Help...Can't find my qnap
Hi all
i was messing around with the virtual switches the other day and must have configured it wrong.
And now i can't see my Qnap on either of my networks...is there any way i can manually logged in to the qnap? via usb or with a moniter?
i've go the ts-x53d
cheers
i've go the ts-x53d
cheers
- Easy as a breeze
Re: Help...Can't find my qnap
Did you look on your desk?
Seriously though, that unit has an HDMI port right? Just connect a monitor and usb keyboard. If I were in your shoes though I'd start by looking on my DHCP server (probably on your router) to see what IP it was assigned.
I checked both routers and the Ip there were assigned before the change aren't in use or on the network at all.
But yea there is a hdmi that's a good shout... Hopefully that will work
3second reset should also put everything back to DHCP
- Easy as a breeze
is the word s h o e s filtered? why???Thisisnotmyname wrote: ↑Wed Sep 22, 2021 7:04 pm Did you look on your desk?
Seriously though, that unit has an HDMI port right? Just connect a monitor and usb keyboard. If I were in your ** though I'd start by looking on my DHCP server (probably on your router) to see what IP it was assigned.
There was a lot of fake online store spam years ago .. so the QNAP forum Admin (Chinese native) thought it would be a brilliant idea to add these to the bad word filters (but only in some forums)
- OneCD
ha .. so I guess the word censorship did not do much to fix that issue
sho*e
Watc*h
and some other ones are in the word list
no to forget the transformation rule that applies when links to q*napsupport.*net are posted
sho*e
Watc*h
- OneCD
I create a support ticket in June of last year (#Q-202006-33342) to ask that QNAP review the auto-censor list. The ticket is still open.
- Easy as a breeze
- OneCD
