Hi, i have NAS QNAP D4, firmware 5.0.0.1716
In my system i have notification to necessarily update of Qsync Central 4.4.0.0.
But it the same time i cant update this app because of warning "[App Center] Failed to install Qsync Central. It does not match the firmware version."
How i can fix it?
- Axell
Network Storages in use: QNap D4, Synogogy DS214SE
Re: Failed to install Qsync Central
5.0 is still in Beta .. even on those Russian devices .. so best to report any issues to QNAP via ticket
Same thing just happened to me. Was working fine until it decided it needed updated today.
- Axell
Thanks a lot! Try to create ticket. And then I'll write here.
Ticket #Q-202109-72457
Any update on this? I've got the same issue
- Axell
Still have the problem.... I am already want to rollback update if only QSync works!!!
- Axell
Hello everyone!
Today i have update on my QNAP D4. I installed it. The version of QTS is now 5.0.0.1785. It is new beta as i read on website preview.
So, Qsync has mandatory upgrade too in the App Shop and it's working now!!!!! Yeeeeee!
no need to censor private IP adresses
