QNAP RAM Recommendations
CpX
Re: QNAP RAM Recommendations
Post by CpX » Thu Jun 27, 2019 11:26 pm
@Trexx, I want to upgrade my Ryzen nas with ram, and wanted to buy the same ones you had. But where I live, they are called red, black and white kingston fury Hyper X.
I'm unsure what the difference is, can you help?
HyperX Fury Black DDR4 2666MHz 2x16GB (HX426C16FBK2/32)
HyperX Fury White DDR4 2666MHz 2x16GB (HX426C16FWK2/32)
HyperX Fury Red DDR4 2666MHz 2x16GB (HX426C16FRK2/32)
Also, did the NAS perform better with more ram, its said that Ryzen excels with more ram.
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Thu Jun 27, 2019 11:53 pm
trex uses the hyperx fury black 16gx2 dual KIT variant. specifically
Trexx wrote:
Fri May 31, 2019 10:20 am
Here is what I put in mine for the Kingston HyperX part #
HX426C16FBK2/32
https://www.amazon.com/Kingston-Technol ... B06XKSPW5V
Stay with the 2666 speed (or even slightly faster if cheaper).
I initially went for the hyperx fury black 16gb (8gb x 2). Unfortunately these were the non kit.... they booted up fine, with uptime for a couple of hours, but i later then had a random reboot. i unfortunately did not do a memtest86 or try it on downgraded qts 4.3.6 as i probably prematurely returned it for a replacement, thinking the issue was incompatible ram. Now i suspect the issue wasn't the ram compatibility, but something on QTS 4.4.1 that caused the random reboot (because using my original ram after downgrading to 4.3.6, i no longer had random reboots). But i didn't do the test so i don't know for sure in regards to the hyperx ram compatibility i installed.
For me i'm using 2x8gb (16gb total) crucial (non kit :( )
Crucial 8GB DDR4-2666 UDIMM
CT8G4DFS8266
Seems to work fine. although i would recommend going for DUAL kits for better compatibility.
viewtopic.php?f=25&t=148952&start=15#p718823
On the crucial and Kingston websites there is a validation/compatibility list for TS-877. I'm not sure for other ram, but at least those 2 for this particular model have a validation list.
NAS
[Main Server] QNAP TS-877 w. 4tb [ 3x HGST Deskstar NAS (HDN724040ALE640) & 1x WD RED NAS ] EXT4 Raid5 & 2 x m.2 SATA Samsung 850 Evo raid1 +16gb ddr4 Crucial+ QWA-AC2600 wireless+QXP PCIE
[Backup] QNAP TS-653A w. 5x 2TB Samsung F3 (HD203WI) EXT4 Raid5
[Backup] QNAP TL-D400S 2x 4TB WD Red Nas (WD40EFRX) single disks.
[^] QNAP TS-659 Pro II
[^] QNAP TS-228
[^] QNAP TS-128
Network
Asus AC68U Router|100dl/50ul MBPS FTTH Internet | Win10, WC PC-Intel i7 920 Ivy bridge desktop (1x 512gb Samsung 850 Pro SSD + 1x 4tb HGST Ultrastar 7K4000)
Guides & articles
CpX
Post by CpX » Thu Jul 11, 2019 12:45 am
@Trexx, any reason you dont use stock ram (8gb) with your black fury set of 32gbs?
Trexx
Ask me anything
Post by Trexx » Thu Jul 11, 2019 4:55 am
Because I just updated this week to 64GB (4x16GB)
Paul
Model: TS-877-1600 FW: 4.4.3.x
VMs (SSD): [RAID-1] 2 x 500GB Evo 860
GPU: EVGA GTX 1060 6GB
UPS: CP AVR1350
Model:TVS-673 32GB FW: 4.4.3.x Test/Backup Box
Model:TS-228a FW: 4.4.3.x Test/Backup Box
NAS RAID Rebuild Times | Live QTS Videos | | QNAP NAS Guide | Information needed when you ask for HELP | QNAP Links, Tutorials, etc.
Trexx
Ask me anything
Post by Trexx » Thu Jul 11, 2019 5:00 am
CpX wrote:@Trexx, I want to upgrade my Ryzen nas with ram, and wanted to buy the same ones you had. But where I live, they are called red, black and white kingston fury Hyper X.
Sorry for the late reply. Here is what I ordered.
https://www.amazon.com/gp/aw/d/B06XKSPW5V
As for black vs red etc. makes no difference is just the color of the heatsinks.
Paul
UPS: CP AVR1350
CpX
Post by CpX » Thu Jul 11, 2019 6:48 pm
Thanks, i'm waiting for upgrading with the next 32gb chunk, so in the meantime I thought about putting in the other 8. Unsure if the difference in ram will make an issue.
¨Congratulations on the upgrade!
MrCaringi
Post by MrCaringi » Thu Aug 08, 2019 7:44 am
Hola masters,
@Trexx what is your RAM recomendation for a TS-673?
Thanks in advance,
melgaard
Post by melgaard » Tue Aug 13, 2019 11:07 pm
Just to add to more experience...
Just successfully installed a 32GB Corsair Vengance LPX kit (2x16GB 2666 MHz) in my TVS-1282-i5-16G together with the original 16GB (2x8), no issues detected so far - Dual channel on and all.
Now it's only been running for 5 hours so it's a bit early to conclude anything, but so far so good.
Kit Serial: CMK32GX4M2A2666C16
Update: After 2 months of uptime, still no issue. So I would have no issue recommending those. After that I have added another kit so that I now have 64GB installed totally.
QNAP TVS-1282 - i5
4 x 16GB Corsair Vengeance LPX DDR4-2666
4 x 4TB Seagate IronWolf (ST4000VN008) - RAID10
2 x 1TB Intel 660p M.2 Nvme SSD - RAID0 - Read Cache
2 x 512GB Intel 545s SATA SSD's - RAID0
