I set it to go into standby after 10mins, but it's still grinding away loudly an hour later.
One suggestion I've seen is that the drives themselves run a scan when they're idle, but I've had one of the same drives in my PC for a year and it spins down as expected.
Looking at the FAQ, it lists Microsoft Networking as one of the things that can stop it from going into standby. If that's the case, how do people use it as a NAS with Windows and get it to spin down the drives?
Here's some of the output from blkdevMonitor (the full thing was too long for the maximum characters, and it just looked like more of the same to me):
============= 0/100 test, Mon Nov 23 16:39:05 GMT 2020 ===============
<7>[238689.841392] md9_raid1(616): WRITE block 1060232 on sda1 (1 sectors)
<7>[238689.841410] md9_raid1(616): WRITE block 1060232 on sdd1 (1 sectors)
<7>[238689.841423] md9_raid1(616): WRITE block 1060232 on sdc1 (1 sectors)
============= 1/100 test, Mon Nov 23 16:39:14 GMT 2020 ===============
<<7>[238700.898343] jbd2/md9-8(628): WRITE block 592168 on md9 (16 sectors)
<7>[238700.898377] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238700.898406] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238700.898425] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238700.898442] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 2/100 test, Mon Nov 23 16:39:25 GMT 2020 ===============
<7>[238704.848338] kworker/u8:0(9309): WRITE block 8 on md9 (8 sectors)
<7>[238704.848373] md9_raid1(616): WRITE block 1060216 on sda1 <7>[2<7>[<
============= 3/100 test, Mon Nov 23 16:39:30 GMT 2020 ===============
<<<<<7>[238712.198332] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238712.198362] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238712.198378] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238712.198394] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
<7><<7>[238714.868352] kworker/u8:0(9309): WRITE block 592192 on md9 (8 sectors)
<7>[238714.868389] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238714.868418] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238714.868436] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238714.868453] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 4/100 test, Mon Nov 23 16:39:39 GMT 2020 ===============
<<<<7>[238725.188577] rsyslogd(17437): dirtied inode 765 (kmsg) on md9
<7>[238725.188598] rsyslogd(17437): dirtied inode 765 (kmsg) on md9
<7<<<<7>[238738.918567] setcfg(29492): dirtied inode 989 (CACHEDEV1_DAT<<7>[238738.987736] rsyslo<7>[238739.198363] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<<7><<<7>[23<<<<<7>[238723.318337] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238723.318366] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238723.318382] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238723.318398] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
<<<<7>[23<<7>[238729.038329] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238729.038355] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238729.038372] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238729.038387] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
<7>[23<<7>[238733.938343] jbd2/md9-8(628): WRITE block 530488 on md9 (8 sectors)
<7>[238733.938377] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238733.938404] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238733.938422] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238733.938438] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 5/100 test, Mon Nov 23 16:40:04 GMT 2020 ===============
<<7>[238744.929243] jbd2/md9-8(628): WRITE block 530680 on md9 (8 sectors)
<7>[238744.929261] jbd2/md9-8(628): WRITE block 530688 on md9 (8 sectors)
<7>[238744.930218] jbd2/md9-8(628): WRITE block 530696 on md9 (8 sectors)
<7>[238749.928528] jbd2/md9-8(628): WRITE block 592240 on md9 (16 sectors)
<7>[238749.928559] md9_raid1(616): WRITE block 1060216 on sda1 (1 secto<<7>[238749.988342] kworker/u8:2(29362): WRITE block 592248 on md9 (8 sectors)
<<7>[238754.988339] kworker/u8:2(29362): WRITE block 0 on md9 (8 sectors)
<7>[238754.988373] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238754.988401] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238754.988419] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238754.988436] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 6/100 test, Mon Nov 23 16:40:26 GMT 2020 ===============
<7>[238794.098541] jbd2/md9-8(628): WRITE block 592304 on md9 (8 sectors)
<7>[238794.098573] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238794.098601] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238794.098620] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238794.098638] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 7/100 test, Mon Nov 23 16:40:58 GMT 2020 ===============
<<7>[238800.033040] md9_raid1(616): WRITE block 1060232 on sda1 (1 sectors)
<7>[238800.033059] md9_raid1(616): WRITE block 1060232 on sdd1 (1 sectors)
<7>[238800.033072] md9_raid1(616): WRITE block 1060232 on sdc1 (1 sectors)
============= 8/100 test, Mon Nov 23 16:41:04 GMT 2020 ===============
<<<7>[238805.078333] kworker/u8:0(9309): WRITE block 8 on md9 (8 sectors)
<7>[238805.078366] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
============= 9/100 test, Mon Nov 23 16:41:14 GMT 2020 ===============
<<7>[238848.898332] jbd2/md9-8(628): WRITE block 592368 on md9 (16 sectors)
<7>[238848.898373] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238848.898401] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238848.898419] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238848.898436] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 10/100 test, Mon Nov 23 16:41:58 GMT 2020 ===============
<7>[238855.488405] md9_raid1(616): W<7<7>[238859.547964] hal_enc_temp(797): dirtied inode 13292095 (em_0.info) on tmpfs
<7>[238855.488337] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238855.488377] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
============= 11/100 test, Mon Nov 23 16:42:04 GMT 2020 ===============
<7>[238862.1572<<<7>[238865.098479] rsyslogd(17437): dirtied inode 765 (kmsg) on md9
<7>[238865.098560] jbd2/md9-8(628): WRITE block 592392 on md9 (16 sectors)
<7>[238865.098592] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238865.098618] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238865.098638] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238865.098655] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 12/100 test, Mon Nov 23 16:42:09 GMT 2020 ===============
<<<<7<<7<7>[2<<7>[23<<7>[238872.858153] hal_enc_temp(797): dirtied inode 13295662 (em_0.info) o<<7<<7>[238875.518319] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238875.518341] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238875.518356] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238875.518370] md9_raid1(616): WRITE block
============= 13/100 test, Mon Nov 23 16:42:19 GMT 2020 ===============
<<<<7<7><<<<<7>[238880.528318] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238880.528341] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238880.528356] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
============= 14/100 test, Mon Nov 23 16:42:33 GMT 2020 ===============
<<7>[238893.238529] jbd2/md9-8(628): WRITE block 592432 on md9 (8 sectors)
<7>[238893.238561] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238893.238588] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238893.238606] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238893.238623] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 15/100 test, Mon Nov 23 16:42:37 GMT 2020 ===============
<<7>[238898.998327] jbd2/md9-8(628): WRITE block 592432 on md9 (16 sectors)
<7>[238898.998359] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238898.998388] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238898.998406] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238898.998423] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
<7>[238900.328330] kworker/u8:2(29362): WRITE block 592440 on md9 (8 sectors)
<7>[238900.328365] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238900.328392] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238900.328410] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238900.328428] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 16/100 test, Mon Nov 23 16:42:44 GMT 2020 ===============
<<7>[238904.338529] jbd2/md9-8(628): WRITE block 531928 on md9 (8 sectors)
<7>[238904.338563] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238904.338592] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238904.338610] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238904.338627] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 17/100 test, Mon Nov 23 16:42:48 GMT 2020 ===============
<<7<<7>[<<<<<<<<<7><<<<<<7>[238915.021632] md9_raid1(616): WRITE block 1060232 on sda1 (1 sectors)
<7>[238915.021658] md9_raid1(616): WRITE block 1060232 on sdd1 (1 sectors)
<7>[238915.021675] md9_raid1(616): WRITE block 1060232 on sdc1 (1 sectors)
============= 18/100 test, Mon Nov 23 16:42:59 GMT 2020 ===============
<<<7>[238920.378810] md9_raid1(616): WRITE block 1060232 on sda1 (1 sectors)
<7>[238920.378830] md9_raid1(616): WRITE block 1060232 on sdd1 (1 sectors)
<7>[238920.378843] md9_raid1(616): WRITE block 1060232 on sdc1 (1 sectors)
<7>[238920.378857] md9_raid1(616): WRITE block 1060232 on sdb1 (1 sector<7>[238920.588322] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238920.588352] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238920.588371] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238920.588387] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 19/100 test, Mon Nov 23 16:43:10 GMT 2020 ===============
<7>[238940.548552] jbd2/md9-8(628): WRITE block 592472 on md9 (16 sectors)
<7>[238940.548587] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238940.548619] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238940.548640] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238940.548660] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
<7>[238945.468369] kworker/u8:0(9309): WRITE block 592480 on md9 (16 sectors)
<7>[238945.468403] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238945.468432] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238945.468451] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238945.468468] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
============= 20/100 test, Mon Nov 23 16:43:30 GMT 2020 ===============
<7>[238950.508325] kworker/u8:2(29362): WRITE block 592488 on md9 (8 sectors)
<7>[238950.508358] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238950.508386] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238950.508403] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238950.508420] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
<<<7>[238950.760179] jbd2/md9-8(628): WRITE block 532328 on md9 (8 sect
============= 21/100 test, Mon Nov 23 16:43:34 GMT 2020 ===============
<<7>[238956.030137] md9_raid1(616): WRITE block 1060232 on sda1 (1 sectors)
<7>[238956.030152] md9_raid1(616): WRITE block 1060232 on sdd1 (1 sectors)
<7>[238956.030165] md9_raid1(616): WRITE block 1060232 on sdc1 (1 sectors)
<7>[238956.030176] md9_raid1(616): WRITE block 10602<<<<7<
============= 22/100 test, Mon Nov 23 16:43:40 GMT 2020 ===============
<<<<7><<<7>[238965.863293] md9_raid1(616): WRITE block 1060232 on sda1 (1 sectors)
<7>[238965.863309] md9_raid1(616): WRITE block 1060232 on sdd1 (1 sectors)
============= 23/100 test, Mon Nov 23 16:43:50 GMT 2020 ===============
<<<<7>[238975.848307] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238975.848330] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238975.848344] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238975.848357] md9_raid1(616): WRITE block 1060216 on sdb1
============= 24/100 test, Mon Nov 23 16:44:02 GMT 2020 ===============
<7>[238983.778654] jbd2/md9-8(628): WRITE block 532552 on md9 (8 sectors)
<7>[238983.778706] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[238983.778754] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[238983.778779] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[238983.778802] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
<7><<7>[<<<7>[238985.858308] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
============= 25/100 test, Mon Nov 23 16:44:12 GMT 2020 ===============
<<<<7>[239010.168306] md9_raid1(616): WRITE block 1060216 on sda1 (1 sectors)
<7>[239010.168328] md9_raid1(616): WRITE block 1060216 on sdd1 (1 sectors)
<7>[239010.168343] md9_raid1(616): WRITE block 1060216 on sdc1 (1 sectors)
<7>[239010.168356] md9_raid1(616): WRITE block 1060216 on sdb1 (1 sectors)
