List of QNAP basic commands
hi
I'm looking for a list of QNAP basic commands, using via putty, for example restart ssh, samba, force shutdown etc.
- pwilson
Re: QNAP basic commands
Restart SSH:ccc wrote:hi
I'm looking for all QNAP basic commands via putty, for example restart ssh, samba, force shutdown etc.
/etc/rcS.d/S85login restart
/etc/rcS.d/S62smb restart
Patrick M. Wilson
Victoria, BC Canada
Thx, but I need all other commands as well, like on competition product Synology:
Basic commands to get around the Synology Box using the CLI
- rtruell
ccc wrote:hi I'm looking for all QNAP basic commands via putty, for example restart ssh, samba, force shutdown etc.
There are really no "QNAP basic commands". For that matter, there are really no "Synology basic commands" either. The Synology and QNAP boxes run (slightly different) versions of the Linux operating system; thus, most of the CLI commands that work on any Linux distro will also work on boxes from either QNAP or Synology. The list of "Synology" commands in the link you provided will, for the most part, work as-is on QNAP boxes. Ones that *won't* work as they are in that list are the commands in the "Restart Services" section; on the QNAP boxes, the service startup scripts are in the '/etc/rcS.d' directory (as Patrick pointed out), they have different sequence numbers and, in some cases, the programs aren't available (Apache, for instance).ccc wrote:Thx, but I need all other commands as wll, like on Synology:
Rick Truell
Edmonton, Alberta, Canada
NAS: TS-119P II, F/W: QTS 4.0.2 Build 20130726, Drive: WD 2TB RE4 || TS-419P II, F/W: QTS 4.1.1 Build 20141003, Drives: 4 * WD 3TB Red
Computers: || Mac mini running Yosemite (10.10.4)
PVR: i5 & Core 2 Duo, both running MythBuntu. Tuners: Hauppauge PVR-150, 2 * HVR-1600 and 2 * HVR-2250
I know already that QNAP and Synology have different commands.
If I can use Synology commands on QNAP, I will not ask in this forum.
I was searching just for a list with basic commands for Qnap boxes.
- schumaku
I don't think so ... Large majority listed there is not Synology - it's plain standard basic embedded (Busybox based) Linux - except what holds the Syno specific path prefix there.ccc wrote:If I can use Synology commands on QNAP, I will not ask in this forum.
To achieve what exactly?ccc wrote:I was searching just for a list with basic commands for Qnap boxes.
Re: List of QNAP basic commands
Let's revive this old thread, because there *are* (many) Qnap-specific commands, and a list would be nice.
Currently, I'm trying to find a command which would show the Qnap firmware version. While searching, I found this:
Also, most Samba commands are not in the PATH, but in /usr/local/samba/bin/ or /usr/local/samba/sbin/
But I still find no way to show the QOS firmware version and build number.
[~] # /sbin/getsysinfo
cputmp : get CPU temperature
systmp : get system temperature
sysfan [fan no] : get system fan speed
sysfannum : get total system fan number
hdnum : get total system SATA disk number
hdtmp [disk no] : get SATA disk temperature
hdstatus [disk no] : get SATA disk status
hdmodel [disk no] : get SATA disk model
hdcapacity [disk no] : get SATA disk capacity
hdsmart [disk no] : get SATA disk SMART summary
model : get system model name
sysvolnum : get system volume number
vol_desc [volume no] : get volume description
vol_fs [volume no] : get volume file system
vol_totalsize [volume no] : get volume total size
vol_freesize [volume no] : get volume free size
vol_status [volume no] : get volume status
[~] # /sbin/getsysinfo model
TS-1079 Pro
[~] # /sbin/get_hwver
1.0
[~] # /sbin/get_hwsn
Q123I10...
[~] # uname -a
Linux kinkellmain 3.10.20-al-2.5.3_sa #2 SMP Fri Jan 1 06:29:56 CST 2016 armv7l unknown
getcfg system versionBut I still find no way to show the QOS firmware version and build number.
getcfg system 'Build Number'
(from pwilsons script)
Thanks. That's it. In the meantime, I had found the info in /etc/config/uLinux.conf, but extracting it with sed is horrible.
I had tried getcfg --help, but that is not very informative. Is there a documentation on getcfg somewhere?
- Toxic17
the late great Patrick Wilson, had a better script to grab everything you needed.AlbertH wrote:Let's revive this old thread, because there *are* (many) Qnap-specific commands, and a list would be nice.
#!/bin/sh
rm -f /tmp/nasreport
touch /tmp/nasreport
chmod +x /tmp/nasreport
cat <<EOF >>/tmp/nasreport
#!/bin/sh
# NAS Report by Patrick Wilson
# see: http://forum.qnap.com/viewtopic.php?f=185&t=82260#p366188
echo "[code]*********************"
echo "** QNAP NAS Report **"
echo "*********************"
echo " "
echo "NAS Model: \$(getsysinfo model)"
echo "Firmware: \$(getcfg system version) Build \$(getcfg system 'Build Number')"
echo "System Name: \$(/bin/hostname)"
echo "Workgroup: \$(getcfg system workgroup)"
echo "Base Directory: \$(dirname \$(getcfg -f /etc/config/smb.conf Public path))"
echo "NAS IP address: \$(ifconfig \$(getcfg network 'Default GW Device') | grep addr: | awk '{ print \$2 }' | cut -d: -f2)"
echo " "
echo "Default Gateway Device: \$(getcfg network 'Default GW Device')"
echo " "
ifconfig \$(getcfg network 'Default GW Device') | grep -v HWaddr
echo " "
echo -n "DNS Nameserver(s):"
cat /etc/resolv.conf | grep nameserver | cut -d' ' -f2
echo " "
echo " "
echo "HDD Information:"
echo " "
alpha='abcdefghijklmnopqrstuvwxyz'
drives=\$(getcfg Storage 'Disk Drive Number')
for ((i=1;i<=drives;++i)) ; do
echo -n "HDD\$i -"
if [ ! -b /dev/sd\${alpha:\$i-1:1} ] ; then
echo "Drive absent"
else
hdparm -i /dev/sd\${alpha:\$i-1:1} | grep "Model"
echo " "
parted /dev/sd\${alpha:\$i-1:1} print
echo " "
/sbin/get_hd_smartinfo -d \$i
echo " "
fi
done
echo "Volume Status"
echo " "
mdadm -D /dev/md0 /dev/md1 2>/dev/null
echo " "
cat /proc/mdstat
echo " "
echo "Disk Space:"
echo " "
df -h | grep -v qpkg
echo " "
echo "Mount Status:"
echo " "
mount | grep -v qpkg
echo " "
#echo "Contents of \$(dirname \$(getcfg -f /etc/config/smb.conf Public path)):"
#echo " "
#ls -lF \$(dirname \$(getcfg -f /etc/config/smb.conf Public path))/
echo " "
echo "Windows Shares:"
echo " "
for i in \$(grep \] /etc/config/smb.conf | sed 's/^\[//g' | sed 's/\]//g' | grep -v global) ;do
echo -n "\$i:"
testparm -s -l --section-name="\$i" --parameter-name=path 2>/dev/null
done
#echo " "
#echo "QNAP Media Scanner / Transcoder processes running: "
#echo " "
#/bin/ps | grep medialibrary | grep -v grep
#echo " "
#echo -n "MediaLibrary Configuration file: "
#ls -alF /etc/config/medialibrary.conf
#echo " "
#echo "/etc/config/medialibrary.conf:"
#cat /etc/config/medialibrary.conf
echo " "
echo "iTunes Music Store: \$(getcfg -f /etc/config/mt-daapd.conf general mp3_dir)"
echo " "
echo "Memory Information:"
echo " "
free | grep -v cache:
echo " "
echo "NASReport completed on \$(date +'%Y-%m-%d %T') (\$0)
echo " "
EOF
sleep 2
clear
/tmp/nasreport
#done[/code]
Just Select all and paste into an SSH window.
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
You can also do the following in your shell
show the commands provided by BusyBox
show the other utilities which are not symlinks to BusyBox
show the "secure" bin commands
busybox
ls -al /mnt/HDA_ROOT/usr/bin |grep -v busybox
ls -al /mnt/HDA_ROOT/usr/sbin
NOT on a 431+. It should, but it only reboots and starts a resynch for hours.pwilson wrote:Restart SSH:ccc wrote:hi
I'm looking for all QNAP basic commands via putty, for example restart ssh, samba, force shutdown etc.Restart Samba:Code: Select all
Do shutdown through the WebUI.Code: Select all
431+, 6TB HGST drives, RAID 10, UPS and USB 3 external on two ports, dual ALB 1Gb network. QTS 4.3Beta
@wise-asses
What's so difficult just to post basic linux commands to help?
http://www.qnap-singapore.com/guides/qn ... -commands/
@fps_user : thanks for the link, but this only lists a few generic linux/unix commands, which are widely documented everywhere. The question was about Qnap-specific commands for which there seems to be no serious documentation anywhere, only bits and pieces here and there.
