QVR Center
jasontodhunter
QVR Center
Post by jasontodhunter » Tue Aug 13, 2019 2:25 am
Hi im using QVR centre to connect to both qvrpros and Viostors. All units are running latest firmware and apps but some units appear to connect but are then not available. You can see the connection made in the NVR connection logs. Tried setting up QVR Center on another unit to use that as the gateway and some of the other units will connect but not others. One unit can be seen on one center but not on the other. When connections are made it works really well.
andersoncheng
Getting the hang of things
Contact:
Re: QVR Center
Post by andersoncheng » Fri Aug 23, 2019 2:06 pm
May need more information like QVR Pro & QVR Center version, and which model you used /?
