multiple VLANs on one NIC (trunking)
Tell us your most wanted features from QNAP products.
auroch
Re: multiple VLANs on one NIC (trunking)
Post by auroch » Thu Mar 07, 2019 8:34 pm
When i bought my QNAP, i thought it was an enterprise class NAS, now i see that fails with things like it.
This is a MUST. It'll come some day?
guner
First post
Post by guner » Mon Jul 01, 2019 12:14 am
The Problem is similar to synology, but there exist a solution im forum and for qnap it shouuld be the same:
https://joffer.blogspot.com/2014/06/how ... ap_26.html
My opinion: If it possible use freenas. You have to invest more money, because you need freebsd compatible hardware, but for the use in a business enviroment you should have some coins more.
Hardware vendor: miniserver.it, sysgen.de, thomas-krenn.de, ixsystems.com, with prior testing HP Microserver (very cheap)
ZipTX
Post by ZipTX » Tue Jul 09, 2019 10:47 pm
+1 ... pretty critical feature especially to leverage a 10G card
eguitton
Post by eguitton » Fri Jul 12, 2019 6:33 am
I join the others on that feature, highly awaited ! After being able to do LACP with NICs, the next immediate thing I would try to setup would be multiple vlans, either at the cisco way (trunk 802.1Q all), or the HP vania (Untag (access port) default vlan + multiple tagged (802.1q) vlans).
When I first saw I couldn't get this ability, was quite shocked :/
Just a random Data & Network tech guy.
heronimus
Post by heronimus » Sun Jul 14, 2019 1:47 am
I was searching for options to configure VLAN in the virtual switch... Then i found this thread... what a disappointment, it isn't there at all. I hope QNAP will include a more advanced VLAN in their roadmap.
ccolotti
Post by ccolotti » Tue Aug 13, 2019 12:25 am
Still amazed this is not in QTS...this is networking 101...not sure why QNAP is ignoring this feature need.
casw1000
Post by casw1000 » Sun Aug 18, 2019 5:55 am
+1 on this feature. I setup virtualization station on two of my 3 qnaps, having installed dual 10Gb interfaces then spending hours on thinking what I was doing wrong. Alas, trunking is not supported. Seriously QNAP, I love your hadware / QTS, but please, implement this feature into QTS and make the true power of the vQTS and Virtualization realised. Thanks.
zipler
Know my way around
Post by zipler » Tue Sep 03, 2019 10:03 pm
Any update on when this will be implemented?
I just got an email (advertisement) for a new QXG-10G2T-107. 10Gb nics without vlan trunking is mostly a waste.
P3R
Post by P3R » Wed Sep 04, 2019 3:39 am
I don't disagree with the feature request but that's NOT true.
AZeroEight
Post by AZeroEight » Sat Sep 21, 2019 7:50 am
Don't understand they put so much effort in putting "advanced" features into their software and don't cover the basics and this is really a pretty basic feature seeing the power of what it can do.
Zabo4
Post by Zabo4 » Thu Oct 03, 2019 4:07 pm
I don't know when this changed but on my TS-832X running QTS 4.4.1.1064 - I don't know when it changed but now I see "Add VLAN" as an adapter option below "Configure" in the ellipsis menu on the Network & Virtual Switch page. I was able to add multiple VLANs to a single adapter.
I can't find any documentation on the change (and indeed the help page still discusses "Enable VLAN" on the VLAN tab in the configuration menu even though that tab no longer exists).
In any case, this is very exciting!
trendchiller
Easy as a breeze
Post by trendchiller » Thu Oct 03, 2019 4:11 pm
good news...
4.3.6.1070 did not have this - I just checked ;-)
trendchiller
Easy as a breeze
Post by trendchiller » Tue Oct 08, 2019 7:06 am
On all my 4.4.1 capable QNAPs available now.
Seems as if QNAP introduced this silently.
But really sad it‘s not available for 4.3.6 (legacy) devices.
JBBERLIN
Getting the hang of things
Re: multiple VLANs on one NIC (trunking) SOLVED! - Can be close
Post by JBBERLIN » Sat Oct 19, 2019 6:03 am
In 4.4.1 is it done ! :)
Actual:
1x TS-EC1279U-RP @ Xeon E3-1275 QuadCore & 16 GByte ECC RAM ;-) / 10x Constellation ES.2 2TB @ RAID6 + 2x Intel 530 SSD4Cache
2x TS-EC1680U-RP V2 @ Xeon E3-1275L v3 & 32 GByte ECC RAM;) / 6x HGST Helium 8TB @ RAID10 + 2x Samsung 850 mSATA SSD Cache + 10x Sandisk X400 1TB SSD
1x TVS-682 @ i7-6700T & 64 GByte RAM / 4x HGST 6TB @ RAID 10 + 2x m2 SSD SANDISK X400 1TB + 2x SANDISK X400 1TB SATA SSD
My QNAP History:
2x 509 CPU,RAM and 6HDD Mod / 809U CPU & RAM Mod / TS470 CPU & RAM ProMod / TVS471 CPU & RAM Mod / 879Pro Xeon CPU & ECC RAM & Fan EC Mod / 3x 471U-SP CPU & RAM Mod / HS251 No Mod! ;)
liberomic
Post by liberomic » Mon Oct 28, 2019 7:38 am
Hi all,
With the latest version QTS 4.4.1.1101 build 20191025, trunking with vlan does not working.
After firmware upgrade the nas ip on interface tagged is unreachable.
I have followed some tests, and in some cases the tag interface does not work after reboot, or not work at first activation.
I have noted the trunk interface will be created only tagged and I can't create virtual adapter on untag ID 1, and other virtual adapter on tag interface. The application container does not see the virtual switch on trunking interface.
Qnap please solve this bugs!!!
Regards
Liberomic
Tested on TS-253be
Return to “Features Wanted”
