I've been receiving this message for about a week:
Level: Warning
[Antivirus] Failed to update virus definitions. Please try again later or update the definitions manually.
Updating manually from the GUI also fails so I have to download the cvd files and then import. Anyone else seeing this?
Clam AV will not update
Re: Clam AV will not update
I did search but apparently not very well. Thanks, I'll check the links.
Thanks, the manual udpate worked perfectly, appreciate you posting this.
