QNAP Qfinder Pro 7.5.1.0716 cannot be installed on Windows Server 2012 R2
Re: QNAP Qfinder Pro 7.5.1.0716 cannot be installed on Windows Server 2012 R2
What happens when you try?
And dont't say "nothing"...a bit more info is needed here..
And remember...there other ways to find your NAS (DHCP Server) ..so why do you need it?
We have v7.5.0 installed and when the program finds its new version the downloaded setup says that the OS is not supported. Also it lists Windows 8 and Windows Server 2016 as minimum requiered OS, which is also weird, because Windows Server 2012 R2 is based on Windows 8.1.
Then open a ticket with QNAP .. nothing we can do about it(QNAP does not come here)
If you (for some reason) really need qfinder..install it on a client
Thanks. We will continue using the older version than.
