I'm having trouble logging into my unit with the web interface. I enter my credentials (which are the correct ones because I can SSH no problem into the unit) but on the browser the main UI never loads, and I get stuck on the blue screen with the "loading" image.
My unit is a TS-453Be with firmware 4.5.2.1594, how do I go about troubleshooting the issue?
Login screen hangs
Re: Login screen hangs
tried a different browser or clearing the cache ?
- Easy as a breeze
There was a known space issue on /tmp, with a documented firmware update/fix. If you do an 'df-h' check to see if /tmp is 100% full. If so, look for the largest file on /tmp and delete it. You should be able to access the web ui after doing that.
Model name: TS-653D
Firmware version: 4.5.3.1697 build 20210611
Volumes: EXT4, Encrypted volume
Previous: TS-651 dead by CPU bug
