Hi all.
It's the first time I'm writing in this forum, despite I own a TS-453A since 4 years.
After the last firmware update released last April, 28th, the NAS is no more able to access to internet.
This means that he is no more able to update the IP address to access remotely, nor to have the possibility to update the apps.
Is someone having the same issue?
A possible solution could be to downgrade the firmware version?
Stefano
Internet connection no more working
Re: Internet connection no more working
Yes downgrade the FW, this is a common issue, you can read about it in the main FW thread
NAS:
TS-453Be
2-4 Gig QNAP ram sticks
1x12 TB Seagate Iron Wolf and 3x12 TB Seagate Exos
Mainly used as a Plex Server and Photo manager (QuMagie is actually pretty good)
WD 12 TB Elements for each hard drive - External HD BU to the NAS movie database and Photos
TS-453Be
Ok, thanks for your answer
How exactly are you accessing the NAS remotely?
Unless it's via VPN, you should rethink the strategy
This is what happens when you expose your NS to WAN
viewtopic.php?f=45&t=160849
For VPN I'd say OpvenVPN on capable router or dedicated appliance ... no, that does not cost any monthly fee's
Quick update:
I solved the issue changing the DNS settings and then changing them back again.
No downgrade of the firmware necessary.
Thanks for the help in any case
But please take dolbyman's advice or your NAS will likely get hacked and you will lose all your data to a ransomware or other attack.I solved the issue changing the DNS settings and then changing them back agai
Lot's of it about.
Yes,
I'm going to setup a VPN for the remote connection
