Hello, I had this error: Avertissement 2022-11-23 01:09:52 --- --- localhost Network & Virtual Switch Infrastructure [Network & Virtual Switch] Failed to connect to the internet. System default gateway "Virtual Switch 4" and all adapters failed to connect to the internet after checking NCSI.
Now, NAS was unreachable, I got CONNECTION REFUSED on Vivaldi, QFinder won't find the NAS, ssh was not working nor Windows Explorer. Weird thing is I had response from cmd ping
I had to shutdown the NAS by pressing power and then it's working. Problem is the NAS is not shutting down properly so I have to verify all disks.
I checked this: https://i.imgur.com/R7EXsLT.png
Will it solve the problem ?
Spec: TS-453D with 2x2To
Thanks for help
QNAP unreacheable
Re: QNAP unreacheable
Always make sure you switch your UI to English when posting screenshots in an English forum
Not sure I understood that reply, just switch the language and repost the screenshot of whatever setting that is
