809Pro - RAID decided to "Unmount" randomly (How to Fix?)
CaptainCanuck
Re: 809Pro - RAID decided to "Unmount" randomly (How to Fix?)
Post by CaptainCanuck » Fri Jan 11, 2019 7:39 am
Thisisnotmyname wrote:
Fri Jan 11, 2019 12:14 am
I don't know what all specifically you previously did, I guess it's possible you don't have a filesystem anymore. What does...
blkid /dev/md0
give you? is there an ext[2|3|4] type on that device? If there's an ext filesystem there then I guess I'd fsck it...
fsck /dev/md0
Hi Thisisnotmyname,
If I enter/run:
blkid /dev/md0
The result is... nothing / nada / zilch... ? All it does is send me back to the beginning: " [~] # "
Was I supposed to run something else first, after launching putty and connecting to the QNAP, before your commands (above) ?
What did you mean by: "...is there an ext[2|3|4] type on that device?" ?
Thanks again very much!
CaptainCanuck
OneCD
Ask me anything
Post by OneCD » Fri Jan 11, 2019 7:47 am
I don’t think this old unit will be running LVM. ;)
production NAS: TS-569 Pro with Debian 9.9 'Stretch' (power on/off times are < 1 minute)
backup NAS: TS-559 Pro+ with QTS 4.2.6 #20190921
one.cd.only@gmail.com
Image Image Image Image
Thisisnotmyname
Easy as a breeze
Post by Thisisnotmyname » Fri Jan 11, 2019 8:00 am
blkid /dev/md0
fsck /dev/md0
Hi Thisisnotmyname,
If I enter/run:
blkid /dev/md0
CaptainCanuck
what happens if you run blkid without any arguments?
Thisisnotmyname
Easy as a breeze
Post by Thisisnotmyname » Fri Jan 11, 2019 8:01 am
really? how old is this thing?
OneCD
Ask me anything
Post by OneCD » Fri Jan 11, 2019 8:11 am
These were announced about 10 years ago: https://hothardware.com/news/qnap-bring ... nterprises
CaptainCanuck
Post by CaptainCanuck » Fri Jan 11, 2019 9:36 am
Hi OneCD,
I could not tell you if it was running LVM... that's Greek to me! :)
Any way for me to know, which may be hard since this isn't working right now and I don't know what LVM is! :D
Thanks, cheers!
CaptainCanuck
CaptainCanuck
Post by CaptainCanuck » Fri Jan 11, 2019 9:39 am
Oh Oh... now you're "dating" me... yes I am a relic and a noob at the same time!
My head is not firmly up my a@s, but I am definitely lost in the woods when it comes to this stuff! lol ;) Good at following directions, buuuut... no real idea what I'm doing.
Thanks, cheers!
CaptainCanuck
Thisisnotmyname
Easy as a breeze
Post by Thisisnotmyname » Fri Jan 11, 2019 10:03 am
what did blkid without any arguments return?
CaptainCanuck
Post by CaptainCanuck » Fri Jan 11, 2019 11:28 am
Hi Thisisnotmyname,
When entering:
blkid
The results were:
/dev/sdx1: UUID="d020c7e7-6fa6-40e5-9a12-1f336ba99cd6" TYPE="ext2"
/dev/sdx2: UUID="f5cc1847-b1e7-4f92-baa0-6476310118d5" TYPE="ext2"
/dev/sdx3: UUID="50533813-c010-4300-914a-43e754681583" TYPE="ext2"
/dev/sdx5: UUID="0e0741ff-97bf-45e6-8120-a044674364cb" TYPE="ext2"
/dev/sdx6: UUID="500939d8-97aa-4761-a659-3913c6e927ff" TYPE="ext2"
/dev/sdd1: UUID="5ebea00e-7ffd-d970-b3c0-36f1f5cfdce5" TYPE="mdraid"
/dev/sdd2: UUID="4b757026-4e54-1e57-ca0d-c15ffae9225a" TYPE="mdraid"
/dev/sdd4: UUID="98b89c41-f806-57ec-b6e3-050a0708f1a4" TYPE="mdraid"
/dev/sdc1: UUID="5ebea00e-7ffd-d970-b3c0-36f1f5cfdce5" TYPE="mdraid"
/dev/sdc2: UUID="4b757026-4e54-1e57-ca0d-c15ffae9225a" TYPE="mdraid"
/dev/sdc4: UUID="98b89c41-f806-57ec-b6e3-050a0708f1a4" TYPE="mdraid"
/dev/sdb1: UUID="5ebea00e-7ffd-d970-b3c0-36f1f5cfdce5" TYPE="mdraid"
/dev/sdb2: UUID="4b757026-4e54-1e57-ca0d-c15ffae9225a" TYPE="mdraid"
/dev/sdb3: UUID="4e3f2593-07db-4688-8c96-7afef8c7761e" TYPE="ext4"
/dev/sdb4: UUID="98b89c41-f806-57ec-b6e3-050a0708f1a4" TYPE="mdraid"
/dev/sda1: UUID="5ebea00e-7ffd-d970-b3c0-36f1f5cfdce5" TYPE="mdraid"
/dev/sda2: UUID="4b757026-4e54-1e57-ca0d-c15ffae9225a" TYPE="mdraid"
/dev/sda3: UUID="4e3f2593-07db-4688-8c96-7afef8c7761e" EXT_JOURNAL="00007800-000 0-0000-0000-000000005e3c" TYPE="ext4"
/dev/sdareal4: UUID="98b89c41-f806-57ec-b6e3-050a0708f1a4" TYPE="mdraid"
/dev/sdh1: UUID="5ebea00e-7ffd-d970-b3c0-36f1f5cfdce5" TYPE="mdraid"
/dev/sdh2: UUID="4b757026-4e54-1e57-ca0d-c15ffae9225a" TYPE="mdraid"
/dev/sdh4: UUID="98b89c41-f806-57ec-b6e3-050a0708f1a4" TYPE="mdraid"
/dev/sdg1: UUID="5ebea00e-7ffd-d970-b3c0-36f1f5cfdce5" TYPE="mdraid"
/dev/sdg2: UUID="4b757026-4e54-1e57-ca0d-c15ffae9225a" TYPE="mdraid"
/dev/sdg3: UUID="4e3f2593-07db-4688-8c96-7afef8c7761e" TYPE="ext4"
/dev/sdg4: UUID="98b89c41-f806-57ec-b6e3-050a0708f1a4" TYPE="mdraid"
/dev/sdf1: UUID="5ebea00e-7ffd-d970-b3c0-36f1f5cfdce5" TYPE="mdraid"
/dev/sdf2: UUID="4b757026-4e54-1e57-ca0d-c15ffae9225a" TYPE="mdraid"
/dev/sdf4: UUID="98b89c41-f806-57ec-b6e3-050a0708f1a4" TYPE="mdraid"
/dev/sde1: UUID="5ebea00e-7ffd-d970-b3c0-36f1f5cfdce5" TYPE="mdraid"
/dev/sde2: UUID="4b757026-4e54-1e57-ca0d-c15ffae9225a" TYPE="mdraid"
/dev/sde4: UUID="98b89c41-f806-57ec-b6e3-050a0708f1a4" TYPE="mdraid"
/dev/md9: UUID="0f43f648-6da6-45c8-9b7b-d49a86c92da8" TYPE="ext3"
/dev/sda4: UUID="e2a497fb-a267-4671-93c8-f2e7523be7ac" TYPE="ext3"
/dev/md8: UUID="f1fb7dd7-6efb-4001-952a-d5f42d89303d" TYPE="swap"
Is that helpful?
Question: When running blkid, should it return the same results each time it's ran ?
------------When I ran it a second time, the results appear different... as seen here:
/dev/sda3: UUID="4e3f2593-07db-4688-8c96-7afef8c7761e" EXT_JOURNAL="00007800-0000-0000-0000-000000005e3c" TYPE="ext4"
/dev/md8: TYPE="swap" UUID="f1fb7dd7-6efb-4001-952a-d5f42d89303d"
Again many thanks for sticking with me through this! Cheers!
CaptainCanuck
storageman
Experience counts
Post by storageman » Fri Jan 11, 2019 4:41 pm
No idea what is going on here. Not really sure what you did previously.
I guess cat1 models have no LVM relaunch
RAID is active but volume is not mounted which means problem is in filesystem.
You could try this:
/etc/init.d/services.sh stop
/etc/init.d/opentftp.sh stop
/etc/init.d/Qthttpd.sh stop
umount /dev/md0
e2fsck -f -v -C 0 /dev/md0
mount /dev/md0
reboot
P3R
Post by P3R » Fri Jan 11, 2019 5:14 pm
TS-809 is a CAT1 with no LVM!
The P3R rule of thumb:
All model numbers ending with a 9 (TS-XX9) was a CAT1 at release. Only TS-X69 (low-end Intel) and TS-X79 (high-end Intel) was later upgraded to CAT2 with new firmware but of course needed a reinitialization to use LVM.
Remember though that those TS-XX9-models weren't the only CAT1 models. We also have the TS-X10, TS-X12 and the really, really old TS-X01.
Thisisnotmyname
Easy as a breeze
Post by Thisisnotmyname » Fri Jan 11, 2019 10:38 pm
You could try this:
umount /dev/md0
mount /dev/md0
reboot
yep, time for fsck, if that doesn't work I think you've trashed your array.
CaptainCanuck
Post by CaptainCanuck » Sat Jan 12, 2019 1:17 am
Hi Storageman,
In my haste (stupidity), I quickly read some forum posts for a fix when the volume just randomly unmounted itself. I did the following trying to get it back up and mounted:
viewtopic.php?t=79123
and then this:
viewtopic.php?p=224731
... I did both of the above before my brain kicked in and I asked for help here in the forums. :oops:
Not sure if the above added to the mess of the random unmounting of the volume... thereby confusing the solution?...
--The QNAP was running along fine as always and then "BEEP"... it suddenly went into unmount status
You could try this:
umount /dev/md0
mount /dev/md0
reboot
When I run:
umount /dev/md0
mount /dev/md0
reboot
I receive this message:
[~] # /etc/init.d/services.sh stop
Default volume not found.
Stop qpkg service: Default volume not found.
Stop service: cloud3p.sh vpn_openvpn.sh vpn_pptp.sh ldap_server.sh antivirus.sh iso_mount.sh qbox.sh qsyncman.sh rsyslog.sh snmp lunportman.sh iscsitrgt.sh twonkymedia.sh init_iTune.sh ImRd.sh crond.sh nvrd.sh StartMediaService.sh bt_scheduler.sh btd.sh mysqld.sh recycled.sh Qthttpd.sh atalk.sh nfs ftp.sh smb.sh versiond.sh .
[~] # /etc/init.d/opentftp.sh stop
[~] # /etc/init.d/Qthttpd.sh stop
Shutting down Qthttpd services: OK.
[~] # umount /dev/md0
umount: /dev/md0: not mounted
[~] # e2fsck -f -v -C 0 /dev/md0
e2fsck 1.41.4 (27-Jan-2009)
e2fsck: Invalid argument while trying to open /dev/md0
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
[~] # mount /dev/md0
mount: can't find /dev/md0 in /etc/fstab or /etc/mtab
[~] # reboot
Soooo... I see what it says, but will wait for direction or confirmation of the correct argument(s) so I don't mess anything up worse! :)
Many thanks, cheers!
CaptainCanuck
CaptainCanuck
Post by CaptainCanuck » Sat Jan 12, 2019 1:19 am
Hi P3R,
Thank you for the details!
Thanks!
CaptainCanuck
CaptainCanuck
Post by CaptainCanuck » Sat Jan 12, 2019 1:20 am
You could try this:
umount /dev/md0
mount /dev/md0
reboot
Hi Thisisnotmyname,
Ok, I will wait for confirmation after my post above of the results so I don't mess anything up further!
CaptainCanuck
