[Megathread] Moogle's QNAP FAQ help V2
Opinions on this MegaThread FAQ
Like
21
81%
No Like
8%
Unsure
3
12%
Total votes: 26
Moogle Stiltzkin
Ask me anything
Contact:
Re: [Megathread] Moogle's QNAP FAQ help V2
Post by Moogle Stiltzkin » Mon Mar 05, 2018 8:56 pm
Okamm wrote:
Moogle Stiltzkin wrote:=================Reserved==========================
hey Moog -- can I reach you off board with a question? Simple but prefer bot so public
Oliver
i sent you a msg on reddit :wink:
Last edited by Moogle Stiltzkin on Sun May 27, 2018 2:51 pm, edited 1 time in total.
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Sun Apr 22, 2018 7:22 am
Do You Really Need to Eject USB Drives?
From Youtube.com
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Sun Apr 22, 2018 7:42 am
QNAP TVS 473 vs TVS 473e vs TS 473 What is the Difference
From Youtube.com
Introduction to the TS-x73 series
From Youtube.com
*notes: due to the similar naming for the x73 series, it deserved it's own article pointing out the differences.
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Sun Apr 22, 2018 8:16 am
Did some updates (which is pointed out in the changelog on page1/2) notably updating recommendation to ts-x73 as a baseline for plex transcoding. to me the baseline ought to be able to transcode 1080p even at high bit rate and it just works, no issues. I haven't had much experience for content beyond 1080p resolution, so no comment on that :}
also qnap finally added their own 10gbe switch.
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Mon Apr 30, 2018 12:54 pm
after some review, seems i need to remove/replace some youtube which are from less than reputable sources. will do this sometime soon. i need to do better vetting for sources next time :shock:
THIO JOE videos just ignore for now. apparently
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Thu May 17, 2018 8:02 pm
Qfiling 2.0 walkthrough
From Youtube.com
From Youtube.com
Personally, how i use Qfilling is to mass delete files. For example.... i would first use Qsirch to search around for junk files on my QNAP. Then i will take note of the filenames, and maybe locations as well, i add to notepad. Then i go to Qfilling, add a rule to mass delete all the matches for those filenames/filetypes i identified as junk e.g. thumbnails ...etc
Another use, that i hadn't really made use of much, is auto sorting content. For example.... you have transmission torrent client setup to download stuff. Then you can also schedule qfilling to auto sort the download location for the torrent files, and it will sort accordingly based on the rules you set. Saves you the trouble of manually sorting yourself.
Last edited by Moogle Stiltzkin on Sun May 27, 2018 2:50 pm, edited 1 time in total.
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Thu May 17, 2018 8:43 pm
Why Buy a 1-Bay NAS - Advantages and Disadvantages
From Youtube.com
My own personal opinion, 1bay is usually fine for some who does not use much storage, and wants to go with the cheapest option. I still recommend a 2bay model as the very bare minimum, and run it in raid1.
A step up from that would be a 3bay model like the TS-328a which can do raid5 using 3hdds.
and above that is a TS-x73 or a TS-x53be series for 4bay hdd or more.
There are many more models beyond this....
*please note that these recommendations can get outdated. Is only relevant as of 17.5.2018 when it was posted
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Fri Dec 28, 2018 9:24 am
Okamm wrote:
Wed Feb 28, 2018 5:31 am
Oliver
i sent you a message on patreon :)
NAS
[Main Server] QNAP TS-877 w. 4tb [ 3x HGST Deskstar NAS (HDN724040ALE640) & 1x WD RED NAS ] EXT4 Raid5 & 2 x m.2 SATA Samsung 850 Evo raid1 + 16gb ddr4 Crucial + QWA-AC2600 wireless adapter.
[Backup] QNAP TS-653A w. 5x 2TB Samsung F3 (HD203WI) EXT4 Raid5
[^] QNAP TS-659 Pro II 1x 4TB HGST Deskstar NAS
[^] QNAP TS-228 w. 1x 1TB WD RE3 (WD1002FBYS)
[^] QNAP TS-128
Mobile NAS TBS-453DX w. 2x Crucial MX500 500gb EXT4 raid1
Network
Asus AC68U Router|100dl/50ul MBPS FTTH Internet | Windows 10, WC PC-Intel i7 920 Ivy bridge desktop (1x 512gb Samsung 850 Pro SSD + 1x 4tb HGST Ultrastar 7K4000)
Guides & articles
Return to “Users' Corner”
