad sorry. Typo error.
Try again:Code: Select all
# killall bcclient
