Syslog still active even if deactivated in QTS
Discussion about hard drive spin down (standby) feature of NAS.
manto235
Post by manto235 » Tue Aug 11, 2020 2:12 pm
I was trying to find the cause of the spin-up of my disks by using the blkdev monitor script and I saw that I have entries related to rsyslogd even though I deactivated Syslog in Control Panel > Applications > Syslog Server.
"rsyslogd(9756): dirtied inode 13427 (kmsg) on md9"
If I do "ps | grep syslog" and kill the running process, my NAS stays in a standby state.
I have a TS-230 running version 4.4.3.1381.
Did any of you encounter the same issue?
Is there another menu to deactive Syslog?
Thank you
TS-230 | FW 4.4.3.1400 | 2 x 4 TB Seagate IronWolf (ST4000VN008) - RAID 1
dolbyman
Re: Syslog still active even if deactivated in QTS
Post by dolbyman » Tue Aug 11, 2020 8:59 pm
could be a bug
report it to qnap via ticket
manto235
Post by manto235 » Tue Aug 11, 2020 10:56 pm
Hi dolbyman,
I opened a ticket and someone from the support connected remotely to the NAS.
He hasn't seen any new entries in the standby test he ran while enabling/disabling Syslog.
I saw there are 2 places where Syslog is mentioned in the QTS options:
- Control Panel > Applications > Syslog Server
- Control Panel > System > System logs > Syslog Client Management
Both are deactivated.
However, there is always this process running:
27391 admin 1944 S /usr/sbin/rsyslogd -f /etc/rsyslog_only_klog.conf -c4 -M /usr/local/lib/rsyslog/
manto235
Post by manto235 » Sun Aug 23, 2020 3:33 pm
A small update:
We performed some checks with QNAP support and even if the rsyslogd process is always running, it does not seem to forbid the system to enter standby mode.
I was running the blkdev script which made me see the rsyslogd entries but the script also forbids the NAS to enter in standby mode.
Return to “HDD Spin Down (HDD Standby)”
