I have a QNAP TS-563 with AMD GX-420MC and 8GB Ram. I replaced all 5x4GB disks with 6GB WDRed one by one. The five rebuilds finish successful. After that I expand Storage Pool it take about 20 hours (the one rebuild took about 12-13 hours). After that something broke and NAS started working super slowly. I decided to restart- and the startup took about 1 hour. After login NAS start sync it took about 4 days. Then I had to run a file system check because the volume has unmounted.
Now I see everything, but again it works super slow. I download important files at 1-2MB/s.
I don't know how to proceed and where is the problem- software or hardware ...
I'm currently trying to back up the more important files (it will probably take me a month) and then if someone doesn't give better advice I will reset the device.
Please for an opinion, what is the reason for the problem and advice on how to proceed from now?
Sorry for my bad english...
QNAP TS-563 work too slow after expand pool
- OneCD
Re: QNAP TS-563 work too slow after expand pool
Hi and welcome to the forum.
Which model WD Red drives did you install? EFRX, EFAX or something else?
EFAX:
1. WD60EFAX-68SHWN0
2. WD60EFAX-68JH4N1
3. WD60EFAX-68JH4N1
4. WD60EFAX-68JH4N0
5. WD60EFAX-68JH4N0
I bought the discs 2 times in 3 pieces. For a long time (2-3 months) he worked with one 6TB Disk and 4 4TB disks. While I was changing the discs and during the rebuild, it also worked normally. I think everything collapsed when I released the expand...
1. WD60EFAX-68SHWN0
2. WD60EFAX-68JH4N1
3. WD60EFAX-68JH4N1
4. WD60EFAX-68JH4N0
5. WD60EFAX-68JH4N0
- OneCD
These model WD drives are unsuitable for RAID operations and are known to be problematic when used in NAS due to their use of SMR technology.
viewtopic.php?f=45&t=154346
You’ll need to replace these drives again with a different brand or model.
Thanks for the feedback.
I read about the SMR technology and as far as I understand the problem with it is the lower recording speed. In my case, the problem is almost zero read speed. I understand that use of this technology decrease performance problems, but I don't believe SMR is slowing down RAID that much
I utilize 2 efax drives in my TS-563, which is a mix of 4TB and 6TB drives. One of my efax (reds) drives is 4TB and the other is 6TB. I haven't had any issue; however, when I added my 6TB into the mix last week, I was in the process of performing a reset anyway. I know this post is old but, it's added info that might help in the future. I performed the reset and experienced no issues. However, I'm using RAID 10, if that means anything. The efax drives using SMR are a known issue for heavy users such as businesses and other related scenarios. It's specified on the product description to avoid these SMR drives for those scenarios. I am using them in my home office and don't fall under those scenarios so they work fine for my purposes. I had some old timing info on performing resets and I observed that it took about the same length of time for completion of the initialization of RAID 10; however, I did notice copying over the files before the RAID was finished formulating was slower. Knowing it was probably the SMR, I stopped copying files and waited for the RAID to complete. After that, I copied back my files and it operated as before. Hope this helps.
SMR issue mostly come up when
- the disks are mostly full or on long continuous writes when the 'CMR sectors' are exhausted (sequential)
- random write operations are done
In fact, my problems with the NAS continue. After about 2-3 months of agony I download the data from it (at a speed of 100-200kb/s). I reinstalled it, recreate RAID but problem exists after it.
I took it to the importer's service center (from Bulgaria it's Persy). After diagnosis, it was told that three of the discs "disappeared for a while" and this caused the problem. Apparently they have a problem with the electronics.
Now I will try to return them for warranty support ...
Thanks for support
Thanks for support
