Let's Encrypt SSL Certificate Idiot's Guide
Post your questions about myQNAPcloud service here.
Tim1023
Post by Tim1023 » Mon Oct 29, 2018 11:16 pm
I'm just in the process of installing my first NAS and just wasted most of my weekend trying to get my own certificate via Let's Encrypt or SSL for Free (which generates certificates from Let's Encrypt). In the end it was dead simple, so I thought I'd write this for other beginners with an easy-to-find title.
It turns out that you don't need to faff around with external sites, SSH, cURL commands, and all of that other frightening-looking stuff. QNAP has kindly integrated everything into apps, but only one of them works!
I assume that you have managed to set up myqnapcloud and have the myqnapcloud app running on your NAS.
1. IGNORE Control Panel/System/Security/Certificate & Private Key as this seems to have a bug. This page can be used later to download your certificate should you need it.
2. Open the myqnapcloud app on your NAS
3. Click on SSL Certificate in the left panel
4. Under Let's Encrypt, hit the Download and Install button
5. Enter your myqnapcloud domain name <yourdomain>.myqnapcloud.com and your email address
6. Select Automatically Renew should you want. Probably best.
7. Click on confirm & wait a little
8. Enjoy all that SSL goodness!
I assume that the above should work in the vast majority of cases. :)
References to help Forum search: https://letsencrypt.org/, https://www.sslforfree.com/
TS-251B, QTS 4.3.5.0723 (2018/10/13), 2 x WD Red 4T SATA, UPS= Cyberpower VALUE600EILCD, NAS backup to external HD stored off-site
aloharaz
Re: Let's Encrypt SSL Certificate Idiot's Guide
Post by aloharaz » Wed Apr 17, 2019 6:47 am
nobody wants to use myqnapcloud **. I want to use my own fixed IP and domain name!!!
qnap.myowndomain.com for example.
Toxic17
Experience counts
Contact:
Post by Toxic17 » Wed Apr 17, 2019 3:28 pm
I suggest you use this then.
viewtopic.php?f=320&t=132911
Regards Simon
QNAP 4.3.x/4.2.x Manuals
QNAP Club Repository
NAS: TS-473-32GB QM2-2P QXG-10G1T 4.3.6.1040 • TVS-463-16GB 4.3.6.1040 QM2-2S10G1TB • TS-459 Pro 2GB 4.2.6 • TS-121 4.3.3.0998 • APC Back-UPS ES 700G •
QPKG's: TwonkyServer 8.51 • Apache73 • QSonarr 3.0.1.503 • QNBZGet 21.0 • phpMyAdmin 4.9.0.1 • Qmono 5.20.1.19 • McAfee 2.2.0 • Lychee 3.2.15 • HBS 3.0.190802 • LEgo v3.0.0
Network: VM Hub 3.0 <500/35> • UniFi USG Pro 4 • UniFi USW-16-150W • UniFi USW-8-60W • UniFi CloudKey Gen2+• UniFi G3-Flex • UAP AC Pro • UAP AC Lite • SLM2008 • Dell 7050 MFF •
terrytse
Post by terrytse » Fri Jun 14, 2019 3:40 pm
use Let's Encrypt SSL Certificate with own domain name
On Qnap
1. Enable Web Server with port 80. Control Panel --> Applications --> Web Server
2. Ensure Qnap System port is not using port 80. Control Panel --> System --> General Setting --> System Port is not port 80
On your router
3. create a port forward rule, forward external port 80 to internal port 80, server is your qnap
On you Browser
4. test web access to your qnap public ip or FQDN, http://your_qnap_ip:80
5. make sure it will not redirect to your Qnap admin login page
On Qnap
6. download and install Let's Encrypt SSL Cert, Control Panel --> System --> Security --> Certificate & Private Key, click "Replace Certificate" --> get from Let's Encrypt
7 . enter your own domain name qnap.myowndoamin.com and your email address
i am able to install Let's Encrypt SSL Cert by doing above.
** tested enable "force secure connection (HTTPS) only" under Control Panel --> System --> General Setting, seem it will break
SenseoHasser
Post by SenseoHasser » Wed Jul 03, 2019 5:16 am
Thanks for this guide!
Is there a way to auto-renew the certificate?
kirilly
Post by kirilly » Thu Jul 18, 2019 6:43 am
Hi, I've managed to trick Chrome SSL using local network address with Let's Encrypt certificate + editing hosts (making "https" icon NOT crossed out ie. certificate considered valid):
1.Followed "Let's Encrypt SSL Certificate Idiot's Guide" by using myqnapcloud (I have error by missing port 80 etc. with Control Panel --> Applications --> Web Server)
2.Added to hosts file:
192.168.1.2:443 my-id.myqnapcloud.com
(or whatever your local NAS IP and port is)
3.Followed the URL:
https://my-id.myqnapcloud.com:443
Hope this will help!
drock_in_nc
First post
Post by drock_in_nc » Sat Jul 27, 2019 6:42 am
I was getting the port 80 error. Turned out to be I had the checkbox to force only HTTPS connection checked on the webserver. Once I removed that setting I was able to redo my certificate and all my sub alt names.
goodelyfe
Know my way around
Post by goodelyfe » Mon Jul 29, 2019 4:09 am
if you are using this method, where are the certs placed?
Return to “myQNAPcloud service”
