hello,
my ts 259 pro stop suddenly, only the fan work
no light on the front face ,
I no longer see him on the network
I removed the hard drive and it doesn't change anything
if you have any ideas I will listen to you
thanks
TS 259 pro suddenly stop
Re: TS 259 pro suddenly stop
It sound like a faulty motherboard.
thanks,
there is a solution ?
l must buy an other nas , no solution to repair it ?
thanks
thanks
Without any idea what could be defective, impossible to give any advice.
Getting an electronic expert to troubleshoot and repair, might be (probably) more expensive than a new NAS
