[QPKG] sherpa: a mini-package-manager (CLI) beta
- OneCD
Re: [SCRIPT] sherpa.sh
Hi guys, happy new year to you both.
Clinton recently pushed a commit to modify [eol.py] in nzbToMedia and this problem is no-more.
Your nzbToMedia will need to be updated. This happens when you stop then start the SABnzbd QPKG in your App Center. If you've manually modified any of the nzbToMedia core files, please advise. This will require a git reset first.
Yes, still waiting for a stable Py3 version of each of the sherpa apps. As each one can be converted, I'll update sherpa to do this and post here.
Happy new year @OneCD! Dang I modified mine. Do I just change it back?
- OneCD
- dirkonline
- Easy as a breeze
Ah gotacha, thanks for getting back to us. I just had a quick read up on his issue in GIT and I saw that now as well Thanks!OneCD wrote: ↑Tue Jan 07, 2020 2:18 am Hi guys, happy new year to you both.
I just navigated to /share/MD0_DATA/Download/nzbToMedia and did "git reset --hard" then "git pull"
Just need to wait for something to download and see if it is all ok.
Thanks OneCD.
Thanks OneCD.
Hi @OneCD,
Thanks so much for this script. Probably the single greatest thing to happen on this forum. I've been using SickChill and it's working great, however my issue arises with OWatcher3 and LazyLibrarian. It was working for a couple days, then stopped. Restarting doesn't work, and re-installing via the script hasn't helped either. Nothing shows up on :5070, :9090, :5299, or anything. SickChill seems to be working fine. Note that I've changed IP since the last time it was working, although this problem was happening pre-IP change.
Please let me know some troubleshooting steps that come to mind. Thanks!
J
J
- OneCD
Hi and welcome to the forum.
Can you please post the package init logs?
What is your NAS model and firmware version?jkcchan wrote: ↑Thu Jan 16, 2020 5:22 am I've been using SickChill and it's working great, however my issue arises with OWatcher3 and LazyLibrarian. It was working for a couple days, then stopped. Restarting doesn't work, and re-installing via the script hasn't helped either. Nothing shows up on :5070, :9090, :5299, or anything.
cat /var/log/OWatcher3.log
cat /var/log/LazyLibrarian.log
NAS Model: TS-231P
Firmware: 4.4.1.1146
-------------------- start requested --------------------
= Sun Jan 5 16:38:34 GMT 2020
= (OWatcher3) is not active
* updating (OWatcher3): OK
= result: 0
= PullGitRepo(): 'Fetching origin
HEAD is now at c64df06 Merge pull request #111 from barbequesauce/barbequesauce-patch-1
Already up to date.'
* starting (OWatcher3): OK
-------------------- stop requested --------------------
= Mon Jan 6 10:16:56 GMT 2020
= Mon Jan 6 10:17:02 GMT 2020
= result: 0
= Wed Jan 15 15:50:54 GMT 2020
= Wed Jan 15 15:51:01 GMT 2020
= result: 0
From https://github.com/barbequesauce/Watcher3
c64df06..87a4518 master -> origin/master
HEAD is now at 87a4518 fix adding torrent to deluge web 2.x, fixes #80
= Wed Jan 15 16:07:59 GMT 2020
= Wed Jan 15 16:08:09 GMT 2020
= result: 0
[~] # cat /var/log/LazyLibrarian.log
= Sun Jan 5 16:39:04 GMT 2020
= (LazyLibrarian) is not active
* updating (LazyLibrarian): OK
= result: 0
From https://gitlab.com/LazyLibrarian/LazyLibrarian
29c79b77..ba156875 master -> origin/master
HEAD is now at ba156875 Move toggles to right side for remaining pages
* starting (LazyLibrarian): OK
= Mon Jan 6 10:17:01 GMT 2020
= Mon Jan 6 10:17:07 GMT 2020
= result: 0
= Wed Jan 15 16:08:02 GMT 2020
= Wed Jan 15 16:08:08 GMT 2020
= result: 0
ba156875..00ac0b71 master -> origin/master
HEAD is now at 00ac0b71 Use global ratelimit for zlibrary
Hi OneCD,
Running TVS-EC880 & 4.4.1.1146
I was running the individual packages for NZBGet and SickChill but because of changes in both I bumped into some challenges. PostProcessing no longer working & no updates on the SickChill show lists anymore. So time to move on
That's when I landed over here.
I first removed the default Python packages 2.7 & 3.8 as they were not accessed by any app and I don't require them for app development. Followed the instructions and ran the scripts for SickChill & NZBGet. The last one gave an error stating that port 6789 is already in use (which it is for JAVA). I tried to change this in the config.ini to the old value of the stand alone qpkg and restarted the app from the app center and that worked fine.
I took a similar approach for SickChill and changed the port value in the config.ini too. However, when I tried to open it in the app center it's going to the expected port value but nothing shows up. When checking for the port use using netstat it didn't show anything.
Do you know why SickChill would not start up?
Thanks in advance.
Thanks in advance.
Cheers,
TVS EC880 / 8 x 6TB WD Red in Raid 6 / QTS 4.5.4.1800
Hybrid Backup Station 3 / Virtualization Station / Container Station / QSync
TS-509 Pro / 4 x 2TB Seagate in Raid 5 / QTS 4.2.X (latest build)
- OneCD
OK, both logs suggest the same behaviour - the app is launched, but is then unavailable. Your init logs indicate both apps are not recording the used UI ports after launch.
Let's focus on Watcher3 for now. Try launching it manually by running these 3 commands:
export PYTHONPATH=/opt/bin/python3
cd $(/sbin/getcfg OWatcher3 Install_Path -f /etc/config/qpkg.conf)/OWatcher3
/opt/bin/python3 watcher3.py --userdata config --conf config/config.ini
Any problems reported on-screen? Please paste your launch messages back here.
edit: updated path
- OneCD
Good work.MHuijbregts wrote: ↑Mon Jan 27, 2020 6:10 am Followed the instructions and ran the scripts for SickChill & NZBGet. The last one gave an error stating that port 6789 is already in use (which it is for JAVA). I tried to change this in the config.ini to the old value of the stand alone qpkg and restarted the app from the app center and that worked fine.
Can you please post the SickChill init log?MHuijbregts wrote: ↑Mon Jan 27, 2020 6:10 am I took a similar approach for SickChill and changed the port value in the config.ini too. However, when I tried to open it in the app center it's going to the expected port value but nothing shows up. When checking for the port use using netstat it didn't show anything.
cat /var/log/SickChill.log
Thanks so much for this prompt reply. Just ran, output belowOneCD wrote: ↑Mon Jan 27, 2020 10:03 amOK, both logs suggest the same behaviour - the app is launched, but is then unavailable. Your init logs indicate both apps are not recording the used UI ports after launch.
Let's focus on Watcher3 for now. Try launching it manually by running these 3 commands:This should launch Watcher3 in interactive-mode (if you close your terminal, Watcher3 will terminate). Please examine the launch messages. When it appears to have finished launching, use your browser to navigate to http://nasip:5070Code: Select all
export PYTHONPATH=/opt/bin/python3 cd $(/sbin/getcfg OWatcher3 Install_Path -f /etc/config/qpkg.conf)/OWatcher3 /opt/bin/python3 watcher3.py --userdata config --conf config/config.ini
edit: updated path
[~] # export PYTHONPATH=/opt/bin/python3
[~] # cd $(/sbin/getcfg OWatcher3 Install_Path -f /etc/config/qpkg.conf)/OWatcher3
[/share/CACHEDEV1_DATA/.qpkg/OWatcher3/OWatcher3] # /opt/bin/python3 watcher3.py --userdata config --conf config/config.ini
/opt/bin/python3: can't open file 'watcher3.py': [Errno 2] No such file or directory
- OneCD
Hmm, that's not right. Looks like the main Watcher3 script is missingjkcchan wrote: ↑Mon Jan 27, 2020 1:54 pmCode: Select all
[/share/CACHEDEV1_DATA/.qpkg/OWatcher3/OWatcher3] # /opt/bin/python3 watcher3.py --userdata config --conf config/config.ini /opt/bin/python3: can't open file 'watcher3.py': [Errno 2] No such file or directory
Can you please get a directory listing there?
ll /share/CACHEDEV1_DATA/.qpkg/OWatcher3/OWatcher3
[/share/CACHEDEV1_DATA/.qpkg/OWatcher3/OWatcher3] # ll /share/CACHEDEV1_DATA/.qpkg/OWatcher3/OWatcher3
drwxr-xr-x 16 admin administ 4.0k Jan 1 16:08 ./
drwxr-xr-x 4 admin administ 4.0k Jan 15 15:51 ../
drwxr-xr-x 8 admin administ 4.0k Jan 15 16:08 .git/
drwxr-xr-x 3 admin administ 4.0k Dec 29 15:45 .github/
-rw-rw-rw- 1 admin administ 266 Jan 1 16:08 .gitignore
drwxr-xr-x 2 admin administ 4.0k Dec 29 15:45 Docker/
-rw-r--r-- 1 admin administ 471 Dec 29 15:45 Dockerfile
-rw-r--r-- 1 admin administ 530 Dec 29 15:45 ISSUE_TEMPLATE.md
-rw-r--r-- 1 admin administ 6.1k Dec 29 15:45 README.md
-rw-r--r-- 1 admin administ 2.6k Dec 29 15:45 backup.py
drwxr-xr-x 5 admin administ 4.0k Jan 2 18:20 core/
drwxr-xr-x 15 admin administ 4.0k Dec 29 15:45 lib/
-rw-r--r-- 1 admin administ 9.5k Dec 29 15:45 license.txt
drwxr-xr-x 2 admin administ 4.0k Dec 29 15:45 locale/
drwxr-xr-x 2 admin administ 4.0k Jan 26 23:29 logs/
drwxr-xr-x 5 admin administ 4.0k Dec 29 15:45 plugins/
drwxr-xr-x 2 admin administ 4.0k Dec 29 15:45 post scripts/
drwxr-xr-x 3 admin administ 4.0k Dec 29 15:45 run scripts/
drwxr-xr-x 7 admin administ 4.0k Dec 29 15:45 static/
drwxr-xr-x 6 admin administ 4.0k Jan 26 23:29 templates/
drwxr-xr-x 2 admin administ 4.0k Dec 29 15:45 tests/
-rw-r--r-- 1 admin administ 22 Dec 29 15:45 tox.ini
drwxr-xr-x 2 admin administ 4.0k Dec 29 15:45 userdata/
-rw-r--r-- 1 admin administ 7.6k Dec 29 15:45 watcher.py
- OneCD
Oops, my bad. I gave you the wrong command to launch Watcher3.jkcchan wrote: ↑Mon Jan 27, 2020 2:56 pmCode: Select all
Try these:
/opt/bin/python3 watcher.py --userdata config --conf config/config.ini
