Sync Qfile with Google photos?
iPhone, Windows Mobile, Symbian, Android
looun
Re: Sync Qfile with Google photos?
Post by looun » Wed Jul 11, 2018 9:25 pm
quote, waiting a "Google photos sync" app on QNAP store.
https://developers.google.com/picasa-web/
dolbyman
Post by dolbyman » Wed Jul 11, 2018 11:15 pm
go ahead complain to QNAP (via ticket) .. only they can add apps to the "APP Store" .. this community forum can't do anything about it
isriam
Post by isriam » Sun Aug 19, 2018 11:51 pm
found a solution!
you can now enable google photos in drive.google.com which won't take space in your google drive. then you can use cloud sync and sync your google drive to a shared folder on your qnap. this seems to include all google photos.
looun
Post by looun » Mon Aug 20, 2018 12:58 am
isriam wrote:found a solution!
:-0 :!:
dsimeone
Post by dsimeone » Mon Sep 17, 2018 11:46 pm
Isriam are you sure about this solution? It's true that you can enable a Google Photo folder in Google Drive but according to this article from Google, the photos are going to take your limited space
https://support.google.com/drive/answer ... older&rd=2
Kinesia
Post by Kinesia » Tue Sep 18, 2018 9:02 am
I use the reduced files and that's fine for me. What I don't like is that it's this _or_ your normal folder backups, not both at once.
lalaw
First post
Post by lalaw » Wed Dec 12, 2018 6:53 am
Has anyone tried running Google Backup and Sync in a VM running in Virtualization Station?
sanfrancisco
Post by sanfrancisco » Mon Dec 24, 2018 12:51 am
Sounds kind of kooky - but curious if anyone has tried this solution?
Looks promising.
https://chosenbuys.com/2018/02/01/sync- ... le-photos/
basically:
  • Setup photo auto-upload to NAS:
    Our photos are stored on QNAP in Multimedia/Photos
    Wife’s iPhone uploads to Multimedia/Photos/iphone
    My Android uploads to Multimedia/android via the FolderSync app. Steps to accomplish this:
    Install the FolderSync app from the Google Play Store
    In the FolderSync app click on “Accounts” and create a new account which would connect to the NAS Multimedia/ share. I named the account “nas_multimedia”
    In FolderSync, create a Folder Pair to upload to remote folder /android from the local Camera folder
    I set this to sync at 12:00AM, on Wi-Fi and when charging only, enabled notifications if an error occurs, set “overwrite old files” to Never.
    Setup photo download from NAS to Android phone:
    In FolderSync, create a Folder Pair to download
    from remote folder /Photos/
    to local folder /storage/emulated/0/DCIM/nas_photos/
    The settings for this Folder Pair are the same as for the first one (12:00AM, Wi-Fi, etc)
    Now all you have to do is to periodically free up device space using Google Photos built in feature for this.
looun
Post by looun » Fri Mar 01, 2019 6:26 pm
The only solution is to shared folder on qnap and install google "backup and sync" on PC and set googlephoto to qnap shared folder.
A good alternative is Amazon Photos unlimited (full-resolution online photo storage with amazon prime) , qnap file station mount amazon drive with pictures folder where was store all photo uploaded from smartphone app, easy to access with Hybrid Backup Sync.
Return to “Mobile Devices”
