SSH Putty halt TS 451+
rjtt64
Post by rjtt64 »
Hi
I want to issue a halt command to my 451TS451+ . Firmware 4.5.2 1630
I connect via putty using the admin account. I can see the SSH connection in the log on the NAS
I type halt a the command prompt, nothing happens.
Other commands from the menu eg 1: show network settings all work
I can reboot the NAS down from qfinder
I can ssh into a different NAS, my 251 use halt and it shuts down just fine, from putty or from the command line.
Ive tried a heap of linux commands and none work
http://qnap support.net/advance-support-2/
(remove whitespace to use this URL)
The background is Im trying to get an APC Smart UPS to gracefully shut down a windows 2012 server from powerchute, so connect via usb to the server then issue a script via ssh to the nas
Any ideas gratefully received..
Reason: edited automangled link
dolbyman
Re: SSH Putty halt TS 451+
Post by dolbyman »
use a link shortener for links to that website..they get autobutchered
you can have the nas as ups master and use winNUT to shutdown your 2019 server ..as long long as both used networks are routable
rjtt64
Post by rjtt64 »
dolbyman wrote: Sat Apr 17, 2021 9:58 pm use a link shortener for links to that website..they get autobutchered
Thanks I'll have a look at that, and also for the url buterching tip! Still foxed as to how SSH halt doesnt work on one NAS but does on the other
dolbyman
Post by dolbyman »
I would always go top bottom
hypervisor shuts down clients ..not the other way around
otherwise your clients have no time to gracefully shut down or hibernate/snapshot
graemev
Know my way around
Post by graemev »
I tend to use poweroff
[~] # type halt
halt is /sbin/halt
[~] # ls -l /sbin/halt
lrwxrwxrwx 1 admin administrators 12 2021-04-21 17:00 /sbin/halt -> /bin/busybox*
[~] # power
power_clean       power_management  poweroff
[~] # type poweroff
poweroff is /sbin/poweroff
[~] # ls -l /sbin/poweroff
lrwxrwxrwx 1 admin administrators 12 2021-04-21 17:00 /sbin/poweroff -> /bin/busybox*
julyusito
Post by julyusito »
Same here, all commands link to busybox.
How can I fix it?
Return to “Miscellaneous”
