My box tells me I need a 2-Step to access my files.
I am the only user but don't see in admin where I can change this.
It says mu Username is Disabled.
How can I fix so I don't use 2-Step.
I don't have my phone on me all the time.
Don't need 2-Step - am only user- How to fix
- Easy as a breeze
QNAP TS-231P 2 x 4TB Group 1 RAID 1
QNAP TS-451A 3 x 2 TB Group 1 RAID 5
Re: Don't need 2-Step - am only user- How to fix
ignore the message... same with the default admin disable message ..just ignore
you should spend little time in the qnap webgui..so it should be a minor nuisance
also make sure that you do not expose your nas to wan (no matter if you do 2fa or not)
- Easy as a breeze
is there a way to officially kill those notifications? It is minor but it is a nuisance.
No official checkboxes that I know of
- Easy as a breeze
