Disks activity statistics
Discussion about hard drive spin down (standby) feature of NAS.
ultradj83
Post by ultradj83 »
Dears,
how to check the amount of time disks have been spinning maybe in the latest month?
They're set to spin down after 10 minutes of inactivity, but I could find no records about.
I need to estimate power consumption in order to check if to spend a lot of money to replace everything with SSD or not.
Regards
holger_kuehn
Easy as a breeze
Re: Disks activity statistics
Post by holger_kuehn »
As far as I know, you'll find the PowerOnHours in Smart. Not sure if there are any statistics per se.
NAS (production): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
NAS (backup): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
Data (QTier): [RAID-6] 4 x 4TB Samsung 870 QVO Sata
Data (HDD): [RAID-6] 7 x 18TB Exos
RAM: 8 GB (QNAP shipped)
UPS: CyberPower CP900EPFCLCD
Usage: SMB with rclone (encrypted)
NAS: TS-873U-RP FW: QTS 5.1.4.2596 build 20231128
BACKUP: 4TB Synology DS214 FW: DSM 7.0.41890
Usage: SMB, Backup Domain Controller
dolbyman
Post by dolbyman »
Disk spindown is a lost cause .. the NAS is constantly writing stuff to disk
Put a powermeter on it and check your usage .. but unless your power cost are outrageous, I doubt you will compensate for the extra costs (SSD vs HDD in cost per storage) in any meaningful time
Return to “HDD Spin Down (HDD Standby)”
