Hi..
I would like to know if there is an app or docker for rar.
I need RAR to run on my Qnap nas.
Thanks.
install RAR on Qnap nas
Reason: fixed title
Reason: fixed title
Re: install RAR on snap nas
What is a snap NAS?
Docker container could be available, but depends on what (unknown) CPU architecture your (unknown) NAS uses
Sorry. typo. QNAP Nas..... I did a search in container.... but only unrar shows up.
Re: install RAR on Qnap nas
I fixed your title
NAS model is still unknown
Here is one for x64/amd64
https://hub.docker.com/r/klutchell/rar/tags
Installs fine and waits for anything to do
Wow... great. THANKS....
Just one last Q... A program what I run in another container needs car to do some stuff. I need to point to the RAR folder in that app.
How do point it to the klutchell/rar container?
I think you can use
and then parse whatever folders and commands it needs (see the documentation of the docker container in shell)
I have never used docker containers that way, but I am pretty sure it should work
docker run -v
This is going over my head..... lol...
Dont know what that does.
Your NAS unit/firmware are still unknown
I just checked and I have unrar native installed on my machine (TS-853BU) 5.0.0.2277
# unrar t test1.rar
UNRAR 5.30 beta 3 freeware Copyright (c) 1993-2015 Alexander Roshal
Testing archive test1.rar
Testing test-api.js OK
Testing test-api.js.map OK
Testing test-api.ts OK
Testing index.html OK
All OK
I have. TS-453A... (older one)
I need RAR... not UNRAR. And if that is available, I need an other program so point to the RAR path... the folder where the RAR executable is located.
I hope u understand what I mean.
ok .. all information not given prior.
I would try the docker and play around with it
