Endless Disk Activity QTS 4.4.1 [SOLVED]
Discussion about hard drive spin down (standby) feature of NAS.
kicritos
Post by kicritos »
Using QNap QTS 4.4.1
After installing docker-station i have noticed that my harddisks started to be continuosly active EVER :( . Disk activity never ends so i decided to investigate whats going on.
following the instrucions from qnap wiki i have downloaded and run script from:
https://wiki.qnap.com/wiki/Find_out_whi ... m_spindown
Running script
We have to look for lines like
<7>[52475.727464] setcfg(9191): dirtied inode 7041 (CACHEDEV1_DATA.log) on md9
This means that process setcfg with pid 9191 have modified file CACHEDEV1_DATA.log on device md9
<7>[52482.016599] jbd2/md9-8(2518): WRITE block 616080 on unknown-block(9,9) (8 sectors)
Like md9 device is updated, its journal have been written
<7>[52482.027584] md9_raid1(2505): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
Finally, datablock is written to device md9, preventing disk to sleep.
Analysing output i have found that docker.log is being updated several times a minute.
<7>[52473.727438] python2(9191): dirtied inode 7046 (docker.log) on md9
With these logs.
time="2020-03-16T01:50:18.680573251+01:00" level=debug msg="Calling GET /v1.32/containers/json"
I 've noticed that Container-Station runs docker in debug mode :shock: , so i have edited file
/share/CACHEDEV1_DATA/.qpkg/container-station/script/run-docker.sh
Wich is script used by container-station to run docker, look for Debug enabled options
And comment Debug option.
Changed
DOCKER_OPTS="$DOCKER_OPTS -D"
to
#DOCKER_OPTS="$DOCKER_OPTS -D"
container station uses redis too, and redis.log is updated frequently, so i have lowered log level from redis in order to reduce disk accesses
To do so, i have edited
/share/CACHEDEV1_DATA/.qpkg/container-station/etc/redis.conf
and change:
loglevel notify
to
loglevel warning
After that i realised that smbstatus is being called every few seconds. As i don't use samba, and i don't know how to stop smb callings, i have renamed smbstatus binary
/mnt/ext/opt/samba/bin/smbstatus
to
/mnt/ext/opt/samba/bin/smbstatus_hidden
And now disc activity have stopped and my disks have a pleasant sleep :DD :DD .
QTS 4.4.1
HS-553DX
graemev
Know my way around
Re: Endless Disk Activity QTS 4.4.1 [SOLVED]
Post by graemev »
Taking a lead from your smbstatus(1), I note in /etc/config/smb.conf the lines:
lock directory = /share/CACHEDEV1_DATA/.samba/lock
state directory = /share/CACHEDEV1_DATA/.samba/state
cache directory = /share/CACHEDEV1_DATA/.samba/cache
lock directory (G)
This option specifies the directory where lock files will be placed. The lock files are used to implement the max connections option.
Note: This option can not be set inside registry configurations.
Default: lock directory = ${prefix}/var/locks
Example: lock directory = /var/run/samba/locks
When I did:
find /share/CACHEDEV1_DATA -xdev -mmin -20 > /tmp/touched
It shows:
/share/CACHEDEV1_DATA/Public/Backups/ingrid-mac/private/var/db/sudo/sebastian
/share/CACHEDEV1_DATA/.qpkg/CodexPack/tmp
/share/CACHEDEV1_DATA/.qpkg/MediaSignPlayer/CodexPackExt/tmp
/share/CACHEDEV1_DATA/.samba/lock/msg.lock
/share/CACHEDEV1_DATA/.samba/lock/smbXsrv_session_global.tdb
/share/CACHEDEV1_DATA/.samba/lock/smbXsrv_tcon_global.tdb
/share/CACHEDEV1_DATA/.qulog/local_access.MYI
/share/CACHEDEV1_DATA/.qulog/local_access.MYD
So , an obvious question; why on earth are they storing the lock files on the raid disk, the mt or even RAMdisk would surely be a much better place?
ABTW, pretty sure nobody is accessing that "backup" file , it must be a stray windowbox making probes of some sort.
Mousetick
Experience counts
Post by Mousetick »
graemev wrote: Thu Apr 22, 2021 4:26 am So , an obvious question; why on earth are they storing the lock files on the raid disk, the mt or even RAMdisk would surely be a much better place?
They are not stored on the RAID disks, they are stored on a tmpfs (RAM) filesystem mounted at <System-Volume-Path>/.samba/lock/msg.lock. So this directory and its contents does not involve any disk access at all - by design.
To see for yourself, you can use this command while Samba is running:
# mount
Or you can study the contents of the script /etc/init.d/smb.sh which sets up the tmpfs filesystems for Samba.
graemev
Know my way around
Post by graemev »
Well <System-Volume-Path>/.samba/lock/msg.lock is indeed tmpfs:
[~] # df -h /share/CACHEDEV1_DATA/.samba/lock/msg.lock
Filesystem Size Used Available Use% Mounted on
tmpfs 48.0M 60.0K 47.9M 0% /share/CACHEDEV1_DATA/.samba/lock/msg.lock
But the other two files (from the find(1) ) are not
[~] # df -h /share/CACHEDEV1_DATA/.samba/lock/smbXsrv_session_global.tdb
/dev/mapper/cachedev1
5.0T 3.1T 1.8T 63% /share/CACHEDEV1_DATA
[~] # df -h /share/CACHEDEV1_DATA/.samba/lock/smbXsrv_tcon_global.tdb
Nor are the other two locations mentioned in smb.conf
[~] # df -h /share/CACHEDEV1_DATA/.samba/state
[~] # df -h /share/CACHEDEV1_DATA/.samba/cache/
mrw13
Post by mrw13 »
graemev wrote: Sat Apr 24, 2021 3:12 am Well <System-Volume-Path>/.samba/lock/msg.lock is indeed tmpfs:
I have this too but need SMB - is it possible to use a symbolic link to divert the files to the ramdisk? Or better to edit the conf files? I am never sure which files get overwritten on reboot etc.
If only qnap did a better job of this stuff eh.
Return to “HDD Spin Down (HDD Standby)”
