[ Sonarr 3 ] [ 3.0.3.698 ] Smart PVR for newsgroup and bittorrent users
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
QNAP_Stephane
Experience counts
Post by QNAP_Stephane » Sun Oct 21, 2018 6:28 pm
Source : https://forums.sonarr.tv/t/sonarr-v3-alpha/19577
Download :
https://www.qnapclub.eu/fr/qpkg/652
Notes :
dependency : Qmono
please shutdown first your actual sonarr to test it (it us same 8989 port by default, due to lack of install instruction)
i do not merge volontary configuration folder (it uses /share/SONARR3_CONFIG instead)
About :
What’s New
There is a ton of new stuff,
Some highlights:
New UI
Grouping of qualities in profiles
Remux and WebRip qualities
Language Profiles
Backup and Restore config/database from the UI
Manual Search is now Interactive Search (clarity between manually searching by pressing buttons and interactively selecting a search result)
Interactive Search filtering
Interactive Search for full seasons
Customize number of rows and columns for tabular data (series, queue, history, etc)
Series import
Drone Factory has been removed, it will not be coming back, though we have plans to improve the import process outside of basic flow
report issue : https://forums.sonarr.tv/c/phantom
Last edited by QNAP_Stephane on Thu Feb 20, 2020 1:17 am, edited 4 times in total.
QnapClub AppCenter - https://www.qnapclub.eu
Toxic17
Ask me anything
Contact:
Re: [ Sonarr 3 ] [ 3.0.0.266 ] Smart PVR for newsgroup and bittorrent users
Post by Toxic17 » Sun Oct 21, 2018 10:40 pm
do you know if its backwards compatible with a Sonarr v2.0.x backup?
Regards Simon
QTS 4.x User Guidex
QNAP Club Repository
NAS: TS-473-32GB QM2-2P QXG-10G1T 4.4.1.1216 • TVS-463-16GB 4.4.1.1216 QM2-2S10G1TB • TS-459 Pro 2GB 4.2.6 • TS-121 4.3.3.1161 • APC Back-UPS ES 700G •
QPKG's: TwonkyServer 8.51 • Apache73 v2441.7310 • QSonarr 3.0.3.645 • QNBZGet 21.0 • phpMyAdmin 4.9.0.1 • Qmono 5.20.1.19 • McAfee 3.0.1 • Lychee 3.2.16 • HBS 3.0.191016 • LEgo v3.1.0
Network: VM Hub 3.0 <500/35> • UniFi USG Pro 4 • UniFi USW-16-150W • UniFi USW-8-60W • UniFi CloudKey Gen2+• UniFi G3-Flex • UAP AC Pro • UAP AC Lite • SLM2008 • Dell 7050 MFF •
Gryzor
Easy as a breeze
Contact:
Post by Gryzor » Mon Oct 22, 2018 12:16 am
Huh, that's nice! Won't v2 update to v3? Do we have to manually install it?
QNAP TS-251-4G / 4.3.2.0026
Toxic17
Ask me anything
Contact:
Post by Toxic17 » Mon Oct 22, 2018 12:20 am
Gryzor wrote:Huh, that's nice! Won't v2 update to v3? Do we have to manually install it?
because its beta/testing then no it wont update at yet.
config is in a different location, : /share/SONARR3_CONFIG as stated in OP
Regards Simon
QTS 4.x User Guidex
Gryzor
Easy as a breeze
Contact:
Post by Gryzor » Mon Oct 22, 2018 12:21 am
Well yes, I got that, my question was just that - will v2 update to v3 when it reaches beta/stable or not :)
QNAP_Stephane
Experience counts
Post by QNAP_Stephane » Mon Oct 22, 2018 1:06 am
regarding Sonarr forum
you can upgrade V2 to V3
simply move your file to the new location, and start Sonarr V3 (may be delete previous one created on first install within SONARR3_CONFIG)
Gryzor
Easy as a breeze
Contact:
Post by Gryzor » Mon Oct 22, 2018 1:50 am
I meant automatically, but I guess it will when the time comes!
Toxic17
Ask me anything
Contact:
Post by Toxic17 » Mon Oct 22, 2018 4:04 am
OK took the plunge. Backed up Sonarr2. downloaded zip file. uninstalled Sonarr2, installed Sonar3 and restored last backup. all works well so far. nice new layout!
Regards Simon
QTS 4.x User Guidex
Gryzor
Easy as a breeze
Contact:
Post by Gryzor » Mon Oct 22, 2018 2:14 pm
That's so good to know :) Thanks for sharing!
Layout seems nice indeed, more 'conventional' but more practical. Any other new stuff you noticed?
sloporc
Know my way around
Post by sloporc » Tue Oct 23, 2018 8:24 pm
Toxic17 wrote:OK took the plunge. Backed up Sonarr2. downloaded zip file. uninstalled Sonarr2, installed Sonar3 and restored last backup. all works well so far. nice new layout!
Successful behind Nginx reverse proxy:
- backed up Sonarr 2.0
- stopped Sonarr 2.0 (did not uninstall because I am a coward)
- installed Sonarr 3.0
- restored 2.0 backup into 3.0
working flawlessly as far as I can tell right now
Model: TVS-463
Firmware: QTS 4.3.3.0154
Storage: RAID 5, 4 x4TB HGST Deskstar HG0S03664
RAM: Crucial 16GB Kit (8GBx2) DDR3-1600 MT/s (PC3-12800)
Networking: Port trunking balance-tlb
Gryzor
Easy as a breeze
Contact:
Post by Gryzor » Tue Oct 23, 2018 8:27 pm
So you need to stop 2.0 from auto-starting and set v3 to auto-start, I guess? How is that done?
Toxic17
Ask me anything
Contact:
Post by Toxic17 » Wed Oct 24, 2018 3:27 pm
Stephane, I noticed a cosmetic issue with the folder and backups.
I have two folders here:
/share/CACHEDEV1_DATA/SONARR_CONFIG3
/share/CACHEDEV1_DATA/SONARR3_CONFIG
the first just has this folder in it, /share/CACHEDEV1_DATA/SONARR_CONFIG3/sonarr_backup
files: config.xml
sonarr.db
I think possibly maybe a type somewhere and this extra folder was added?
Regards Simon
QTS 4.x User Guidex
QNAP_Stephane
Experience counts
Post by QNAP_Stephane » Wed Oct 24, 2018 7:24 pm
indeed my BAD
exporting HOME and TMPDIR in wrong directory (typo error)
fixed my diff
QNAP_Stephane
Experience counts
Re: [ Sonarr 3 ] [ 3.0.0.267 ] Smart PVR for newsgroup and bittorrent users
Post by QNAP_Stephane » Wed Oct 24, 2018 7:44 pm
QNAP_Stephane wrote:Image
Download :
Notes :
dependency : Qmono
About :
What’s New
Some highlights:
New UI
Language Profiles
Series import
Toxic17
Ask me anything
Contact:
Post by Toxic17 » Thu Oct 25, 2018 2:44 pm
Thanks for the update. I can confirm backups now writing to correct location.
Regards Simon
QTS 4.x User Guidex
Return to “Community Apps”
