Rogue Chia installation??
Somehow, someone has managed to install Chia mining on my QNAP!
Few days ago I noticed my QNAP was running high on resource. Checked process and found Chia, Chia_full_node and Chia_wallet running. Wasn't installed by me!
I've tracked down where the processes are running from, killed them, deleted the directory and contents. Within 15 minutes the processes are back again, folder structure is back. It is getting very frustrating and very worrying how this has happened behind a firewall, ports blocked, Malware scanner and AV running daily.
How can I get rid of Chia? The QNAP tutorials show containers, this seems to be running as Python. There must be auto-repair or install script stashed somewhere or a QNAP package update has been compromised?
Any suggestions gratefully received.
Re: Rogue Chia installation??
Probably a new attack...NAS exposed to the web?
There were cryptominer infections before..again ..exposed devices
Same for me.... noticed a new Python 3.9 install and chia running when examining top through Putty today. I'm not sure how it got there as i have all external incoming traffic disabled (due to login attempts).
Have a look at the 'chi.sh' file found in '/share/CACHEDEV1_data/' using VIM. You can see the installation process.
You will need to:
kill the processes associated with chia
rm the .chia folder and files 'chi.sh, and the 'chihld2.lck'
edit your crontab as there's an entry added
Hope this helps. I will monitoring over the next few days to see if it's reoccuring. Already run Malware scans and made sure apps/firware is updated.
You will need to:
were you infected by something before ? .. something must have put the crontab entries there
what means "all incoming traffic disabled" ? is upnp off in the router and no manual portforwards are set ?
Just found this chia on my NAS after noticing the disk was going mental for no reason.
What are QNAP doing about this?
Have the released something to clean this?
read my posts above.. QNAP has probably no idea about this yet.. so go ahead and report it via ticket
QNAP does not come here
thanks dolbyman, its been a while since I had to do anything on the NAS. what's the best way to connect and look for the file?
I tried to SSH on there and it took me to a page I didnt recognise with a menu.
New FW versions have a console management upon login via SSH, you can disable that via
ControlPanel>GeneralSettings>ConsoleManagement
That will lead you right to shell upon login
That's exactly what I found including the Python install. Uninstalled and it reinstalled itself again! Thanks for the tip on crontab I'll check that.flea001 wrote: ↑Fri Jun 11, 2021 1:25 am Same for me.... noticed a new Python 3.9 install and chia running when examining top through Putty today. I'm not sure how it got there as i have all external incoming traffic disabled (due to login attempts).
You will need to:
- Moogle Stiltzkin
you're not exactly telling us your qnap setup.
did you expose your nas online? do you update qts and your router regularly?
if you are simply exposing nas online, DON'T do that.
if you NEED remote use a vpn. also update regularly. Or you will definitely get hit.....
now you are just trying to tackle the symptoms of the real issue, which is exposing your nas online inappropriately (which is most likely). Or perhaps you did everything correctly (we don't know cauz you did not explain), but you still somehow got hit.
Either way report the issue to helpdesk for some assistance :X
https://service.qnap.com/
Chia miner will basically
1. use up your electricity (so say hello to next months pricey electricity bill)
2. all your hdds/ssds on the NAS are getting worned out to kingdom come o-O;
3. internet bandwidth used up by these hackers
NAS
Network
Resources
Network
Resources
To your questions
1) The crontab entry is completed by the chi.sh file (you can see it towards the end of the script)
2) I am not a Systems/Network engineer by any means, but I have only LAN IPs specified (i.e. 192.168.0.3 - 192.168.0.255) under ControlPanel->Security->Allow/Deny List.
Looking at the date/timestamp for the chi.sh file, the landing of that file and installation of Python 3.9.xx occuring during overnight updates.
no need to be a network engineer to check if you somehow "defeat" NAT by forwarding ports manually or via upnp
....so is upnp active on the router or ports manually forwarded?
Ok - sorry not trying to be cheeky, just wanted to indicate my level of expertise here
I don't have any ports manually forwarded, just upnp enabled.
then your nas probably forwarded ports itself via upnp...
make sure that is off and then kill your nas and start from scratch ...you have been compromised and should not trust the nas anymore
thanks for the advice dolbyman re:upnp.
I have turned off upnp on the router and shutdown myQNAPCloud. I don't use it (all interactions with the NAS are done through the lan).
I did notice a mysterious port (32440) entered in myQNAPCloud on the upnp table (labeled as 'NAS spare port 0).
