obviously, someone tried to login to my SSH with 100+ failed attempts.
I've changed my default port and not using qnapcloud, and only the official application is installed
The scan didn't pick up any virus.
What's wrong with my machine?
Persistant login failures from 127.0.0.1
Re: Persistant login failures from 127.0.0.1
It's not the same, the user name keeps changing, not admin, so it's not a qnap app.dolbyman wrote: ↑Tue Mar 28, 2023 2:49 am Please use the forum search
viewtopic.php?t=169092&p=836100
please take a good look at the picture
see further down in the linked thread
https://www.qnap.com/en/how-to/faq/arti ... 1-via-http
Then update or disable SC
No, I haven't install SC, thanksdolbyman wrote: ↑Tue Mar 28, 2023 3:26 am see further down in the linked thread
Then best to open a ticket, weird that the username changes incrementally in your output wa/wb/wc/wd/we....
Question is .. what port did you change if the NAS is not exposed online ?
I changed the SSH port, however, "he" still figured it out.
So I think it's very weird...
