Hi All,
I am looking into Qnap and have a quick question.
I am planning on encrypting a 6tb drive within it but read it requires manual mounting.
I intend to use the NAS to access the drive while im outside of the house so manually mounting each time would be impossible. Autoloading would also defeat the purpose of encryption.
Is it possible to remotely mount the encrypted volume NAS?
Perhaps loging in remotley and simply entering the password
Remotely Mounting
Re: Remotely Mounting
Establish a VPN(done on router or dedicated device) and unlock the drive via the webgui (vpn is then also used for remote usage)
NEVER expose your NAS to the open internet for remote access
Ah its that simple ok. I didnt realize you can do it via the webgui.
By the way
1) Does decrypting a 6tb drive take a long time?
The videos I have seen where on much smaller drives and seem to take a bit of time.
2) I assume I will have no problem streaming media (movies, music) on my encrypted drive via the webgui right? or do I need to use another app for this?
Thanks again.
By the way
Thanks again.
1) decrypting is on the fly....decrypting the whole drive would make no sense
2) any files on that drive would be unavailable until the drive/volume has been unlocked
1) Using a 932px decrypting a 2TB volume literally takes minutes. This is something that has amazed me since day one. Using Bitlocker for example it's a matter of entering the password and you're done. On the QNAP it's grinding away and only after that you're able to access the files
This has lead me to a "solution", always keep the volume decrypted, as I simply can't stand the delay.
I'm wondering if you are mixing up 'unlocking' - opening up access to an encrypted volume, with 'decrypting' - permanently converting the contents back to plaintext.1) Using a 932px decrypting a 2TB volume literally takes minutes. This is something that has amazed me since day one. Using Bitlocker for example it's a matter of entering the password and you're done. On the QNAP it's grinding away and only after that you're able to access the files
crap that is what i was worried about. I thought I could connect remotley enter the password for the encrypted drive and within seconds access and stream my files. If a 2TB takes minutes it will take ages for a 6TB. Can anyone else please confirm this? Defeats the purpose of buying a QNAP in this case.1) Using a 932px decrypting a 2TB volume literally takes minutes. This is something that has amazed me since day one. Using Bitlocker for example it's a matter of entering the password and you're done. On the QNAP it's grinding away and only after that you're able to access the files
doubt the unlock of a larger volume will take longer .. as (as stated before) the full volume will not be decrypted (obviously) but merely unlocked with on the fly decryption/encryption of accessed data
Sorry, yes I really meant unlocking.AlastairStevenson wrote: ↑Mon May 17, 2021 9:07 pm I'm wondering if you are mixing up 'unlocking' - opening up access to an encrypted volume, with 'decrypting' - permanently converting the contents back to plaintext.
That is, here, not simply entering password and being done, but rather:
Enter password, wait, see percentage of unlocking increase, wait, wait, disks grinding, percentage rising, more grinding etc. etc.
Volume is filled with images and videos. Can make video is people think this is impossible
