TS 451+, Firmware: 4.5.4.1741
I installed Qmiix, then created a new, non-admin user for it to use. I logged into the NAS as the new user and opened Qmiix. The first step is to 'Bind your NAS Account to Qmiix Agent' but when I click 'Accept and Bind' it briefly shows a 'Loading' popup and just stays on the same screen. I can't do anything else in Qmiix until I bind the account. My new user has RW access to a shared folder that I plan to use with Qmiix.
Are there more permissions I need to grant to the user? Does Qmiix only work with admin users? Is this a bug?
Non-admin user can't bind account to Qmiix
Re: Non-admin user can't bind account to Qmiix
Never used that app, but does the user have application privileges assigned to it ? (user management the 4 squares in the action area)
If that does not help, it might be good to open a ticket, only QNAP can fix bugs (and they don't come here)
Qmiix doesn't appear on the Edit Application Privileges list, but the user has all the others.
Then it's probably time for a ticket
