How to equip and setup an 872XT...
Interested in our products? Post your questions here. Let us answer before you buy.
bokr71
Know my way around
Re: How to equip and setup an 872XT...
Post by bokr71 » Mon Dec 03, 2018 3:36 am
Hi Bob,
I know that the HP2915 is GigaBit switch which is why, if I were to go to 10GbE, I'd need to buy a 10GbE switch. This 10GbE switch would connect my QNAP and my Mac Pro, and I'd connect it the HP2915 as well, for the rest of my network.
If I understand you correct; as I am running macOS 10.14.2, I should be fine with putting the Sonnet Solo10G PCIe in my Sonnet Echo Express box, and that way have 10GbE Ethernet in my Mac Pro - even without upgrading my Echo Express box to TB3. TB2 is fast enough to handle the 10GbE speeds...
Apple: nMP 3.5GHz 6C/64GB/1TB/D700 - 2 x ATD - Echo Express 1TB Accelsior/2x500GB Sonnet Tempo - MBP 13" 4c i7/16GB/512GB - MBA 13" 2c i7/8GB/250GB - MB 12" 4c i7/16GB/512GB - MMI 6c i5/8GB/500GB - 2 x TC 3TB - iPhone Xs - iPad Mini - iPad Pro - 2 x HomePod - 42mm Apple Watch
Primary NAS: QNAP TVS-872XT 6x10TB + 2x512GB NVMe SSD. BackUp NAS: ReadyNAS Pioneer Pro 6x4TB
Network: 2 x HP2915 - LinkSys Velop AC6600
CiASpook
Know my way around
Post by CiASpook » Thu Dec 06, 2018 10:31 pm
To bad they didn't make a TVS-1272XT that would have been something that could have replaced my TVS-1282T3...
QNAP TVS-1282T3-i7-64G with 8x Seagate Ironwolf 14TB, 4x Samsung 860EVO 4TB, 2x Samsung 860EVO 2TB M.2, custom with Corsair H5 SF watercooling, Corsair SF450W PSU and Noctua NF-8A PWM 80mm fans. QTiering and RW Cache.
QNAPDanielFL
Know my way around
Post by QNAPDanielFL » Tue Dec 11, 2018 1:47 am
I think the TVS-872XT can replace your TVS-1282T3 since they have the same amount of 3.5" drive bays, and now that we have M.2 NVMe in the 872, there is no need for the 4 2.5" bays since NVMe is faster. And if you want more NVMe there is an open PCIe slot on the 872 so you could have up to 6 NVMe SSDs if you wanted.
bokr71
Know my way around
Post by bokr71 » Tue Dec 11, 2018 2:13 am
The TVS-872XT will certainly be faster than the TVS-1282T3, because of the upgraded CPU, RAM, and the native NVMe SSDs.
HiTach
Post by HiTach » Sat Feb 16, 2019 7:32 am
To Bokr71 the OP:
Did you find the SSD cache on the 872XT makes a big or even a noticeable difference for you in photography applications or elsewhere?
You wrote "- 2 x Samsung 970 Pro M.2 NVMe, 512GB - for caching, Raid1 for read/write cache"
As I understand RAID1 to be mirroring primarily for redundancy, wouldn't RAID 0 maximize R/W cache performance (2x) and cache size (2x) with no redundancy required (the RAID6 HDD data is already well protected with 2 spare drives.)
I saw Trexx also has RAID1 on his SSDs, but he uses Qtier which as I understand moves (not caches) the most frequently used data which is no longer present on the HDD portion.
Happy to be corrected, I'm still understanding and planning my 872XT configuration.
bokr71
Know my way around
Post by bokr71 » Sat Feb 16, 2019 8:27 am
I do not think you have control over the Raid setup on the drives used for caching (but I could be wrong). I know the support docs on caching say that if you only have one SSD for caching it'll only be possible to have read caching. If you have two SSDs, they'll be in Raid1, and you will have read and write caching. That's OK, as the SSDs in the 872XT are NVMe SSDs, and even in Raid1, they're much faster than the interface.
And yes, I did see a marked improvement when I added the NVMe caching. My photography workflow is to put all RAW files on my NAS, in folders named for the job (for paid photoshoots), or the location/month (for private photos). Then I scan the folders using LightRoom Classic, and the library references the files on the NAS, though the libraries are stored on the Master drive on my Mac Pro. I then edit in LR, or in PhotoShop if needed. The same goes for videos, and all my add-in tools are for Adobe CS. Without the caching, LR or PS could sometimes feel sluggish, especially when adding several layers, photo stitching, or working with multiple photo stacking or HDR. With caching that is not so. It is as fast as if the RAW files were on the Master drive. Also, when dumping a photoshoot from my TB Lexar XQD card reader, it is much much faster, especially when downloading 100GB of files:) I want to try and setup an iSCSI target drive, and store my LR libraries on the NAS. That way I can access the same libraries from my Mac Pro and my MacBook Pro. I just haven't gotten around to trying that out yet.
As for seeing the effect in other applications, you bet I see it when moving media files to the NAS, and when accessing files in general. Most, if not all, my big files usage is for photography though...
bokr71
Know my way around
Post by bokr71 » Sun Feb 17, 2019 4:27 am
I tried creating an iSCSI target on the NAS, and connecting to it from my Macs. It works fine, but it is much too slow to use for LR libraries...
Return to “Presales”
