Hi, good afternoon.
Does anyone here know if there's a way to create a link to File Station on the login screen, like we have, for instance, with Photo Station?
Photo Station Shortcut on Login Screen
- OneCD
Re: Photo Station Shortcut on Login Screen
File Station is an embedded QTS authenticated-use application. So, it requires the user to login to QTS before it can be used. There'd be no-point offering a link to it on the QTS login screen, as the link would also need to point to a QTS login screen.
Yes, but Photo Station also requires authentication. And we can access File Station using <IP Adress>:8080/filestation.
- OneCD
It does, but it's a separate and distinct QPKG'd application - it's not embedded in QTS. Different login.
... Which also requires a login (using the QTS login details):
- Moogle Stiltzkin
to remove photostation icon for login screen, go appcenter and there is a drop down selection to choose not to display on login screen.
NAS
Network
Resources
Network
Resources
No, my question was how to put File Station on the login screen
- Moogle Stiltzkin
on qts, you can pop up a left side panel. from there u can DRAG drop onto the QTS main desktop screen.
or if you are refering to login screen app selection, then the process is same like i mentioned. if that option is not available for filestation, then they probly did not add the option for it
NAS
Network
Resources
Network
Resources
