NUT Configuration
NUT Configuration
I am trying to use the NUT tool with my qnap to have it shutdown when the UPS battery power gets low. I've already added the UPS to upsmon.conf. How do I get upsmon to run/start at start-up?
Re: NUT Configuration
Have you tried the network slave gui ? Unless the QNAP is the network master (also in the gui) .. but that is not quite clear from the question
Yes, the qnap device is set to be a network ups slave.
How can I ensure the connection is working?
pull the plug on your ups and check the ups status
I've set the IP address of the NUT UPS server. But the UPS information is not coming up.
you should be able to query ups status via ssh.....check
- moody_blue
- Easy as a breeze
The ups name in the NUT server must be qnapups
QNAP TS-253A 8G QTS 5.0.1.2145
Plex Media Server 1.29.0.6209
OpenHAB 3.4.0.M2
Unifi 7.2.92
Apache80 2454.8230
GLPI 10.0.3
OpenHAB 3.4.0.M2
Unifi 7.2.92
Apache80 2454.8230
GLPI 10.0.3
