Brand New TVS-x82T!
Interested in our products? Post your questions here. Let us answer before you buy.
rgarjr
Know my way around
Contact:
Re: Brand New TVS-x82T!
Post by rgarjr » Sat May 23, 2020 11:45 pm
Sushanth.reddy wrote:
Sat May 23, 2020 3:13 am
I am sorry if this has been discussed already.
Any idea if there is going to be an updated 1282T3 with the latest intel Processors, Its been a couple of years they have been refreshed? I am in market to buy one and I don't want to spend too much money on older hardware though it's powerful.
What's interesting is QNAP just made a video of 2 new models that look very similar to the TVS-x82, TS-686 and TS-886 with Xeon processors.
https://www.youtube.com/watch?v=dRFkkf_M2n0
TS-1677x-R7-2700 | 64GB HyperX | 4 x 860 EVO 500GB [RAID5] | Corsair SF600 | All Noctua fans | NH-L12 CPU cooler | 8 x WD 10TB | QM2-4P-384 card (4 x 1TB ADATA XPG SX8200 Pro M.2 [RAID5]) | Emulex Oce11102-NX
TS-677-R7-2700 | 64GB HyperX | 2 x 860 EVO M.2 250GB [iSCSI] | QM2-4P-384 card (4 x 500GB ADATA XPG SX8200 Pro M.2 [RAID5]) | All Noctua fans | NH-L12 CPU cooler | QXG-10G1T
TVS-682-i7-6700K | 64GB HyperX | 1 x 860 EVO 1TB | Corsair SF450 | All Noctua fans | NH-L12 CPU cooler | Emulex Oce11102-NX
TVS-682-i7-7700 | 64GB HyperX | 1 x 860 EVO 1TB | Corsair SF450 | All Noctua fans | NH-L12 CPU cooler | Emulex Oce11102-NX
rafale
Easy as a breeze
Post by rafale » Sat May 30, 2020 2:53 am
Interesting indeed. Note that the Xeon CPUs are 27W and 40W lower powered CPU from the Broadwell architecture so essentially the same or actually a bit older than the initial TVS-x82 which was skylake... They just don't have an iGPU.
This all in spite of being released in Q2 or 2019.
I just took a look on amazon and was stunned by how expensive the NAS has become... COVID19 effect it seems.
Given the lack of update, I decided to add a GPU to mine...
Server: TVS-872XT i9 9900 ES, 64GB DDR4 2666MHz, intel X550-T2, Asus RTX3070 Dual OC (On pico PSU), 2x Phison E12 1TB M.2, 4x Micron 5210 7.68TB, 4x WD Purple 4TB
Backup NAS: TS-473 20GB DDR4 2400MHz, Mellanox ConnectX3, 2x Samsung PM871b 256GB M.2, 4x WD Red 8TB
Former units: TVS-1282, TS-871, TS-469
P3R
Post by P3R » Sat May 30, 2020 3:37 am
The update have been available for years, TS-X77. :wink:
rafale
Easy as a breeze
Post by rafale » Sat May 30, 2020 3:43 am
lol... true to some degree and I have considered it... but the incremental improvement vs the cost has prevented me from doing it.
P3R
Post by P3R » Sat May 30, 2020 4:27 am
I know, wait for the revamped Ryzen-line!
ainemorf
Post by ainemorf » Sun May 31, 2020 5:41 am
Please excuse me but I was not able to understand if is it possible to swap i3 6100 processor of y QNAP 682T to i7 7700.
I already upgraded BIOS of my QNAP with QX77AT22 versione which support gives me but I don't know if this BIOS which is the last which I can flash on my NAS permits to install i7 7700.
The problem is to understand if is it possible to swap from 6th generation to 7th gneration of processor.
Please can someone help me to understand if can I do this?
Thanks a lot
vassoura
Getting the hang of things
Post by vassoura » Sun May 31, 2020 6:30 am
Thanks a lot
As stated previously, you can, but it's not advisable because you might brick the unit... Stick to the generation of your product. If you have an i3-6100, you can use an i7-6700k. If your unit came with an i3-7100, you can use a i7-7700k. In both cases, you can use the "T" versions or the non "K" ones of these CPUs because they have a lower TDP and that's always good, since the unit lacks a little bit in terms of airflow.
So, theoretically, it should be possible, but unless I'm mistaken, nobody took the chance of bricking the unit. I haven't dared doing it myself... Another reason is that the i7-7700k's price is way too high for a Quad-Core CPU in 2020...
TVS-682
- CPU: i7-6700K
- RAM: 32GB DDR4 Kingston HX434C19FRK2/32 (2x16GB 3466MHz@1.2v)
- COOLER: Noctua NH-L12 cooler
- FANS: 1x60mm NoiseBlocker fan, 1x60mm Noctua fan, 2x80mm Noctua fans, 1x92mm Noctua fan
- STORAGE: 2x500GB Crucial MX500 M.2 SSDs (RAID1 - VM duties), 2x500GB Samsung Evo 850 SSDs (RAID1 - Qtier), QM2-2P-344 with 2x500GB NVMe ADATA XPG SX8200 Pro M.2 (Caching), 4x3TB HDDs (RAID5 - Qtier)
- GPU: MSI GTX 1050 Ti LP
- PSU: SF450
peelos
Been there, done that
Post by peelos » Sun May 31, 2020 9:05 am
If you have already installed the bios then there should not be a bricking risk of trying a 7700K processor, it either works or it doesn't. Cannot confirm if the bios you stated supports 7th gen CPU or not though.
Sent from my SM-N975F using Tapatalk
NAS: TVS-1282-i7K-40G / 4 x 500GB SSD 2.5" / 2 x 500GB M.2 SSD / 8 x 12TB WD Whites 3.5" / Corsair H5-SF Watercooling / 3 x 80mm PWM Noctua fans / Corsair 600W PSU / Asus Turbo GTX 1060 6GB GPU
Software: Plex Media Server / QTransmission / Sonarr / Radarr / Bazarr / Jackett / QMono / Tautulli / OpenHAB / Resilio Sync / QPython / QJDK 8 / NetData / Qapache / SortMyQPKGs
pfSense Firewall / OpenVPN Server: QOTOM Fanless Mini PC / Core i5 / 8GB RAM / 128GB SSD / 4 Gigabit NICs / AES-NI
Wireless Routers: 2 x Netgear AC1900 R7000 Nighthawk / Advanced Tomato Firmware
michalspl2000
Post by michalspl2000 » Fri Jun 19, 2020 2:09 am
Hi guys, subject is so long and a lot of pictures are missing.
I need a bit help.
I want upgrade my tvs-1282:
- CPU i3 to i7 6700k (max processor for it)
- probably cooler on cpu (any suggestions)
- exchange PSU 250W to I think sf600 600W (but I read that need to add something some cables -> mby im wrong)
- need exchange fans for "silence" (any suggestions)
okenny
Know my way around
Post by okenny » Sat Jun 20, 2020 10:32 pm
Hi michalspl2000, I think you're really going to have to take the time to read through this long thread to learn how others upgraded.
If you have any specific questions, let us know.
You will need a QNAP PSU adapter cable (I got mine on Ebay, just search for it), and you will need a new CPU cooler for the i7-6700k (I have a Corsair unit but others have a Noctua).
QNAP TVS-1282-i7K-40G with Corsiar H5 SF watercooling, 3x 80mm PWM Noctua fans, 1x 60mm PWM Noctua fan, Corsair SF450 PSU
michalspl2000
Post by michalspl2000 » Sun Jun 21, 2020 3:33 am
ok if u say so :) :
PSU sf600 https://www.ebay.com/itm/New-Corsair-SF ... ondition=3 -> what I will need more ? without that?
for CPU I want buy that:
https://www.ebay.com/itm/Intel-Core-i7- ... b02b92fc2d
for coooling cpu I think about Corsiar H5 SF watercooling but if I have m.2 with radiators I don't think will match so what you propose to put in ?
for silence FANs I read about Noctua, but right now I don't know which one pick... I can pick from: Noctua NF-A8 PWM vs FLX vs ULN they are very similar but ...
If i'm right I need 3 of them ...
mby on that stage (preaparing to upgrade) you will give me other propose like diferent fans/psu etc ;)
peelos
Post by peelos » Sun Jun 21, 2020 3:36 am
All the info is earlier in the thread and also in my signature - even if it is a long thread it's a good one Image
M.2 with radiators you will have to test and let us know!
literally searched "PSU" in this thread and 4 posts back found this: https://www.ebay.com/itm/Power-Supply-U ... 3030853128
rafale
Easy as a breeze
Post by rafale » Mon Jun 22, 2020 10:28 pm
After years of playing with water-cooling, I can say now that I would not recommend it due to the maintenance needed and risks involved for a 24/7 machine. I opted to replace the heatsink with one of similar design but heftier and made out of copper. There are a lot of options for "passive 2U cooler" (Mine is a Dynatron Y506) involving copper and heat pipes up to 100W TDP. Technically with normal case airflow, these should not even need a CPU fan. I also replaced the blower fans with more powerful ones. I did not care so much about the noise and honestly it's not all that loud in my office.
immaculatec
Post by immaculatec » Sat Jul 11, 2020 4:43 pm
I have been trying to find Noctua NH-L12 but no luck so far, so any suggestion would be appreciated. I would like to stick to air cooling..
rgarjr
Know my way around
Contact:
Post by rgarjr » Sun Jul 12, 2020 12:35 am
You're in luck cause the Noctua NH-L12 just got resurrected thanks to Louqe Ghost sffpc case. It is now called the NH-L12 Ghost Edition.
Return to “Presales”
