[ TransmissionBT v3 ] [ 3.0.0.2 ] Transmission is a fast, easy, and free BitTorrent client.
- peelos
- Been there, done that
Re: [ TransmissionBT v3 ] [ 3.0.0.2 ] Transmission is a fast, easy, and free BitTorrent client.
I had the same problem when manually specifying a port and forwarding on firewall, the transmission client port check gave an error but the port was indeed open and client was recognised to be accepting connections by the tracker.
I suspect it is this issue : https://github.com/transmission/transmi ... ssues/1190
NAS: TVS-1282-i7K-40G / 4 x 500GB SSD 2.5" / 2 x 500GB M.2 SSD / 8 x 12TB WD Whites 3.5" / Corsair H5-SF Watercooling / 3 x 80mm PWM Noctua fans / Corsair 600W PSU / Asus Turbo GTX 1060 6GB GPU
Software: Plex Media Server / QTransmission / Sonarr / Radarr / Bazarr / Jackett / QMono / Tautulli / OpenHAB / Resilio Sync / QPython / QJDK 8 / NetData / Qapache / SortMyQPKGs
pfSense Firewall / OpenVPN Server: QOTOM Fanless Mini PC / Core i5 / 8GB RAM / 128GB SSD / 4 Gigabit NICs / AES-NI
Wireless Routers: 2 x Netgear AC1900 R7000 Nighthawk / Advanced Tomato Firmware
Thanks for everyone's assistance, I actually installed 2.94 and it didn't have any issues so I'm using that.
Hi Stephane, i installed v3.0.0.2 but now my torrents aren't in qtransmission 3, they're still in v2.94
why did you use another folder than the default one? this makes such trouble.
what do i do now?
what do i do now?
Qnap TS-212 QTS 4.3... , 2x3TB WD Red.
Windows 10 x64
Windows 10 x64
I have the same problem. Torrents are still in v2.94. What is the procedure to transfer them to 3.0.0.2?
- Xmantium
think theres a fix here v2.94 to v3 - viewtopic.php?f=221&t=150693&p=763677&h ... on#p763677
- spaxz
I'm seeing the same issue as some on Transmission 3.0.2 and the port blocking but with a twist. I had 2.9.4 installed and removed it. Installed 3.0.2. I am getting the port not open error in Transmission but I have verified the port is forwarded and open to the internet. I also disabled IPv6 with no results.
The issue I have is that I can connect to some tracker websites but others will not connect. Can anyone offer any advice on what the issue is or what I can try to fix this?
- peelos
Personally staying with 2.94 for the time being, rock solid with no issues for years.
- jaysona
- Easy as a breeze
Same here, I am using 2.94 as well and based on the changelog there are no benefits to upgrading to 3.x
H/W: TS-219 Pro / TS-269 Pro / TS-253 Pro (8Gig) / TS-509 Pro x2 / TS-569 Pro
H/W: TS-670 Pro (i7-3770S 16Gig) x2 / TS-853 Pro (8Gig) / TVS-871 Pro (i7-4790S 16Gig)
Router1: Asus RT-AC86U - Asuswrt-Merlin - 384.19
Router2: Asus RT-AC68U - DD-WRT v3.0-r39960M kongac
Router3: Linksys WRT1900AC - DD-WRT v3.0-r43028 std
Router4: Asus RT-AC66U - FreshTomato v2020.7
So I installed this, but can't get it to work again. When launching the app it gives me connection refused. And I have trouble finding a guide which tells me how to use SSH to setup transmission.
Is there something I'm overlooking?
I'm also having the same issue. I have all my torrents migrated from 2.94 to 3.0.0.2 but for some reason after the latest Qnap update I keep getting connection refused and it is driving me crazy.
I found a fix for me and it might work for you. My Qnap is running a intel cpu and I was running the x86 version of Transmission but after installing the x64 it worked.
- Skeptical.me
- Easy as a breeze
How do I change the Blackhole Dir in Transmission 3.0.0.2
QNAP TS-253Be 2 x WD Red 6TB RAID1, & 1 x WD Ext. 6TB, QTS: 4.5.1.1495
Plex, Radar, Sonarr, Lidarr, NZBGet, NZBHydra 2, Container Station, QBitTorrent, Jackett
