How to access files on my TS-453D from Linux Station?
DigitalMan
Post by DigitalMan »
I used to have no problem getting to files on my NAS from the Linux Station app installed on the same NAS.
However, as of an update today, I can't get to any of the files I store on my TS-453D in Linux Station. This is a real problem as accessing my NAS files from Linux Station was essential to my workflow.
Any ideas?
DigitalMan
Re: How to access files on my TS-453D from Linux Station?
So, replying to my own question thanks to some awesome guidance on Reddit: it looks like QNAP removed the shortcut, but I can get to my data in Linux Station by adding network drives: https://www.qnap.com/en-us/how-to/tutor ... te-desktop
This totally works, unless anyone has another idea....?
iamsantino
Post by iamsantino »
I'm having the same problem since upgrading my TS-253A firmware to 4.5.3.1697, and upgrading Ubuntu Linux Station to v2.3.0.2396
There use to be a folder on the Ubuntu Linux Station desktop called NAS that showed all the shared folders on the NAS. After the upgrades I mentioned above the folder is gone.
I contacted support via the HelpDesk app but they reviewed my logs and said they could not find an error
iamsantino
Turns out they removed the NAS folder on purpose, it is on the release notes of the most recent Ubuntu Linux Station version (2.3.0.2396). I am not sure why, though.
https://www.qnap.com/en/app_releasenote ... =ubuntu-hd
QNAP links to the webpage you mentioned above as a means of accessing the shared folders on the NAS. I missed having the NAS folder on my Ubuntu Linux Station Desktop though so I found a way to recreate the NAS folder on the desktop:
Open terminal and run this command:
ln -s /.share/ ~/Desktop/NAS
The NAS folder that is created shows all the shared folders present on the NAS. It also unfortunately show a few additional, unnecessary folders but this is a small price to pay for my scripts to continue working as they did before the update.
I hope this works for you as well
oyvindo
Experience counts
Post by oyvindo »
That command didn't work for me.
I do get the icon and link, but clicking on it produces the following error message:
This link cannot be used because its target "/.share/" doesn't exist
So, what is wrong and how to fix it?
TajikNAS
Post by TajikNAS »
DigitalMan wrote: Wed Jun 16, 2021 12:11 am I used to have no problem getting to files on my NAS from the Linux Station app installed on the same NAS.
Any ideas?
Yep! Same here. I was confused and added folders as remote folders. After seeing your post and replies here, I am sure I didn't do anything wrong with my QNAP.
Thank you all for useful discussion and hints!
TajikNAS
Post by TajikNAS »
iamsantino wrote: Mon Jun 28, 2021 3:44 pm Turns out they removed the NAS folder on purpose, it is on the release notes of the most recent Ubuntu Linux Station version (2.3.0.2396). I am not sure why, though.
Your script worked perfectly as you described.
Thank you very much, iamsantino!
oyvindo
Experience counts
Post by oyvindo »
Is there a way to make this work also from Virtualizaiton Station using a Ubuntu image ?
Return to “Miscellaneous”
