seeking ARM CPU owners! Any QNAP firmware!
OneCD
Re: seeking ARM CPU owners! Any QNAP firmware!
Post by OneCD »
Model list in the OP has been refreshed, added a few new ones, and removed the completed models. :)
EOL dates are now recorded in the spreadsheet attached to the OP. Models will automatically highlight in red when that date arrives.
kop33
Post by kop33 »
TS-112P
none
MARVELL_6281
armv5tel
OneCD
Post by OneCD »
Hi and welcome to the forum. :)
kop33 wrote: Mon Jan 18, 2021 1:29 am TS-112P
none
MARVELL_6281
armv5tel
There's something odd about the x12P range. QNAP specs say these NAS have a 6282 CPU, but we've now had 2 reports that the QTS platform is revealed as 'MARVELL_6281'. Maybe QNAP are using 'MARVELL_6281' on NAS with either 6281 or 6282 CPUs? :'
Can you also please run the following command and post the result back here?
cat /proc/cpuinfo
L3rd
Know my way around
Post by L3rd »
TS-212P
[~] # cat /proc/cpuinfo
Processor name  : Feroceon 88F6282 rev 1 (v5l) @ 1.6 GHz
BogoMIPS        : 1587.60
Features        : swp half thumb fastmult edsp
CPU implementer : 0x56
CPU architecture: 5TE
CPU variant     : 0x2
CPU part        : 0x131
CPU revision    : 1
Hardware        : Feroceon-KW ARM
Revision        : 0000
Serial          : 0000000000000000
[~] # getcfg MISC DISPLAY_NAME -d none -f /etc/platform.conf; getcfg "" Platform -d none -f /etc/platform.conf; uname -m
none
MARVELL_6281
armv5tel
NAS:
QNAP TVS-682 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .FW: 4.5.2.xxxx
QNAP TS-351 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .FW: 4.5.2.xxxx
QNAP TS-509 Pro . . [Xeon L5408(SLBBT)] . . . . . . . . . . . . . . . FW: 4.2.6 Build 20200821 (2020-09-02) (TS-809 Pro)
QNAP TS-212P . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . FW: 4.3.3.1432
QNAP TS-109 Pro . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . FW: 3.3.3 build 1003 (2014-10-09)
QNAP QG-103N QGenie . . . . . . . . . . . . . . . . . . . . . . . . . . . . . FW: 3.2.3 (2018/08/10)
OneCD
Post by OneCD »
L3rd wrote: Fri Mar 12, 2021 4:52 am TS-212P
BogoMIPS        : 1587.60
CPU variant     : 0x2
CPU part        : 0x131
CPU revision    : 1
Revision        : 0000
none
MARVELL_6281
armv5tel
Excellent! Thank you. :D
L3rd
Know my way around
Post by L3rd »
Do you need the same also from the other models that I own?
OneCD wrote: Fri Mar 12, 2021 4:55 am
BogoMIPS        : 1587.60
CPU variant     : 0x2
CPU part        : 0x131
CPU revision    : 1
Revision        : 0000
none
MARVELL_6281
armv5tel
NAS:
OneCD
Post by OneCD »
L3rd wrote: Fri Mar 12, 2021 4:58 am Do you need the same also from the other models that I own?
Actually, to fill-in a blank space on the spreadsheet, are you able to please post the platform info for your TS-109 Pro?
L3rd
Know my way around
Post by L3rd »
TS-109 Pro
none
none
armv5tejl
cat /proc/cpuinfo
Processor       : ARM926EJ-Sid(wb) rev 0 (v5l)
BogoMIPS        : 332.59
CPU implementer : 0x41
CPU architecture: 5TEJ
CPU variant     : 0x0
CPU part        : 0x926
CPU revision    : 0
Cache type      : write-back
Cache clean     : cp15 c7 ops
Cache lockdown  : format C
Cache format    : Harvard
I size          : 32768
I assoc         : 1
I line length   : 32
I sets          : 1024
D size          : 32768
D assoc         : 1
D line length   : 32
D sets          : 1024
Hardware        : MV-88fxx81
Revision        : 0000
NAS:
OneCD
Post by OneCD »
L3rd wrote: Fri Apr 02, 2021 5:28 am TS-109 Pro
Thanks mate. :)
OneCD
Post by OneCD »
Decided to re-add the EOL units to the OP as it's possible someone out there is still using them. ;)
mud1984
First post
Post by mud1984 »
TS-419P II
none
MARVELL_6281
armv5tel
cat /proc/cpuinfo
Processor name  : Feroceon 88F6282 rev 1 (v5l) @ 2 GHz
BogoMIPS        : 1980.82
CPU variant     : 0x2
CPU part        : 0x131
CPU revision    : 1
Revision        : 0000
OneCD
Post by OneCD »
Thanks and welcome to the forum. :)
kop33
Post by kop33 »
Sorry, no noticed your request until today.
TS-112P
BogoMIPS        : 1587.60
CPU variant     : 0x2
CPU part        : 0x131
CPU revision    : 1
Revision        : 0000
OneCD wrote: Mon Jan 18, 2021 3:11 am There's something odd about the x12P range. QNAP specs say these NAS have a 6282 CPU, but we've now had 2 reports that the QTS platform is revealed as 'MARVELL_6281'. Maybe QNAP are using 'MARVELL_6281' on NAS with either 6281 or 6282 CPUs? :'
cat /proc/cpuinfo
OneCD
Post by OneCD »
kop33 wrote: Sat May 22, 2021 11:28 pm Sorry, no noticed your request until today.
TS-112P
Thanks mate. Image
barman26
First post
Post by barman26 »
Locked
Return to “Users' Corner”
