Lost Plex App in Menu/Desktop
Plex allows you to aggregate all your personal media and access it anywhere you go. Enjoy your own media on all your devices with the Plex Media Server.
Denrael
Post by Denrael » Fri Apr 24, 2020 12:32 am
I have Plex installed on my QNAP TS-563. The only place I can see it however is to go into AppCenter and open it from there. It does not show up as a shortcut on the desktop or in the Hamburger Menu in the upper left for any user including admin. I do have it set to display on "Every User's Menu" when I look at the drop down via AppCenter. Ideas on how I can get it back in my hamburger menu of installed apps?
Model:TS-563 | Firmware 4.3.2
Acquired: 2017/03/06
Network : 2x 1.0GbE, non-trunking
Drive Configuration: 4 x (WD Red) 3.0TB Raid 6
Coming From: Drobo 5n
dolbyman
Re: Lost Plex App in Menu/Desktop
Post by dolbyman » Fri Apr 24, 2020 1:14 am
maybe a complete reinstall ? (of Plex not the NAS)
is plex that important as a menu point ?
users should use a plex player (web or device) , why would they use the QNAP web interface to click on it ?
holger_kuehn
Know my way around
Post by holger_kuehn » Sat Apr 25, 2020 6:10 pm
There should be a menu point "add shortcut to desktop".
Gesendet von meinem HTC One M9 mit Tapatalk
NAS (production): TS-1635AX FW: 4.5.1.1540 build 20210107
NAS (backup): TS-1635AX FW: 4.5.1.1540 build 20210107
Data (QTier): [RAID-6] 4 x 500GB Samsung Evo 860 Sata
Data (HDD): [RAID-6] 5 x 14TB WD Red
RAM: 8 GB (QNAP shipped)
UPS: CyberPower CP900EPFCLCD
NAS: TS-873U-RP FW: 4.5.1.1495 build 20201123
BACKUP: 4TB Synology DS214 FW: DSM 6.2.3.25426 Update 2
dolbyman
Post by dolbyman » Sat Apr 25, 2020 9:52 pm
OP said plex is not in the "hamburger menu"...that is where the desktop shortcut could be created
aesculus
Easy as a breeze
Post by aesculus » Sun Dec 06, 2020 2:06 am
I found that when installing Plex MS the icon in the desktop is random. I did find it in the hamburger menu under applications.
So to get it also on the desktop just drag the application one onto the desktop and it will appear in both places.
Chris
Return to “Plex Media Server”
