TS251A not going into standby (probably since HDD replacement)
Discussion about hard drive spin down (standby) feature of NAS.
andre85
Post by andre85 » Wed Apr 21, 2021 10:38 pm
Hi there.
I've got an issue with my TS251A for quite a while now.
I feel like it started when I've replaced my 2x 4 TB WD Red with 2x 12 TB WD Red. This was about 1.5 years ago.
Since that I feel like the HDDs are not getting any sleep :(
Also I've got an error message after every reboot, that the filesystem is not clean. (even though I restart it from the webui)
I've done a filesystem check several times, always with no issues.
Not sure if this is related to my standby issue, but I think it's worth mentioning.
I've disabled all services (as far as I can tell), except for Microsoft Networking. I'll add a screenshot.
I've also run the blkdevMonitor twice - once before I cleaned up even further (removed the Hybrid DeskStation, disabled OpenVPN, set the standby timer for the HDDs to 5min instead of 30min, removed my Windows-Networkmappings) and once after.
Also rebooted afterwards and was waiting for about one hour after the reboot before I started the second scan.
I feel like I got more entries since I've cleaned up actually :(
Unfortunately I don't have the first log anymore. But here comes the second log:
===== Welcome to use blkdevMonitor_v2 on Wed Apr 21 15:45:44 CEST 2021 =====
Stop klogd.sh daemon... Done
Turn off/on VM block_dump & Clean dmesg
Countdown: 3 2 1
Start...
============= 0/100 test, Wed Apr 21 15:45:51 CEST 2021 ===============
<7>[24486.580266] smbd(25003): dirtied inode 163053581 (locking.tdb) on dm-0
<7>[24486.580272] smbd(25003): dirtied inode 163053581 (locking.tdb) on dm-0
<7>[24483.830283] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[24483.830295] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[24483.814442] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24483.814476] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[24483.828152] jbd2/md9-8(2444): WRITE block 528856 on unknown-block(9,9) (8 sectors)
<7>[24483.828166] jbd2/md9-8(2444): WRITE block 528864 on unknown-block(9,9) (8 sectors)
<7>[24483.828174] jbd2/md9-8(2444): WRITE block 528872 on unknown-block(9,9) (8 sectors)
<7>[24483.828182] jbd2/md9-8(2444): WRITE block 528880 on unknown-block(9,9) (8 sectors)
<7>[24483.830356] jbd2/md9-8(2444): WRITE block 528888 on unknown-block(<7>[24484.709446] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24484.709482] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 1/100 test, Wed Apr 21 15:46:04 CEST 2021 ===============
<7>[24494.069525] jbd2/md9-8(2444): WRITE block 528984 on unknown-block(9,9) (8 sectors)
============= 2/100 test, Wed Apr 21 15:46:10 CEST 2021 ===============
<<7>[24510.962475] jbd2/dm-0-8(17206): WRITE block 3854950984 on unknown-block(253,0) (8 sectors)
<7>[24514.675010] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[24514.534444] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24514.534476] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[24513.382444] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24513.382474] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[24513.774457] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24513.774493] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 3/100 test, Wed Apr 21 15:46:33 CEST 2021 ===============
<7>[24521.587541] kworker/u4:1(22520): WRITE block 9071244680 on u<<<7>[24521.628626] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7<<<7>[24519.695795] jbd2/md9-8(2444): WRITE block 835<<<<7>[24520.778123] hal_enc_temp(2576): dirtied inode 2298899 (em_0.info) on tmpfs
<<7>[24519.677650] jbd2/md9-8(2444): WRITE block 835184 on unknown-block(9,9) (8 sectors)
<7>[24524.768474] jbd2/md9-8(2444): WRITE block 835192 on unknown-block(9,9) (8 sectors)
<7>[24521.817622] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) <7>[24522.807481] hal_enc_temp(2576): dirtied inode 2298936 (em_0.info) on tmpfs
<7>[24521.575450] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24521.575486] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[24521.<<7>[24521.817585] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
============= 4/100 test, Wed Apr 21 15:46:41 CEST 2021 ===============
<7>[24530.826669] jbd2/md9-8(2444): WRITE block 835208 on unknown-block(9,9) (8 sectors)
<7>[24530.830442] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24530.830473] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 5/100 test, Wed Apr 21 15:46:48 CEST 2021 ===============
<7>[24541.974670] jbd2/md9-8(2444): WRITE block 835232 on unknown-block(9,9) (8 sectors)
<<<7>[24541.995167] jbd2/md9-8(2444): WRITE block 835240 on unknown-block(9,9) (8 sectors)
<7>[24541.995248] jbd2/md9-8(2444): WRITE block 529376 on unknown-block(9,9) (8 sectors)
<7>[24541.995257] jbd2/md9-8(2444): WRITE block 529384 on unknown-block(9,9) (8 sectors)
<7>[24541.995266] jbd2/md9-8(2444): WRITE block 529392 on unknown-block(9,9) (8 sectors)
<7>[24541.995272] jbd2/md9-8(2444): WRITE block 529400 on unknown-block(9,9) (8 sectors)
<7>[24541.995279] jbd2/md9-8(2444): WRITE block 529408 on unknown-block(9,9) (8 sectors)
<7>[24541.998143] jbd2/md9-8(2444): WRITE block 529416 on unknown-block(9,9) (8 sectors)
============= 6/100 test, Wed Apr 21 15:46:59 CEST 2021 ===============
<7>[24547.234097] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24547.234132] md9_raid1(2431): WRITE block 1060216 on unknown-bloc<<7>[24547.539451] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24547.539484] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<<<7>[24550.374451] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24550.374483] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 7/100 test, Wed Apr 21 15:47:08 CEST 2021 ===============
<7>[24554.158159] Plex Media Serv(16259): dirtied inode 220856533 (Plex Media Server.log) on dm-0
<7>[24554.158182] Plex Media Serv(16259): dirtied inode 220856533 (Plex Media Server.log) on dm-0
<7>[24554.158185] Plex Media Serv(16259): dirtied inode 220856533 (Plex Media Server.log) on dm-0
<<7>[2<7>[24558.448113]<<<<<7>[24559.083865] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[24557.428601] jbd2/md9-8(2444): WRITE block 5<7>[24557.803010] md9_raid1(2431): WRITE<7>[24558.414309] hal_enc_temp(2576): dirtied inode 2306858 (em_0.info) on tmpfs
<7>[24557.40<7>[24557.404749] jbd2/md9-8(2444): WRITE block 835264 on unknown-block(9,9) (8 sectors)
<<7>[24557.428508] jbd2/md9-8(2444): WRITE block 835272 on unknown-block(9,9) (8 sectors)
<7>[24557.428585] jbd2/md9-8(2444): WRITE block 529520 on unknown-block(9,9) (8 sectors)
<7>[24557.428594] jbd2/md9-8(2444): WRITE block 529528 on unknown-block(9,9) (8 sectors)
============= 8/100 test, Wed Apr 21 15:47:16 CEST 2021 ===============
<<7>[24567.519440] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24567.519471] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[24567.541993] jbd2/md9-8(2444): WRITE block 529656 on unknown-block(9,9) (8 sectors)
============= 9/100 test, Wed Apr 21 15:47:27 CEST 2021 ===============
<7>[24586.543102] md9_raid1(2431): WRITE block 1060232 on <7>[24586.79
============= 10/100 test, Wed Apr 21 15:47:43 CEST 2021 ===============
<<7><<7>[24596.790445] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24596.790470] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 11/100 test, Wed Apr 21 15:47:54 CEST 2021 ===============
<7>[24609.760479] jbd2/md9-8(2444): WRITE block 835392 on unknown-block(9,9) (8 sectors)
<<7>[24615.278707] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[24615.278725] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[24615.686490] md9_raid1(24<7><7>[24615.783442] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24611.688455] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24611.688487] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[24613.862443] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24613.862473] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[24615.783474] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 12/100 test, Wed Apr 21 15:48:13 CEST 2021 ===============
<7>[24619.889597] jbd2/dm-0-8(17206): WRITE bl<<<<<<7>[24619.890263] jbd2/dm-0-8(17206): WRITE block 3854951584 on unknown-block(253,0) (8 sectors)
============= 13/100 test, Wed Apr 21 15:48:16 CEST 2021 ===============
<7>[24637.427517] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[24637.427528] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[24635.554596] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[24635.554631] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[24637.412446] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24637.412483] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<<<7>[24639.974449] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24639.974484] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 14/100 test, Wed Apr 21 15:48:40 CEST 2021 ===============
<7>[24646.868187] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[24646.868199] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[24646.869137] smbd(25003): dirtied inode 163053581 (locking.tdb) on dm-0
<<<<<7>[24646.048875] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1<7>[24646.112487] jbd2/dm-0-8(17206): WRITE block 3854951680 on unknown-block(253,0) (8 sectors)
<7>[24647.654447] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24647.654478] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[2<<<7>[24648.050944] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[24648.050960] md9_raid1(2431): WRITE block 10
============= 15/100 test, Wed Apr 21 15:48:45 CEST 2021 ===============
<7>[24656.757194] md9_raid1(2431): WRITE block 1060<7>[24656.836991] hal_enc_temp(2576): dirtied inode 2332112 (em_0.info) on tmpfs
<<7>[24656.737694] jbd2/md9-8(2444): WRITE block 835496 on unknown-block(9,9) (8 sectors)
<7>[2<<<<7>[24656.757179] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[2<7>[24653.068452] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24653.068491] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 16/100 test, Wed Apr 21 15:48:54 CEST 2021 ===============
<7>[24660.851347] jbd2/dm-0-8(17206): WRITE block 3854951800 on unknown-block(253,0) (8 sectors)
<7>[24661.892793] jbd2/md9-8(2444): WRITE block 835512 on unknown-block(9,9) (8 sectors)
<7>[24661<7>[24661.911289] jbd2/md9-8(2444): WRITE block 835520 on unknown-block(9,9) (8 sectors)
<7>[24661.911361] jbd2/md9-8(2444): WRITE block 530480 on unknown-block(9,9) (8 sectors)
<7>[24661.911370] jbd2/md9-8(2444): WRITE block 530488 on unknown-block(9,9) (8 sectors)
<7>[24661.911378] jbd2/md9-8(2444): WRITE block 530496 on unknown-block(9,9) (8 sectors)
<7>[24661.911386] jbd2/md9-8(2444): WRITE block 530504 on unknown-block(9,9) (8 sectors)
<7>[24661.911393] jbd2/md9-8(2444): WRITE block 530512 on unknown-block(9,9) (8 sectors)
<7>[24663.027254] md9_raid1(2431): WRITE block 1<7>[24663.322463] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24663.322500] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 17/100 test, Wed Apr 21 15:49:01 CEST 2021 ===============
<<7>[24678.800942] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[24678.800955] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[24682.238665] jbd2/md9-8(2444): WRITE block 835568 on unknown-block(9,9) (8 sectors)
<7>[24679<<7>[24679.911446] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24679.911477] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[24681.318444] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24681.318476] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 18/100 test, Wed Apr 21 15:49:20 CEST 2021 ===============
<7>[24706.957021] smbd(25003): dirtied inode 163053581 (locking.tdb) on dm-0
<7>[24706.957<<<7>[24706.973134] jbd2/dm-0-8(17206): WRITE block 3854952080 on unknown-block(253,0) (8 sectors)
<7>[24703.621698] jbd2/md9-8(2444): WRITE block 836640 on unknown-block(9,9) (8 sectors)
<7>[24703.640246] jbd2/md9-8(2444): WRITE block 836648 on unknown-block(9,9) (8 sectors)
<7>[24703.640307] jbd2/md9-8(2444): WRITE block 530864 on unknown-block(9,9) (8 sectors)
<7>[24703.640316] jbd2/md9-8(2444): WRITE block 530872 on unknown-block(9,9) (8 sectors)
<7>[24703.640323] jbd2/md9-8(2444): WRITE block 530880 on unknown-block(9,9) (8 sectors)
<7>[24703.640330] jbd2/md9-8(2444): WRITE block 530888 on unknown-block(9,9) (8 sectors)
<7>[24703.640337] jbd2/md9-8(2444): WRITE block 530896 on unknown-block(9,9) (8 sectors)
<<7>[24706.135458] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24706.135494] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 19/100 test, Wed Apr 21 15:49:45 CEST 2021 ===============
<7>[24711.978668] jbd2/dm-0-8(17206): WRITE block 3854952088 on unknown-block(253,0) (8 sectors)
============= 20/100 test, Wed Apr 21 15:49:49 CEST 2021 ===============
<<7>[24718.182446] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24718.182478] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[24718.598455] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24718.598489] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 21/100 test, Wed Apr 21 15:49:56 CEST 2021 ===============
<7>[24723.942454] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24723.942470] md9_raid1(2431): WRITE block 1060216 on unknown-bloc
============= 22/100 test, Wed Apr 21 15:50:01 CEST 2021 ===============
<7>[24732.008496] smbd(25003): dirtied inode 163053581 (locking.tdb) on dm-0
<7>[24732.008508] smbd(25003): dirtied inode 163053581 (locking.tdb) on dm-0
============= 23/100 test, Wed Apr 21 15:50:09 CEST 2021 ===============
<7>[24739.186460] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24739.186494] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[24739.201060] jbd2/md9-8(2444): WRITE block 836736 on unknown-block(9,9) (8 sectors)
<7>[24739.201126] jbd2/md9-8(2444): WRITE block 531264 on unknown-block(9,9) (8 sectors)
<7>[24739.201136] jbd2/md9-8(2444): WRITE block 531272 on unknown-block(9,9) (8 sectors)
<7>[24739.201143] jbd2/md9-8(2444): WRITE block 531280 on unknown-block(9,9) (8 sectors)
<7>[24739.201150] jbd2/md9-8(2444): WRITE block 531288 on unknown-block(9,9) (8 sectors)
<7>[24739.201157] jbd2/md9-8(2444): WRITE block 531296 on unknown-block(9,9) (8 sectors)
<7>[24739.504485] md9_raid1(2431): WR<<<7>[24739.808480] kworker/u4:3(27857): WRITE block 836736 on unknown-block(9,9) (8 sectors)
============= 24/100 test, Wed Apr 21 15:50:17 CEST 2021 ===============
<7>[24744.306204] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sec<7>[24744.53<<<
============= 25/100 test, Wed Apr 21 15:50:23 CEST 2021 ===============
<<<<7>[24754.803966] jbd2/md9-8(2444): WRITE block 836768 on unknown-block(9,9) (8 sectors)
<7>[24754.804039] jbd2/md9-8(2444): WRITE block 531408 on unknown-block(9,9) (8 sectors)
<7>[24754.804048] jbd2/md9-8(2444): WRITE block 531416 on unknown-block(9,9) (8 sectors)
<7>[24754.804056] jbd2/md9-8(2444): WRITE block 531424 on unknown-block(9,9) (8 sectors)
<7>[24754.804063] jbd2/md9-8(2444): WRITE block 531432 on unknown-block(9,9) (8 sectors)
<7>[24754.804070] jbd2/md9-8(2444): WRITE block 531440 on unknown-block(9,9) (8 sectors)
============= 26/100 test, Wed Apr 21 15:50:32 CEST 2021 ===============
<7>[24770.855477] md9_raid1(2431): WRITE block 1060216 on unknown-block(8
============= 27/100 test, Wed Apr 21 15:50:48 CEST 2021 ===============
<7>[24774.795594] jbd2/md9-8(2444): WRITE block 836816 on unknown-block(9,9) (8 sectors)
<7>[24774.814177] jbd2/md9-8(2444): WRITE block 531600 on unknown-block(9,9) (8 sectors)
<7>[24774.814189] jbd2/md9-8(2444): WRITE block<<
============= 28/100 test, Wed Apr 21 15:50:52 CEST 2021 ===============
<7>[24785.141761] md9_raid1(2431): WRITE block 10<7>[24785.302016] qsnapman-recyc(12028): dirtied inode 7249 (qlvm.conf) on md9
<7>[24784.859721] jbd2/md9-8(2444): WRITE block 836832 on unknown-block(9,9) (8 sectors)
<7>[24784.862456] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24784.862490] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[24784.874600] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[24784.874634] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[24784.878333] jbd2/md9-8(2444): WRITE block 531736 on unknown-block(9,9) (8 sectors)
<7>[24786.137482] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24786.137520] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 29/100 test, Wed Apr 21 15:51:04 CEST 2021 ===============
<7<7>[24801.610082] md9_raid1(2431): WRITE block 1060232<7>[24802.113376] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[24802.113388] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
============= 30/100 test, Wed Apr 21 15:51:21 CEST 2021 ===============
<7>[24820.192502] jbd2/dm-0-8(17206): WRITE block 3854952680 on unknown-block(253,0) (8 sectors)
============= 31/100 test, Wed Apr 21 15:51:37 CEST 2021 ===============
<7>[24829.095320] smbd(25003): dirtied inode 163053581 (locking.tdb) on dm-0
<7>[24829.095332] smbd(25003): dirtied inode 163053581 (locking.tdb) on dm-0
<<<<7>[24828.785288] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[24830.576703] jbd2/md9-8(2444): WRITE block 836952 on unknown-block(9,9) (8 sectors)
<7>[24830.591620] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[24830.591644] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[24830.962682] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[24830.962691] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[24831.974455] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24831.974487] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[24832.870448] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24832.870478] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[24833.166460] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24833.166496] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 32/100 test, Wed Apr 21 15:51:52 CEST 2021 ===============
<7>[24840.714830] jbd2/md9-8(2444): WRITE block 836968 on unknown-block(9,9) (8 sectors)
============= 33/100 test, Wed Apr 21 15:51:58 CEST 2021 ===============
<7>[24844.768493] jbd2/dm-0-8(17206): WRITE block 3854952856 on unknown-block(253,0) (8 sectors)
<7>[24845.803712] jbd2/md9-8(2444): WRITE block 836976 on unknown-block(9,9) (8 sectors)
============= 34/100 test, Wed Apr 21 15:52:03 CEST 2021 ===============
<7>[24857.890574] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[24857.890584] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
============= 35/100 test, Wed Apr 21 15:52:15 CEST 2021 ===============
<7>[24871.194661] jbd2/md9-8(2444): WRITE block 837056 on unknown-block(9,9) (8 sectors)
============= 36/100 test, Wed Apr 21 15:52:29 CEST 2021 ===============
<7>[24884.622493] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24884.622531] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 37/100 test, Wed Apr 21 15:52:42 CEST 2021 ===============
<<<<7>[24892.261130] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[24892.261143] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7<<7><<7>[24888.306586] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[24888.306603] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[24888.646458] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24888.646494] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 38/100 test, Wed Apr 21 15:52:49 CEST 2021 ===============
<7>[24897.599688] jbd2/md9-8(2444): WRITE block 837120 on unknow<7><<7>[<<7>[24897<<<<<<7>[24<<<7><<7>[24898.616448] hal_enc_temp(2576): dirtied inode 2405154 (em_0.info) on tmpfs
<7>[24898.894456] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24898.894491] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 39/100 test, Wed Apr 21 15:52:57 CEST 2021 ===============
<7>[24905.524462] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24905.524498] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 40/100 test, Wed Apr 21 15:53:03 CEST 2021 ===============
<<7>[24<7>[24909.795708] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[24912.838530] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24912.838561] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[24912.854898] jbd2/md9-8(2444): WRITE block 532944 on unknown-block(9,9) (8 sectors)
<7>[24911.718451] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24911.718487] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 41/100 test, Wed Apr 21 15:53:10 CEST 2021 ===============
<<7>[24917.298514] smbd(25003): dirtied inode 163053588 (smbXsrv_open_glo<<7>[24917.842694] jbd2/md9-8(2444): WRITE block 837160 on unknown-block(9,9) (8 sectors)
<7>[24917.859610] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[24917.859642] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
============= 42/100 test, Wed Apr 21 15:53:15 CEST 2021 ===============
<7>[24933.865448] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24933.865478] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 43/100 test, Wed Apr 21 15:53:31 CEST 2021 ===============
<7>[24944.342655] jbd2/md9-8(2444): WRITE block 837224 on unknown-block(9,9) (8 sectors)
<7>[24944.472587] jbd2/md9-8(2444): WRITE block 837232 on unknown-block(9,9) (8 sectors)
<7>[24944.472663] jbd2/md9-8(2444): WRITE block 533192 on unknown-block(9,9) (8 sectors)
<7>[24944.472673] jbd2/md9-8(2444): WRITE block 533200 on unknown-block(9,9) (8 sector<
<7>[24940.699499] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[24940.699536] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 44/100 test, Wed Apr 21 15:53:41 CEST 2021 ===============
<7>[24949.395682] jbd2/md9-8(2444): WRITE block 837232 on unknown-block(9,9) (8 se<7>[24949.411543] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[24949.411569] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
============= 45/100 test, Wed Apr 21 15:53:47 CEST 2021 ===============
<<7>[24980.455465] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[24980.455502] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[24980.717146] md9_raid1(2431): WRITE block 106023<<
============= 46/100 test, Wed Apr 21 15:54:17 CEST 2021 ===============
<7>[25004.839454] Plex Media Serv(16259): dirtied inode 220856533 (Plex Media Server.log) on dm-0
============= 47/100 test, Wed Apr 21 15:54:42 CEST 2021 ===============
<7>[25012.537695] jbd2/md9-8(2444): WRITE block 837392 on unknown-block(9,9) (8 sectors)
============= 48/100 test, Wed Apr 21 15:54:49 CEST 2021 ===============
<7>[25017.656693] jbd2/md9-8(2444): WRITE block 837392 on unknown-block(9,9) (8 sectors)
============= 49/100 test, Wed Apr 21 15:54:55 CEST 2021 ===============
<7>[25034.975269] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
============= 50/100 test, Wed Apr 21 15:55:12 CEST 2021 ===============
<7>[25039.568966] smbd(24395): dirtied inode 163053580 (brlock.tdb) on dm-0
<7>[25039.568972] smbd(24395): dirtied inode 163053580 (brlock.tdb) on dm-0
<7>[25039.190459] md9_raid1(2431): <7>[25039.329647] ncaas(7536): dirtied inode 2448716 (?) on tmpfs
<<7<<<7>[25038.845091] jbd2/md9-8(2444): WRITE block 837456 on unknown-block(9,9) (8 sectors)
<7>[25038.845163] jbd2/md9-8(2444): WRITE block 534032 on unknown-block(9,9) (8 sectors)
<7>[25038.845173] jbd2/md9-8(2444): WRITE block 534040 on unknown-block(9,9) (8 sectors)
<7>[25038.845181] jbd2/md9-8(2444): WRITE block 534048 on unknown-block(9,9) (8 sectors)
<7>[25038.845188] jbd2/md9-8(2444): WRITE block 534056 on unknown-block(9,9) (8 sectors)
<7>[25038.845195] jbd2/md9-8(2444): WRITE block 534064 on unknown-block(9,9) (8 sectors)
============= 51/100 test, Wed Apr 21 15:55:19 CEST 2021 ===============
<7>[25049.998553] Plex Media Serv(16259): dirtied inode 220856533 (Plex Media Server.log) on dm-0
<7>[25049.998571] Plex Media Serv(16259): dirtied inode 220856533 (Plex Media Server.log) on dm-0
<<7>[25048.929676] jbd2/md9-8(2444): WRITE block 837464 on unknown-block(9,9) (8 sectors)
<7>[25049.237538] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25049.237544] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25048.946562] <<<<7>[25049.237469] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25049.237506] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 52/100 test, Wed Apr 21 15:55:28 CEST 2021 ===============
<7>[25057.260207] md9_raid1(2431): WRITE block <<7>[25057.262560] kworker/u4:0(20382): WRITE block 837512 on unknown-block(9,9) (8 sectors)
============= 53/100 test, Wed Apr 21 15:55:35 CEST 2021 ===============
<7>[25067.506549] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25067.506582] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
============= 54/100 test, Wed Apr 21 15:55:46 CEST 2021 ===============
<<7>[25079.628454] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25079.628486] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 55/100 test, Wed Apr 21 15:55:57 CEST 2021 ===============
<7>[<<<7>[25087.989538] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<<7>[25085.927450] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25085.927484] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 56/100 test, Wed Apr 21 15:56:08 CEST 2021 ===============
<<7<<<<7>[25094.9<<<7>[25095.271963] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25095.271977] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
============= 57/100 test, Wed Apr 21 15:56:14 CEST 2021 ===============
<<7>[25099.762263] jbd2/dm-0-8(17206): WRITE block 3854954080 on unknown-block(253,0) (8 sectors)
<7>[25099.762295] jbd2/dm-0-8(17206): WRITE block 38549<<7>[25099.951454] gen_bandwidth(16303): dir<<7<7>[25099.956448] md9_raid1(2431): WRITE block 1060216 on unk<<7<<7>[25099.969216] jbd2/md9-8(2444): WRITE block 837608 on unknown-block(9,9) (8 sectors)
<7>[25099.969283] jbd2/md9-8(2444): WRITE block 534608 on unknown-block(9,9) (8 sectors)
============= 58/100 test, Wed Apr 21 15:56:20 CEST 2021 ===============
<7>[25108.964230] jbd2/dm-0-8(17206): WRITE block 3854954112 on unknown-block(253,0) (8 sectors)
============= 59/100 test, Wed Apr 21 15:56:26 CEST 2021 ===============
<<7>[25118.990465] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25118.990501] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 60/100 test, Wed Apr 21 15:56:36 CEST 2021 ===============
<7>[25122.621501] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25122.62151<<7><<<7>[25122.632577] jbd2/dm-0-8(17206): WRITE block 3854954240 on unknown-block(253,0) (8 sectors)
<7>[25123.006464] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25123.006498] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<<7>[25127.910451] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25127.910482] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 61/100 test, Wed Apr 21 15:56:46 CEST 2021 ===============
<7>[25133.961813] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25133.961824] smbd(25003): dirtied inode 1630<<<7>[25134.052453] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25135.572262] smbd(24395): dirtied inode 163053580 (<<7>[25135.872948] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25134.052485] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<<7>[25135.500693] jbd2/md9-8(2444): WRITE block 865352 on unknown-block(9,9) (8 sectors)
<7>[25135.872959] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[25139.179487] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25139.179522] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25133.926457] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25133.926490] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<<7<<7>[25138.286462] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25138.286498] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 62/100 test, Wed Apr 21 15:56:57 CEST 2021 ===============
<<7>[25149.414455] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25149.414491] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25150.944513] jbd2/md9-8(2444): WRITE block 865384 on unknown-block(9,9) (8 sectors)
<7>[25150.965669] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25150.965698] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[25150.307451] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25150.307486] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 63/100 test, Wed Apr 21 15:57:09 CEST 2021 ===============
<7>[25172.706302] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25172.706313] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25172.707315] smbd(25003): dirtied inode 163053581 (locking.tdb) on dm-0
<7>[25170.250612] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[25173.194707] jbd2/md9-8(2444): WRITE block 865424 on unknown-block(9,9) (8 sectors)
<7>[25173.217071] jbd2/md9-8(2444): WRITE block 865432 on unknown-block(9,9) (8 sectors)
<7>[25173.217133] jbd2/md9-8(2444): WRITE block 535280 on unknown-block(9,9) (8 sectors)
<7>[25173.217142] jbd2/md9-8(2444): WRITE block 535288 on unknown-block(9,9) (8 sectors)
<7>[25173.217150] jbd2/md9-8(2444): WRITE block 535296 on unknown-block(9,9) (8 sectors)
<7>[25173.217157] jbd2/md9-8(2444): WRITE block 535304 on unknown-block(9,9) (8 sectors)
<7>[25173.217164] jbd2/md9-8(2444): WRITE block 535312 on unknown-block(9,9) (8 sectors)
<<7>[25170.790459] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25170.790493] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[25171.046467] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25171.046502] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 64/100 test, Wed Apr 21 15:57:31 CEST 2021 ===============
<7>[2<<<7>[25185.479453] Plex Media Serv(16259): dirtied inode 220856533 (Plex Media Server.log) on dm-0
<7>[25188.838458] md1_raid1(2701): WRITE block 23417<<<<7>[25188.85250<<
============= 65/100 test, Wed Apr 21 15:57:46 CEST 2021 ===============
<7>[25193.<7>[25194.024709] jbd2/md9-8(2444): WRITE block 865472 on unknown-block(9,9) (8 sectors)
============= 66/100 test, Wed Apr 21 15:57:52 CEST 2021 ===============
<<7>[25199.457672] jbd2/md9-8(2444): WRITE block 865488 on unknown-block(9,9) (8 sectors)
============= 67/100 test, Wed Apr 21 15:57:57 CEST 2021 ===============
<7>[25204.971802] jbd2/md9-8(2444): WRITE block 865496 on unknown-block(9,9) (8 sectors)
<7>[25204.988367] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
============= 68/100 test, Wed Apr 21 15:58:03 CEST 2021 ===============
<7>[25211.243550] md9_raid1(2431): WRITE bloc<<7>[25211.682363] hal_enc_temp(2576): dirtied inode 2492297 (em_0.info) on tmpfs
============= 69/100 test, Wed Apr 21 15:58:09 CEST 2021 ===============
<<7>[25215.013454] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25215.013490] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<<7>[25<<<7>[25215.274489] md9_raid1(2431): WRITE block 1060216 on unknown-block(<
============= 70/100 test, Wed Apr 21 15:58:13 CEST 2021 ===============
<<<<<<<7>[25224.095812] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25224.095821] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25220.010459] gen_bandwidth(1<<7>[252<<<7>[25220.033918] jbd2/md9-8(2444): WRI<<<<<7>[25220.833856] hal_enc_temp(2576): dirtied inode 2495444 (em_0.info) on tmpfs
<<7>[25226.204890] smb<<7>[25226.208462] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25226.208498] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25219.046456] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25219.046494] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 71/100 test, Wed Apr 21 15:58:24 CEST 2021 ===============
<7>[25231.350024] jbd2/md9-8(2444): WRITE block 535848 on unknown-block(9,9) (8 sectors)
============= 72/100 test, Wed Apr 21 15:58:34 CEST 2021 ===============
<7>[25252.286690] jbd2/md9-8(2444): WRITE block 865600 on unknown-block(9,9) (8 sectors)
============= 73/100 test, Wed Apr 21 15:58:49 CEST 2021 ===============
<7>[25269.089681] jbd2/md9-8(2444): WRITE block 865648 on unknown-block(9,9) (8 sectors)
<7>[25265.518465] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25265.518499] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 74/100 test, Wed Apr 21 15:59:06 CEST 2021 ===============
<7>[25280.404199] md9_raid1(2431): WRITE <<7>[25280.768457] hal_enc_temp(2576): dirtied inode 2508386 (em_0.info) on tmpfs
<7>[25282.819441] md9_raid1(2431): WRITE block 1060232 on unknown-block(<7>[25283.549488] ncaas(7536): dirtied inode 2510395 (?) on tmpfs
<7>[25279.970509] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25279.970515] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25282.534458] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25282.534490] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25282.819420] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25279.970455] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25279.970486] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 75/100 test, Wed Apr 21 15:59:21 CEST 2021 ===============
<7>[25297.907161] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25297.907175] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25297.780139] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[25293.054468] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25293.054503] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25295.846454] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25295.846490] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25296.271807] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25296.271817] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[25301.984509] jbd2/md9-8(2444): WRITE block 865712 on unknown-block(9,9) (8 sectors)
<7>[25297.766453] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25297.766485] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 76/100 test, Wed Apr 21 15:59:40 CEST 2021 ===============
<<7>[25313.253461] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25313.253493] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25313.561912] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25313.561926] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[25314.150455] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25314.150486] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[25314.558467] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25314.558503] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 77/100 test, Wed Apr 21 15:59:54 CEST 2021 ===============
<7>[25325.741332] setcfg(18248): dirtied inode 6894 (CACHEDEV1_DATA.log) on md9
<7>[25325.753798] setcfg(18249): dirtied inode 7001 (CACHEDEV1_DATA.lo~) on md9
<7>[25325.764380] setcfg(18250): dirtied inode 6894 (CACHEDEV1_DATA.lo~) on md9
<7>[25325.774400] sed(18255): dirtied inode 7001 (CACHEDEV1_DATA.logST5fnn) on md9
<7>[25325.796978] setcfg(18260): dirtied inode 6894 (CACHEDEV1_DATA.lo~) on md9
<7>[25326.820484] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25326.820522] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 78/100 test, Wed Apr 21 16:00:04 CEST 2021 ===============
<7>[25332.192501] jbd2/dm-0-8(17206): WRITE block 3854955184 on unknown-block(253,0) (8 sectors)
<7>[25334.063472] md9_raid1(2431): WRITE block <7>[25334.597504] hal_enc_temp(2576): dirtied inode 2522459 (em_0.info) on tmpfs
============= 79/100 test, Wed Apr 21 16:00:10 CEST 2021 ===============
<7>[25348.853699] jbd2/md9-8(2444): WRITE block 865824 on unknown-block(9,9) (8 sectors)
============= 80/100 test, Wed Apr 21 16:00:24 CEST 2021 ===============
<7>[25358.816507] jbd2/dm-0-8(17206): WRITE block 3854955352 on unknown-block(253,0) (8 sectors)
<7>[25354.975097] md9_raid1(2431): WRITE block 1060232 on<7>[25355.<7>[25355.930431] hal_enc_temp(2576): dirtied inode 2527478 (em_0.info) on tmpfs
<7>[25354.726455] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25354.726490] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25352.165458] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25352.165495] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 81/100 test, Wed Apr 21 16:00:35 CEST 2021 ===============
<7>[2<<7>[25364.818072] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25364.818102] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[25365.080442] <<<<<<7>[25365.425771] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25365.425787] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<<7>[25370.154465] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25370.154501] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 82/100 test, Wed Apr 21 16:00:46 CEST 2021 ===============
<7>[25378.021835] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25378.021846] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25378.022800] smbd(25003): dirtied inode 163053581 (locking.tdb) on dm-0
<7>[25378.022807] smbd(25003): dirtied inode 163053581 (locking.tdb) on dm-0
============= 83/100 test, Wed Apr 21 16:00:56 CEST 2021 ===============
<<<7>[25390.342467] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25390.342500] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 84/100 test, Wed Apr 21 16:01:08 CEST 2021 ===============
<<<<7>[25403.692748] jbd2/md9-8(2444): WRITE block 537400 on unknown-block(9,9) (8 sectors)
<7>[25403.692760] jbd2/md9-8(2444): WRITE block 537408 on unknown-block(9,9) (8 sectors)
<7>[25403.692767] jbd2/md9-8(2444)<<<7>[25404.009739] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25404.009767] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[25404.262460] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25404.262490] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[25405.806891] md1_raid1(2701): WRITE block 2<<7>
============= 85/100 test, Wed Apr 21 16:01:21 CEST 2021 ===============
<<7>[25412.7821<7>[25413.088512] jbd2/dm-0-8(17206): WRITE block 3854955624 on unknown-block(253,0) (8 sectors)
============= 86/100 test, Wed Apr 21 16:01:29 CEST 2021 ===============
<7>[25420.646456] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25420.646490] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 87/100 test, Wed Apr 21 16:01:36 CEST 2021 ===============
<7>[25423.963740] jbd2/md9-8(2444): WRITE block 865992 on unknown-block(9,9) (8 sectors)
============= 88/100 test, Wed Apr 21 16:01:44 CEST 2021 ===============
<7>[25449.334539] kworker/u4:3(27857): WRITE block 90<7>[25449.336311] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[25449.346924] jbd2/md9-8(2444): WRITE block 537848 on unknown-block(9,9) (8 sectors)
============= 89/100 test, Wed Apr 21 16:02:06 CEST 2021 ===============
<7>[25460.125665] jbd2/md9-8(2444): WRITE block 866080 on unknown-block(9,9) (8 sectors)
<<7>[25460.146743] jbd2/md9-8(2444): WRITE block 537904 on unknown-block(9,9) (8 sectors)
<7>[25460.146756] jbd2/md9-8(2444): WRITE block 537912 on unknown-block(9,9) (8 sectors)
<7>[25460.146765] jbd2/md9-8(2444): WRITE block 537920 on unknown-block(9,9) (8 sectors)
<7>[25460.146772] jbd2/md9-8(2444): WRITE block 537928 on unknown-block(9,9) (8 sectors)
<7>[25460.146781] jbd2/md9-8(2444): WRITE block 537936 on unknown-block(9,9) (8 sectors)
============= 90/100 test, Wed Apr 21 16:02:16 CEST 2021 ===============
<7>[25464.843059] smbd(25024): dirtied inode 163053598 (leases.tdb) on dm-0
<7>[25465.697682] jbd2/md9-8(2444): WRITE block 866080 on unknown-block(9,9) (8 sectors)
<7>[25465.714645] kworker/u4:0(20382): WRITE block 726397928 on un<<<<<<<7>[25465.721385] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25465.721399] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1<7><7>[2<<7>[25465.725148] jbd2/md9-
============= 91/100 test, Wed Apr 21 16:02:21 CEST 2021 ===============
<7>[25471.704688] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[25471.704757] jbd2/md9-8(2444): WRITE block 866096 on unknown-block(9,9) (8 sectors)
<7>[254<<<7>[25471.942469] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25471.942504] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 92/100 test, Wed Apr 21 16:02:28 CEST 2021 ===============
<7>[25487.583058] smbd(24395): dirtied inode 163053580 (brlock.tdb) on dm-0
<7>[25487.583065] smbd(24395): dirtied inode 163053580 (brlock.tdb) on dm-0
<7>[25483.746751] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[25478.001673] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25478.001686] md9_raid1(2431): WR<<7>[25478.212862] smbd<7>[25478.373467] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25478.373503] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25478.373529] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25483.763193] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25483.763204] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[25484.017517] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25484.017525] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
<7>[25487.335468] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25487.335503] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25488.914704] jbd2/md9-8(2444): WRITE block 866136 on unknown-block(9,9) (8 sectors)
<7>[25478.373505] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 93/100 test, Wed Apr 21 16:02:46 CEST 2021 ===============
<<7>[25492.971238] hal_enc_<7>[25493.232326] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25493.232337] smbd(25003): dirtied inode 163053588 (smbXsrv_open_global.tdb) on dm-0
<7>[25495.029488] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[25495.008657] jbd2/md9-8(2444): WRITE block 866152 on unknown-block(9,9) (8 sectors)
<7>[25495.024830] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25495.024858] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
============= 94/100 test, Wed Apr 21 16:02:51 CEST 2021 ===============
<7>[25516.326664] rsyslogd(22978): dirtied inode 13339 (kmsg) on md9
<7>[25516.326730] jbd2/md9-8(2444): WRITE block 866200 on unknown-block(9,9) (8 sectors)
<7>[25518.053455] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25518.053490] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
============= 95/100 test, Wed Apr 21 16:03:15 CEST 2021 ===============
<<7>[25528.305583] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25528.305610] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,16) (1 sectors)
============= 96/100 test, Wed Apr 21 16:03:24 CEST 2021 ===============
<7>[25536.992493] jbd2/md9-8(2444): WRITE block 866248 on unknown-block(9,9) (8 sectors)
<7>[25537.270469] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25537.270505] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25539.431503] md1_raid1(2701): WR<7>[25539.441989] kworker/u4:3(27857): WRITE block 728748672 on unknown-block(253,0) (8 sectors)
<<7>[25539.681474] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25539.681511] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 97/100 test, Wed Apr 21 16:03:36 CEST 2021 ===============
<7>[25548.126468] md9_raid1(2431): WRI<7>[25548.799260] hal_enc_temp(2576): dirtied inode 2575528 (em_0.info) on tmpfs
============= 98/100 test, Wed Apr 21 16:03:46 CEST 2021 ===============
<7>[25569.774693] jbd2/dm-0-8(17206): WRITE block 3854956432 on u<7>[25570.137517] hal_enc_temp(2576): dirtied inode 2581521 (em_0.info) on tmpfs
<7>[25573.361480] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25573.361515] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25573.668167] md9_raid1(2431): WRITE block 1060232 on unknown-block(8,0) (1 sectors)
<7>[25573.668194] md9_raid1(2431): WRITE block 1060232 on un
<7>[25569.762456] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25569.762489] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
============= 99/100 test, Wed Apr 21 16:04:09 CEST 2021 ===============
<7>[25583.602899] jbd2/dm-0-8(17206): WRITE block 3854956496 on unknown-block(253,0) (8 sectors)
<7>[25578.982531] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,0) (1 sectors)
<7>[25578.982563] md9_raid1(2431): WRITE block 1060216 on unknown-block(8,16) (1 sectors)
<7>[25584.162680] jbd2/md9-8(2444): WRITE block 866352 on unknown-block(9,9) (8 sectors)
<7>[25577.958460] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25577.958495] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[25578.273467] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
<7>[25578.273500] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,16) (1 sectors)
<7>[25580.390536] md1_raid1(2701): WRITE block 23417854088 on unknown-block(8,0) (1 sectors)
Turn off block_dump
Start klogd.sh daemon
Is there anyone who could help me please? I'm quite annoyed by this, since the NAS is in my office and I'm working in the homeoffice for about a year. It keeps stressing me more every day :D
I appreciate every help!
André
Return to “HDD Spin Down (HDD Standby)”
