Hi
I just update firmeware of my 2 NAS. (QNAP TS-431P3-2G)
At first the 2 update were ok.
The first NAS is now unreachable and seems to reboot all the time. I can see it via ping and then hear a BIP and then can't see it in ping everey 5 or 10 min.
Juste after the reboot i check the target LUN on it with a third computer and he was unreachable cause by password error on CHAP lun. It was working fine right before the update but i remove CHAP security and restart LUN service on computer. When i check back on the NAS he was down.
Then the NAS was unreachable and i heard it every 5-10min.
I try to force shutdown and restart but it s seems to be same
The second NAS is ok
What should I do?
Can't acces to qnap after update
Re: Can't acces to qnap after update
I get this with my TS-451 after every update and other seemingly random times teh device drop DHCP and will not refresh the lease, I havbe to push the reset and then go in as default user and reset DHCP. No idea why it does this. going to try setting a fixed address. I have assigned the device the same address permanently in the broadband route.
Any one have a definitive answer as to why it does this? I've had a TS-112 for 10 years and it never did taht once. I got the 451 to replace it and a BRIX box for download apps. Not sure I can get rid of it if the 451 is going to flake on DHCP every 3 or 4 days!!
I try to switch PSU and keep having the issue :
From 192.168.1.98 icmp_seq=267 Destination Host Unreachable
From 192.168.1.98 icmp_seq=268 Destination Host Unreachable
64 bytes from 192.168.1.85: icmp_seq=269 ttl=64 time=0.207 ms
64 bytes from 192.168.1.85: icmp_seq=270 ttl=64 time=0.114 ms
64 bytes from 192.168.1.85: icmp_seq=271 ttl=64 time=0.158 ms
64 bytes from 192.168.1.85: icmp_seq=272 ttl=64 time=0.158 ms
64 bytes from 192.168.1.85: icmp_seq=273 ttl=64 time=0.169 ms
64 bytes from 192.168.1.85: icmp_seq=274 ttl=64 time=0.160 ms
64 bytes from 192.168.1.85: icmp_seq=275 ttl=64 time=0.173 ms
64 bytes from 192.168.1.85: icmp_seq=276 ttl=64 time=0.162 ms
64 bytes from 192.168.1.85: icmp_seq=277 ttl=64 time=0.147 ms
64 bytes from 192.168.1.85: icmp_seq=278 ttl=64 time=0.161 ms
64 bytes from 192.168.1.85: icmp_seq=279 ttl=64 time=0.128 ms
64 bytes from 192.168.1.85: icmp_seq=280 ttl=64 time=0.172 ms
64 bytes from 192.168.1.85: icmp_seq=281 ttl=64 time=0.164 ms
64 bytes from 192.168.1.85: icmp_seq=282 ttl=64 time=0.173 ms
64 bytes from 192.168.1.85: icmp_seq=283 ttl=64 time=0.173 ms
64 bytes from 192.168.1.85: icmp_seq=284 ttl=64 time=0.163 ms
64 bytes from 192.168.1.85: icmp_seq=285 ttl=64 time=0.172 ms
64 bytes from 192.168.1.85: icmp_seq=286 ttl=64 time=0.141 ms
64 bytes from 192.168.1.85: icmp_seq=287 ttl=64 time=597 ms
From 192.168.1.98 icmp_seq=335 Destination Host Unreachable
From 192.168.1.98 icmp_seq=336 Destination Host Unreachable
Thank you for your advice i try it now.
For your information my NAS has static IP
Cool, I hit the rest on mine and several hours later its has come back up and its got the DHCP address back, so at least I can get to it.
I Know its not several hours really, but it feels like it when ur waiting for the thing to restart!
Be really keen to understand what I've done wrong for the DHCP to drop after a few days.
Sorry, i m not sure to understand your last message. I still have the problem. I m just trying your solution. I will tell you if it s ok.
THank you so much, My NAS is up
I Tried the mac adress as password but it doesn't work
Do you have an idea?
Second reset and it s ok thank you so much. I m going to sleep better !! professionel use of my qnas and big consequence each day it s off.
When i switch back to my orignal IP, the problem came back. I stop iscsi service on the compture and were able to restart nas propraly. Then I restarted my service (reboot) and qnas crash again.
So the problem to the NAS is this iscsi conection. I need to resolve this
