I know this seems like an unlikely situation but I have a TS-421 powered from a UPS and working with the normal USB signal for shutdown.
I also have a new (to me) TS-453Pro on the UPS power but, of course, not connected to that UPS via a USB for a SHUTDOWN command.
My question is "is there some way for the TS-421 to send a SHUTDOWN signal to the TS-453Pro"?
Will it require an app?
Command level coding?
Thanks,
Paul
Sending a SHUTDOWN cmd to TS-453Pro from TS-421
Re: Sending a SHUTDOWN cmd to TS-453Pro from TS-421
while you could .. why would you ?
setup the 421 as the UPS master and the 453Pro as the UPS slave, easy and explained in the manual
