HDD always spinning up at same time each day
Discussion about hard drive spin down (standby) feature of NAS.
OneCD
Ask me anything
Re: HDD always spinning up at same time each day
Post by OneCD » Wed May 31, 2017 4:32 am
TOMillr wrote:
# m h dom m dow cmd
53 21 * * * /mnt/ext/opt/QcloudSSLCertificate/bin/ssl_agent_cli
This schedule line also fits (fairly closely) with your mention of 9:52pm
TOMillr wrote:
# m h dom m dow cmd
0 9,21 * * * /sbin/notify_update -m -s -p 1>/dev/null 2>&1
This one matches your 9pm activity too.
TOMillr
Post by TOMillr » Thu Jun 01, 2017 1:24 am
Yes, the time is set correctly. ;-)
TOMillr
Post by TOMillr » Thu Jun 01, 2017 3:13 am
OneCD wrote:
TOMillr wrote:
# m h dom m dow cmd
TOMillr wrote:
# m h dom m dow cmd
Can I just unquote or delete those entries somehow? Or uninstall the QcloudSSL components altogether?
OneCD
Ask me anything
Post by OneCD » Thu Jun 01, 2017 3:59 am
Yes, you can comment those lines out by prefixing them with a hash character (#), but to correctly apply any changes, suggest you read the crontab wiki.
TOMillr
Post by TOMillr » Thu Jun 01, 2017 4:18 am
Ok, got it. Thanks. Let's see what happens tomorrow.
How about those other entries in the crontab? You link lists some of those but how can I find out what all the other ones are used for? Or which I might not need and can disable?
OneCD
Ask me anything
Post by OneCD » Thu Jun 01, 2017 4:37 am
TOMillr wrote:How about those other entries in the crontab? You link lists some of those but how can I find out what all the other ones are used for? Or which I might not need and can disable?
Usually, it's not advisable to disable crontab entries unless you put them there. These entries are needed for correct operation of the OS. Disabling them can have unwanted side-effects. ;)
TOMillr
Post by TOMillr » Thu Jun 01, 2017 5:13 am
I'm just curious about entries like this one:
/etc/init.d/nss2_dusg.sh
Your link above says "is a job of the Surveillance Station". Which I've never installed or used on my NAS - but apparently is still running nonetheless.
schumaku
Contact:
Post by schumaku » Fri Jun 02, 2017 4:15 pm
TOMillr wrote:Your link above says "is a job of the Surveillance Station". Which I've never installed or used on my NAS - but apparently is still running nonetheless.
...it's there for legacy reasons. It won't spin-up any HDD as it will only check the RAM disk based existence of /var/.nvr_init_ok and then terminate.
#!/bin/sh
if [ -f /var/.nvr_init_ok ]; then
        /usr/bin/qcmd DUSG
fi
P3R
Post by P3R » Fri Jun 02, 2017 5:31 pm
TOMillr wrote:Yes, the time is set correctly. ;-)
Updated from a time server?
keithkei
Post by keithkei » Wed Jun 07, 2017 10:46 pm
I am getting QNAP support to resolve it. Hopes the root cause can be found :cry:
The log I got by running the script suggested by the QNAP support shows that, there may not be read/write to the hdd, the hdd just wake...weird...
TOMillr
Post by TOMillr » Thu Jun 08, 2017 1:15 am
No, I've disabled that option just to make sure.
TOMillr
Post by TOMillr » Thu Jun 22, 2017 2:49 am
So I've updated the firmware to the latest version, which was supposed to address some of the issues with hdd standby.
While the pattern has changed somewhat, the NAS still wakes up a couple of times a day at the same exact time - like clockwork.
For example, at around 7:55 (19:55) the HDDs spin up for half an hour before going back to sleep. Since I've set the HDD timeout to 10 minutes, some internal process seems to keep the NAS/HDD active for about 20 minutes.
As a reminder, I've basically disabled everything that I can get at through the guide and even have disconnected the LAN cable to eliminate any external causes... :?
===== Welcome to use blkdevMonitor_v2 on Thu Jun 15 11:15:48 CEST 2017 =====
Turn off/on VM block_dump & Clean dmesg
Countdown: 3 2 1
Start...
============= 4/100 test, Thu Jun 15 19:54:51 CEST 2017 ===============
<7>[259872.908334] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[259872.908368] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[259872.940160] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[259872.940191] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[259873.163796] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[259873.163836] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[259873.186925] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[259873.186945] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[259881.135026] detect_defaultg(25929): dirtied inode 67903 (python) on md13
<7>[259881.135040] detect_defaultg(25929): dirtied inode 67904 (python2) on md13
<7>[259881.135088] detect_defaultg(25929): dirtied inode 67905 (python2.7) on md13
<7>[259881.139599] python(25929): dirtied inode 67881 (site.pyc) on md13
<7>[259881.140108] python(25929): dirtied inode 67730 (os.pyc) on md13
<7>[259881.141150] python(25929): dirtied inode 67658 (posixpath.pyc) on md13
<7>[259881.141415] python(25929): dirtied inode 67677 (stat.pyc) on md13
<7>[259881.141558] python(25929): dirtied inode 67657 (genericpath.pyc) on md13
<7>[259881.141685] python(25929): dirtied inode 67556 (warnings.pyc) on md13
<7>[259881.142100] python(25929): dirtied inode 67506 (linecache.pyc) on md13
<7>[259881.142231] python(25929): dirtied inode 67646 (types.pyc) on md13
<7>[259881.143187] python(25929): dirtied inode 67510 (UserDict.pyc) on md13
<7>[259881.143440] python(25929): dirtied inode 67533 (_abcoll.pyc) on md13
<7>[259881.143802] python(25929): dirtied inode 67899 (abc.pyc) on md13
<7>[259881.143927] python(25929): dirtied inode 67596 (_weakrefset.pyc) on md13
<7>[259881.147027] python(25929): dirtied inode 67597 (copy_reg.pyc) on md13
<7>[259881.147270] python(25929): dirtied inode 67480 (traceback.pyc) on md13
<7>[259881.148266] python(25929): dirtied inode 67877 (sysconfig.pyc) on md13
<7>[259881.149041] python(25929): dirtied inode 67653 (re.pyc) on md13
<7>[259881.149214] python(25929): dirtied inode 67673 (sre_compile.pyc) on md13
<7>[259881.149536] python(25929): dirtied inode 67590 (sre_parse.pyc) on md13
<7>[259881.149818] python(25929): dirtied inode 67587 (sre_constants.pyc) on md13
<7>[259881.150607] python(25929): dirtied inode 67585 (_sysconfigdata.pyc) on md13
<7>[259881.152091] python(25929): dirtied inode 67551 (site-packages) on md13
<7>[259881.152644] python(25929): dirtied inode 67741 (__init__.pyc) on md13
<7>[259881.152784] python(25929): dirtied inode 67655 (codecs.pyc) on md13
<7>[259881.153700] python(25929): dirtied inode 67837 (aliases.pyc) on md13
<7>[259881.154147] python(25929): dirtied inode 67738 (ascii.pyc) on md13
<7>[259881.156084] python(25929): dirtied inode 67714 (time.so) on md13
<7>[259881.156467] python(25929): dirtied inode 67536 (__init__.pyc) on md13
<7>[259881.156923] python(25929): dirtied inode 67706 (_ctypes.so) on md13
<7>[259881.157890] python(25929): dirtied inode 67901 (struct.pyc) on md13
<7>[259881.158004] python(25929): dirtied inode 67688 (_struct.so) on md13
<7>[259881.160498] python(25929): dirtied inode 67543 (_endian.pyc) on md13
<7>[259881.161213] python(25929): dirtied inode 67656 (subprocess.pyc) on md13
<7>[259881.161826] python(25929): dirtied inode 67692 (select.so) on md13
<7>[259881.162134] python(25929): dirtied inode 67703 (fcntl.so) on md13
<7>[259881.162326] python(25929): dirtied inode 67605 (pickle.pyc) on md13
<7>[259881.165251] python(25929): dirtied inode 67712 (binascii.so) on md13
<7>[259881.165733] python(25929): dirtied inode 67702 (cStringIO.so) on md13
<7>[259881.166167] python(25929): dirtied inode 67884 (shlex.pyc) on md13
<7>[259881.166344] python(25929): dirtied inode 67550 (collections.pyc) on md13
<7>[259881.166775] python(25929): dirtied inode 67694 (_collections.so) on md13
<7>[259881.167105] python(25929): dirtied inode 67699 (operator.so) on md13
<7>[259881.167424] python(25929): dirtied inode 67654 (keyword.pyc) on md13
<7>[259881.167593] python(25929): dirtied inode 67681 (heapq.pyc) on md13
<7>[259881.167812] python(25929): dirtied inode 67691 (itertools.so) on md13
<7>[259881.169249] python(25929): dirtied inode 67591 (threading.pyc) on md13
<7>[259881.171115] python(25929): dirtied inode 67875 (socket.pyc) on md13
<7>[259881.173980] python(25929): dirtied inode 67704 (_socket.so) on md13
<7>[259881.174842] python(25929): dirtied inode 67873 (functools.pyc) on md13
<7>[259881.175037] python(25929): dirtied inode 67715 (_functools.so) on md13
<7>[259881.175299] python(25929): dirtied inode 67698 (_ssl.so) on md13
<7>[259881.180003] python(25929): dirtied inode 67729 (httplib.pyc) on md13
<7>[259881.180570] python(25929): dirtied inode 67685 (array.so) on md13
<7>[259881.180832] python(25929): dirtied inode 67643 (urlparse.pyc) on md13
<7>[259881.185611] python(25929): dirtied inode 67647 (mimetools.pyc) on md13
<7>[259881.185812] python(25929): dirtied inode 67891 (tempfile.pyc) on md13
<7>[259881.186086] python(25929): dirtied inode 67642 (io.pyc) on md13
<7>[259881.186231] python(25929): dirtied inode 67695 (_io.so) on md13
<7>[259881.187879] python(25929): dirtied inode 67721 (random.pyc) on md13
<7>[259881.188505] python(25929): dirtied inode 67726 (__future__.pyc) on md13
<7>[259881.188741] python(25929): dirtied inode 67683 (math.so) on md13
<7>[259881.190140] python(25929): dirtied inode 67589 (hashlib.pyc) on md13
<7>[259881.190338] python(25929): dirtied inode 67716 (_hashlib.so) on md13
<7>[259881.190819] python(25929): dirtied inode 67689 (_random.so) on md13
<7>[259881.191496] python(25929): dirtied inode 67680 (rfc822.pyc) on md13
<7>[259881.192170] python(25929): dirtied inode 67532 (ssl.pyc) on md13
<7>[259881.192649] python(25929): dirtied inode 67872 (textwrap.pyc) on md13
<7>[259881.192844] python(25929): dirtied inode 67887 (string.pyc) on md13
<7>[259881.199027] python(25929): dirtied inode 67505 (base64.pyc) on md13
<7>[259881.200342] python(25929): dirtied inode 70394 (functions.pyc) on md13
<7>[259881.201029] python(25929): dirtied inode 67672 (contextlib.pyc) on md13
<7>[259881.201372] python(25929): dirtied inode 67649 (__init__.pyc) on md13
<7>[259881.201529] python(25929): dirtied inode 67650 (decoder.pyc) on md13
<7>[259881.201839] python(25929): dirtied inode 67652 (scanner.pyc) on md13
<7>[259881.202035] python(25929): dirtied inode 67690 (_json.so) on md13
<7>[259881.203820] python(25929): dirtied inode 67828 (hex_codec.pyc) on md13
<7>[259881.205207] python(25929): dirtied inode 67651 (encoder.pyc) on md13
<7>[259881.207161] python(25929): dirtied inode 67477 (__init__.pyc) on md13
<7>[259881.208238] python(25929): dirtied inode 67607 (weakref.pyc) on md13
<7>[259881.209489] python(25929): dirtied inode 67883 (atexit.pyc) on md13
<7>[259881.209720] python(25929): dirtied inode 67478 (handlers.pyc) on md13
<7>[259881.210361] python(25929): dirtied inode 67718 (cPickle.so) on md13
<7>[259881.212218] python(25929): dirtied inode 70395 (ifparser.pyc) on md13
<7>[259881.212416] python(25929): dirtied inode 70396 (re_scan.pyc) on md13
<7>[259881.222078] python(25929): dirtied inode 67588 (ConfigParser.pyc) on md13
<7>[259881.226130] python(25929): dirtied inode 67854 (__init__.pyc) on md13
<7>[259881.226399] python(25929): dirtied inode 67865 (process.pyc) on md13
<7>[259881.227063] python(25929): dirtied inode 67858 (util.pyc) on md13
<7>[259881.227864] python(25929): dirtied inode 67707 (_multiprocessing.so) on md13
<7>[259881.228691] python(25929): dirtied inode 70412 (__init__.pyc) on md13
<7>[259881.228911] python(25929): dirtied inode 70413 (core.pyc) on md13
<7>[259881.229145] python(25929): dirtied inode 67889 (pprint.pyc) on md13
<7>[259881.229382] python(25929): dirtied inode 70414 (compat.pyc) on md13
<7>[259881.229966] python(25929): dirtied inode 70416 (__init__.pyc) on md13
<7>[259881.230681] python(25929): dirtied inode 70417 (__init__.pyc) on md13
<7>[259881.232190] python(25929): dirtied inode 70418 (ipv4.pyc) on md13
<7>[259881.232682] python(25929): dirtied inode 70419 (ipv6.pyc) on md13
<7>[259881.233141] python(25929): dirtied inode 70421 (fbsocket.pyc) on md13
<7>[259881.239952] python(25929): dirtied inode 70420 (sets.pyc) on md13
<7>[259881.240375] python(25929): dirtied inode 70422 (glob.pyc) on md13
<7>[259881.240664] python(25929): dirtied inode 70423 (nmap.pyc) on md13
<7>[259881.240826] python(25929): dirtied inode 70424 (rfc1924.pyc) on md13
<7>[259881.241066] python(25929): dirtied inode 70425 (__init__.pyc) on md13
<7>[259881.241471] python(25929): dirtied inode 70426 (eui48.pyc) on md13
<7>[259881.253096] python(25929): dirtied inode 70427 (eui64.pyc) on md13
<7>[259881.264394] python(25929): dirtied inode 70405 (response.pyc) on md13
<7>[259881.302469] python(25946): dirtied inode 69340 (shttpc.py) on md13
<7>[259881.416922] python(25949): dirtied inode 68996 (list_if.sh) on md13
<7>[259881.424055] python(25955): dirtied inode 69008 (get_mac_addr.sh) on md13
<7>[259881.449188] curl(25961): dirtied inode 69015 (libcurl.so.4) on md13
<7>[259881.449460] curl(25961): dirtied inode 69018 (libcares.so.2) on md13
<7>[259881.449508] curl(25961): dirtied inode 69012 (librtmp.so.1) on md13
<7>[259881.449773] curl(25961): dirtied inode 69013 (libgnutls-deb0.so.28) on md13
<7>[259881.449830] curl(25961): dirtied inode 69011 (libhogweed.so.4) on md13
<7>[259881.449877] curl(25961): dirtied inode 69017 (libnettle.so.6) on md13
<7>[259881.449946] curl(25961): dirtied inode 69016 (libgmp.so.10) on md13
<7>[259881.450100] curl(25961): dirtied inode 69010 (libp11-kit.so.0) on md13
============= 5/100 test, Thu Jun 15 19:55:00 CEST 2017 ===============
<7>[259881.450164] curl(25961): dirtied inode 69019 (libtasn1.so.6) on md13
<7>[259881.450228] curl(25961): dirtied inode 69014 (libffi.so.6) on md13
<7>[259918.649677] hcitool(26045): dirtied inode 33062 (libbluetooth.so.3.5.0) on md13
<7>[259933.684493] sh(26057): dirtied inode 728 (hcitool) on md13
<7>[260001.390321] python(26132): dirtied inode 69384 (gsd.py) on md13
<7>[260001.404513] python(26132): dirtied inode 71043 (checkInternet.pyc) on md13
<7>[260001.406382] python(26132): dirtied inode 68582 (shttpc.pyc) on md13
<7>[259886.809457] kjournald(4301): WRITE block 291472 on md13 (8 sectors)
<7>[259886.809495] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[259886.809532] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[259886.844318] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[259886.844337] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[259886.866696] kjournald(4301): WRITE block 291480 on md13 (8 sectors)
<7>[259886.866709] kjournald(4301): WRITE block 291488 on md13 (8 sectors)
<7>[259886.866717] kjournald(4301): WRITE block 291496 on md13 (8 sectors)
<7>[259886.866725] kjournald(4301): WRITE block 291504 on md13 (8 sectors)
<7>[259886.866732] kjournald(4301): WRITE block 291512 on md13 (8 sectors)
<7>[259886.866739] kjournald(4301): WRITE block 291520 on md13 (8 sectors)
<7>[259886.866746] kjournald(4301): WRITE block 291528 on md13 (8 sectors)
<7>[259886.866754] kjournald(4301): WRITE block 291536 on md13 (8 sectors)
<7>[259886.866761] kjournald(4301): WRITE block 291544 on md13 (8 sectors)
<7>[259886.866768] kjournald(4301): WRITE block 291552 on md13 (8 sectors)
<7>[259886.866776] kjournald(4301): WRITE block 291560 on md13 (8 sectors)
<7>[259886.866783] kjournald(4301): WRITE block 291568 on md13 (8 sectors)
<7>[259886.866790] kjournald(4301): WRITE block 291576 on md13 (8 sectors)
<7>[259886.866808] kjournald(4301): WRITE block 291584 on md13 (8 sectors)
<7>[259886.866820] kjournald(4301): WRITE block 291592 on md13 (8 sectors)
<7>[259886.866832] kjournald(4301): WRITE block 291600 on md13 (8 sectors)
<7>[259886.866844] kjournald(4301): WRITE block 291608 on md13 (8 sectors)
<7>[259886.867386] kjournald(4301): WRITE block 291616 on md13 (8 sectors)
<7>[259887.093964] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[259887.093994] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[259887.111492] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[259887.111505] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[259901.173419] kworker/u8:0(24139): WRITE block 524816 on md13 (8 sectors)
<7>[259901.173457] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[259901.173498] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[259901.216596] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[259901.216614] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[259901.239649] kworker/u8:0(24139): WRITE block 524824 on md13 (8 sectors)
<7>[259901.239673] kworker/u8:0(24139): WRITE block 524832 on md13 (8 sectors)
<7>[259901.239689] kworker/u8:0(24139): WRITE block 524840 on md13 (8 sectors)
<7>[259901.239705] kworker/u8:0(24139): WRITE block 524848 on md13 (8 sectors)
<7>[259901.239724] kworker/u8:0(24139): WRITE block 524856 on md13 (8 sectors)
<7>[259901.239733] kworker/u8:0(24139): WRITE block 524864 on md13 (8 sectors)
<7>[259901.239743] kworker/u8:0(24139): WRITE block 524872 on md13 (8 sectors)
<7>[259901.239753] kworker/u8:0(24139): WRITE block 524880 on md13 (8 sectors)
<7>[259901.239762] kworker/u8:0(24139): WRITE block 524904 on md13 (8 sectors)
<7>[259901.239771] kworker/u8:0(24139): WRITE block 524912 on md13 (8 sectors)
<7>[259901.239780] kworker/u8:0(24139): WRITE block 524920 on md13 (8 sectors)
<7>[259901.239789] kworker/u8:0(24139): WRITE block 524928 on md13 (8 sectors)
<7>[259901.239798] kworker/u8:0(24139): WRITE block 525200 on md13 (8 sectors)
<7>[259901.239810] kworker/u8:0(24139): WRITE block 525280 on md13 (8 sectors)
<7>[259901.239820] kworker/u8:0(24139): WRITE block 525544 on md13 (8 sectors)
<7>[259901.239829] kworker/u8:0(24139): WRITE block 525552 on md13 (8 sectors)
<7>[259901.440940] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[259901.440972] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[259901.462178] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[259901.462199] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[259923.873722] kjournald(4301): WRITE block 291624 on md13 (8 sectors)
<7>[259923.873760] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[259923.873797] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[259923.957007] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[259923.957045] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[259923.994621] kjournald(4301): WRITE block 291632 on md13 (8 sectors)
<7>[259923.994839] kjournald(4301): WRITE block 291640 on md13 (8 sectors)
<7>[259924.215358] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[259924.215390] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[259924.250548] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[259924.250567] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[259938.688585] kworker/u8:0(24139): WRITE block 262448 on md13 (8 sectors)
<7>[259938.688624] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[259938.688662] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[259938.724918] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[259938.724936] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[259938.911042] kjournald(4301): WRITE block 291648 on md13 (8 sectors)
<7>[259938.911067] kjournald(4301): WRITE block 291656 on md13 (8 sectors)
<7>[259938.911273] kjournald(4301): WRITE block 291664 on md13 (8 sectors)
<7>[259939.134455] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[259939.134490] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[259939.170253] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[259939.170273] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[259953.776008] kworker/u8:0(24139): WRITE block 392 on md13 (8 sectors)
<7>[259953.776047] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[259953.776086] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[259953.819540] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[259953.819575] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[259954.042527] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[259954.042560] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[259954.066442] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[259954.066459] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[260007.043925] kjournald(4301): WRITE block 291672 on md13 (8 sectors)
<7>[260007.043964] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[260007.044002] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[260007.082667] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[260007.082700] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[260007.105045] kjournald(4301): WRITE block 291680 on md13 (8 sectors)
<7>[260007.105063] kjournald(4301): WRITE block 291688 on md13 (8 sectors)
<7>[260007.105077] kjournald(4301): WRITE block 291696 on md13 (8 sectors)
============= 6/100 test, Thu Jun 15 19:57:05 CEST 2017 ===============
<7>[260061.496994] ssl_agent_cli(26266): dirtied inode 19977 (ssl_agent.log) on md9
<7>[260062.465531] python(18058): dirtied inode 13482 (cmd_result) on md9
<7>[260062.548628] sdmd(13610): dirtied inode 13543 (ssdcache.conf) on md9
<7>[260121.611431] cat(26425): dirtied inode 13521 (cmd_timestamp) on md9
<7>[260066.505867] kworker/u8:0(24139): WRITE block 852040 on md9 (8 sectors)
<7>[260066.505900] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260066.505926] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260066.541176] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260066.541205] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260066.764365] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260066.764398] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260066.786079] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260066.786097] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260067.161173] kjournald(2103): WRITE block 544784 on md9 (8 sectors)
<7>[260067.161206] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260067.161241] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260067.231418] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260067.231431] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260067.320556] kjournald(2103): WRITE block 544792 on md9 (8 sectors)
<7>[260067.320577] kjournald(2103): WRITE block 544800 on md9 (8 sectors)
<7>[260067.320591] kjournald(2103): WRITE block 544808 on md9 (8 sectors)
<7>[260067.321954] kjournald(2103): WRITE block 544816 on md9 (8 sectors)
<7>[260067.580950] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260067.580970] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260067.621035] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260067.621048] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260072.389343] kworker/u8:0(24139): WRITE block 524432 on md9 (8 sectors)
<7>[260072.389383] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260072.389418] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260072.426299] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260072.426317] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260072.448635] kworker/u8:0(24139): WRITE block 786744 on md9 (8 sectors)
<7>[260072.448658] kworker/u8:0(24139): WRITE block 524400 on md9 (8 sectors)
<7>[260072.649842] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260072.649876] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260072.671251] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260072.671270] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260127.278410] kjournald(2103): WRITE block 544824 on md9 (8 sectors)
<7>[260127.278447] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260127.278484] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260127.319167] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260127.319196] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260127.337962] kjournald(2103): WRITE block 544832 on md9 (8 sectors)
<7>[260127.338152] kjournald(2103): WRITE block 544840 on md9 (8 sectors)
<7>[260127.558932] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260127.558963] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260127.591242] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260127.591259] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260132.367316] kworker/u8:0(24139): WRITE block 524424 on md9 (8 sectors)
<7>[260132.367355] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260132.367389] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260132.403367] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260132.403389] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260132.626815] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260132.626852] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260132.648280] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260132.648300] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260061.488456] sh(26266): dirtied inode 70538 (ssl_agent_cli) on md13
<7>[260061.496951] ssl_agent_cli(26266): dirtied inode 70552 (log) on md13
<7>[260061.503396] getcfg(26277): dirtied inode 70551 (data) on md13
<7>[260061.504552] ssl_agent_cli(26266): dirtied inode 70476 (cert) on md13
<7>[260007.329462] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[260007.329498] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[260007.349840] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[260007.349858] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[260021.428954] kworker/u8:0(24139): WRITE block 525096 on md13 (8 sectors)
<7>[260021.428991] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[260021.429029] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[260021.463006] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[260021.463042] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[260021.485362] kworker/u8:0(24139): WRITE block 525296 on md13 (8 sectors)
<7>[260021.485384] kworker/u8:0(24139): WRITE block 525712 on md13 (8 sectors)
<7>[260021.686454] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[260021.686490] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[260021.707897] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[260021.707916] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[260067.161168] kjournald(4301): WRITE block 291712 on md13 (8 sectors)
<7>[260067.161210] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[260067.161245] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[260067.224126] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[260067.224147] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[260067.274966] kjournald(4301): WRITE block 291720 on md13 (8 sectors)
<7>[260067.274984] kjournald(4301): WRITE block 291728 on md13 (8 sectors)
<7>[260067.283003] kjournald(4301): WRITE block 291736 on md13 (8 sectors)
<7>[260067.547898] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[260067.547931] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[260067.586572] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[260067.586585] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[260081.527162] kworker/u8:0(24139): WRITE block 525568 on md13 (8 sectors)
<7>[260081.527202] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[260081.527241] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[260081.569476] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[260081.569495] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
<7>[260081.591846] kworker/u8:0(24139): WRITE block 525584 on md13 (8 sectors)
<7>[260081.792674] md13_raid1(2120): WRITE block 1060256 on sdb4 (1 sectors)
<7>[260081.792708] md13_raid1(2120): WRITE block 1060256 on sda4 (1 sectors)
<7>[260081.814390] md13_raid1(2120): WRITE block 1060272 on sdb4 (1 sectors)
<7>[260081.814409] md13_raid1(2120): WRITE block 1060272 on sda4 (1 sectors)
============= 7/100 test, Thu Jun 15 19:59:14 CEST 2017 ===============
<7>[260222.272723] setcfg(26658): dirtied inode 13929 (uLinux.conf) on md9
<7>[260241.841816] crond(11983): dirtied inode 13886 (passwd) on md9
<7>[260241.980123] getcfg(26705): dirtied inode 13929 (uLinux.conf) on md9
<7>[260242.103479] lunportman(12101): dirtied inode 13489 (lunporter.conf) on md9
<7>[260301.960263] crond(26758): dirtied inode 13327 (group) on md9
<7>[260227.473817] kjournald(2103): WRITE block 544848 on md9 (8 sectors)
<7>[260227.473855] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260227.473899] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260227.511694] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260227.511724] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260227.534008] kjournald(2103): WRITE block 544856 on md9 (8 sectors)
<7>[260227.534226] kjournald(2103): WRITE block 544864 on md9 (8 sectors)
<7>[260227.757351] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260227.757386] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260227.778867] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260227.778885] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260232.565730] kworker/u8:0(24139): WRITE block 524624 on md9 (8 sectors)
<7>[260232.565769] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260232.565804] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260232.599402] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260232.599423] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260232.823227] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260232.823260] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260232.844350] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260232.844368] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260247.512898] kjournald(2103): WRITE block 544872 on md9 (8 sectors)
<7>[260247.512937] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260247.512974] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260247.550896] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260247.550933] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260247.573633] kjournald(2103): WRITE block 544880 on md9 (8 sectors)
<7>[260247.573650] kjournald(2103): WRITE block 544888 on md9 (8 sectors)
<7>[260247.573666] kjournald(2103): WRITE block 544896 on md9 (8 sectors)
<7>[260247.573913] kjournald(2103): WRITE block 544904 on md9 (8 sectors)
<7>[260247.797427] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260247.797460] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260247.818491] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260247.818509] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260252.605809] kworker/u8:0(24139): WRITE block 524624 on md9 (8 sectors)
<7>[260252.605849] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260252.605886] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260252.638624] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260252.638649] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260252.661495] kworker/u8:0(24139): WRITE block 524408 on md9 (8 sectors)
<7>[260252.661515] kworker/u8:0(24139): WRITE block 524600 on md9 (8 sectors)
<7>[260252.862315] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260252.862346] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260252.884091] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260252.884101] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260307.630143] kjournald(2103): WRITE block 544912 on md9 (8 sectors)
<7>[260307.630182] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260307.630218] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260307.668511] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260307.668530] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260307.690835] kjournald(2103): WRITE block 544920 on md9 (8 sectors)
<7>[260307.691060] kjournald(2103): WRITE block 544928 on md9 (8 sectors)
<7>[260307.906657] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260307.906693] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260307.926544] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260307.926563] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260312.715041] kworker/u8:0(24139): WRITE block 524320 on md9 (8 sectors)
<7>[260312.715079] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260312.715112] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260312.745120] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260312.745139] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260312.968535] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260312.968566] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260312.992149] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260312.992167] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
============= 8/100 test, Thu Jun 15 20:06:00 CEST 2017 ===============
<7>[260972.241273] hal_lvm_check(3886): dirtied inode 13912 (qlvm.conf) on md9
<7>[260972.247749] drbdadm-84(27749): dirtied inode 13396 (global_common.conf) on md9
<7>[260972.247862] drbdadm-84(27749): dirtied inode 13395 (ha) on md9
<7>[260972.247920] drbdadm-84(27749): dirtied inode 13861 (r1.res) on md9
<7>[260977.929410] kjournald(2103): WRITE block 544936 on md9 (8 sectors)
<7>[260977.929450] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260977.929494] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260993.697699] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260993.697731] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260993.714323] kjournald(2103): WRITE block 544944 on md9 (8 sectors)
<7>[260993.714341] kjournald(2103): WRITE block 544952 on md9 (8 sectors)
<7>[260993.714355] kjournald(2103): WRITE block 544960 on md9 (8 sectors)
<7>[260993.714608] kjournald(2103): WRITE block 544968 on md9 (8 sectors)
<7>[260993.938611] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260993.938645] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260993.959159] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260993.959177] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260998.746988] kworker/u8:0(24139): WRITE block 524360 on md9 (8 s
============= 9/100 test, Thu Jun 15 20:13:35 CEST 2017 ===============
<7>[260998.747027] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260998.747063] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260998.779620] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260998.779661] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[260998.802038] kworker/u8:0(24139): WRITE block 524592 on md9 (8 sectors)
<7>[260998.802083] kworker/u8:0(24139): WRITE block 524616 on md9 (8 sectors)
<7>[260999.003479] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[260999.003504] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[260999.024638] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[260999.024664] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
============= 10/100 test, Thu Jun 15 20:28:08 CEST 2017 ===============
<7>[262775.754556] hal_lvm_check(3886): dirtied inode 13914 (raid.conf) on md9
<7>[262781.446756] kjournald(2103): WRITE block 544976 on md9 (8 sectors)
<7>[262781.446793] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[262781.446835] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[262797.124494] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[262797.124524] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[262797.145131] kjournald(2103): WRITE block 544984 on md9 (8 sectors)
<7>[262797.145337] kjournald(2103): WRITE block 544992 on md9 (8 sectors)
<7>[262797.364773] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[262797.364805] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[262797.385758] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[262797.385793] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[262802.173150] kworker/u8:0(24139): WRITE block 524616 on md9 (8 sectors)
<7>[262802.173189] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[262802.173229] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[262802.206412] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[262802.206431] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
<7>[262802.429642] md9_raid1(2092): WRITE block 1060216 on sdb1 (1 sectors)
<7>[262802.429664] md9_raid1(2092): WRITE block 1060216 on sda1 (1 sectors)
<7>[262802.451346] md9_raid1(2092): WRITE block 1060232 on sdb1 (1 sectors)
<7>[262802.451365] md9_raid1(2092): WRITE block 1060232 on sda1 (1 sectors)
Turn off block_dump
End of standby test!
PeterMac83
Post by PeterMac83 » Sun Jul 01, 2018 7:40 am
@TOMillr - heh exactly, my TS-231P also wakes I noticed at exaclty same time HH:55 few times a day. For example every day at 15:55. I tried everything also.
Here is my theard - viewtopic.php?f=55&t=142016
Do you maybe resolved this or throw it out of window :) ?
Return to “HDD Spin Down (HDD Standby)”
