[ Radarr .NET ] [ 3.0.0.4260 ] automatically downloading movies via Usenet and BitTorrent.
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
QNAP_Stephane
Experience counts
Post by QNAP_Stephane » Fri Aug 28, 2020 2:45 pm
Source : www.radarr.net
Download : x64, arm64, armv7 (x41) not compatible TS-531P
https://www.qnapclub.eu/fr/qpkg/1007
Dependency : Apache74 https://www.qnapclub.eu/fr/qpkg/835
The project was inspired by other Usenet/BitTorrent movie downloaders such as CouchPotato.
Radarr is currently undergoing rapid development and pull requests are actively added into the repository.
Features
Current Features
Adding new movies with lots of information, such as trailers, ratings, etc.
Support for major platforms: Windows, Linux, macOS, Raspberry Pi, etc.
Can watch for better quality of the movies you have and do an automatic upgrade. eg. from DVD to Blu-Ray
Automatic failed download handling will try another release if one fails
Manual search so you can pick any release or to see why a release was not downloaded automatically
Full integration with SABnzbd and NZBGet
Automatically searching for releases as well as RSS Sync
Automatically importing downloaded movies
Recognizing Special Editions, Director's Cut, etc.
Identifying releases with hardcoded subs
All indexers supported by Sonarr also supported
New PassThePopcorn Indexer
QBittorrent, Deluge, rTorrent, Transmission and uTorrent download client (Other clients are coming)
New TorrentPotato Indexer
Torznab Indexer now supports Movies (Works well with Jackett)
Scanning PreDB to know when a new release is available
Importing movies from various online sources, such as IMDb Watchlists (A complete list can be found here)
Full integration with Kodi, Plex (notification, library update)
And a beautiful UI
Importing Metadata such as trailers or subtitles
Adding metadata such as posters and information for Kodi and others to use
Advanced customization for profiles, such that Radarr will always download the copy you want
Last edited by QNAP_Stephane on Sat Dec 12, 2020 6:00 pm, edited 4 times in total.
QnapClub AppCenter - https://www.qnapclub.eu
Ramonster
Re: [ Radarr .NET ] [ 3.0.0.3502 ] automatically downloading movies via Usenet and BitTorrent.
Post by Ramonster » Mon Aug 31, 2020 9:57 pm
A few issues with the install on TS-653D with latest FW, but nothing major and easily fixed, once done all working 100% - downloaded some stuff no issues whatsoever. Well done and thanks very much.
Had to add the following to the Radarr.runtimeconfig.json in the "runtimeOptions" section to avoid critical exception with culture/localization:
"configProperties":{
"System.Globalization.Invariant": true
Also had to install the following package to avoid libmedialibrary.so startup errors:
https://www.qnapclub.eu/en/qpkg/712
I am not sure the application restart from the web interface is working, doesn't seem to restart itself.
doubter13
Post by doubter13 » Thu Oct 01, 2020 3:19 pm
hi, Radar .NET just told me "Branch 'aphrodite' has been merged, switch to 'nightly' for further V3 development"
next to the message is a link with some explanation:
Branch is for a previous version
The update branch setup in Settings/General is for a previous version of Radarr, therefore the instance will not see correct update information in the System/Updates feed and may not receive new updates when released"
but I don't have an option to change this under settings/general
any plans to release an updated Qnap package with a) the option, or b) that is already set to "nightly" branch?
oh and btw I used the internal updater to get to version. 3.0.0.3790, while here and on qnapclub.eu the last version is 3.0.0.3502
QNAP TS-470 Pro [4.3.6.1333 (2020/06/08)]
- disks: 4xWD30EFRX-68EUZN0 3TB, ext3
- SSD: 2xSAMSUNG SSD 850 EVO 1000GB
Maggus
Post by Maggus » Sat Oct 10, 2020 4:01 am
You forgot to expanse the settings... press the "show advance" button...
doubter13
Re: [ Radarr .NET ] [ 3.0.0.3790 ] automatically downloading movies via Usenet and BitTorrent.
Post by doubter13 » Sat Oct 10, 2020 4:58 am
Ahh , stupid me :roll:
Thank you !
delirium
Post by delirium » Sun Oct 18, 2020 12:16 am
Importing from the IMDB list doesn't work.
Also, the "Lists" tab under "Movies" (so the one just below "Discover") is missing.
Edit: Correction on the IMDB list auto import not working - i noticed that the import ask had hung. Restarting the Radarr from the app center didn't work so I restarted the whole device. It has now imported the movies.
spikemixture
Been there, done that
Post by spikemixture » Tue Oct 27, 2020 5:42 pm
Will somebody please point me to the apache 74 needed for Radarr 3.
Qnap TS-1277 1700 (48gb RAM) 6x8TB WD White, 2x8TB WD Red - Raid5, 2x M.2 Crucial 1TB (Raid 1 VM),
2x SSD 860 EVO 500gb (Raid1 QTS), 2x SSD 860 EVO 250GB (Cache), 2x M.2 PCIe 970 500gb NVME (Raid1 Plex and Emby server)
GTX 1050 TI
Qnap TVS-1282 i7 (32GB RAM) 8x10TB WD White - Raid 6, 2x M.2 Crucial 500gb (Raid1 VM),
2x SSD EVO 500gb (Raid1 QTS), 2x SSD EVO 250gb (Raid1 Cache), 2x M.2 PCIe Intel 512GB NVME (Raid1-Servers)
Synology -1817+ - 2x10,2x8,2x6 (Ironwolf) 2x6 (WD Red) - SHR
Drobo 5n - 3x2TB WD Green, 2x3TB WD Red - Drobo Raid
ProBox 8 Bay USB3 - 8x4TB Seagate - JBOD
All software is updated asap.
I give my opinion from my experience i.e. I have (or had) that piece of equipment/software and used it! :roll:
QNAP_Stephane
Experience counts
Post by QNAP_Stephane » Tue Nov 17, 2020 7:58 pm
doubter13
Re: [ Radarr .NET ] [ 3.0.0.4092 ] automatically downloading movies via Usenet and BitTorrent.
Post by doubter13 » Wed Nov 25, 2020 5:17 am
I can’t download that package anymore due to a revoked Certificate
Are there alternative sources?
OneCD
Ask me anything
Post by OneCD » Wed Nov 25, 2020 5:32 am
I get the same thing when attempting downloads from the Qnapclub website using Firefox. My other browsers were OK. Have you tried a different browser?
doubter13
Post by doubter13 » Thu Nov 26, 2020 5:12 am
Tried Chrome and safari
Also get an erteilt when my qnap tried to update the app
OneCD
Ask me anything
Post by OneCD » Thu Nov 26, 2020 5:21 am
Works fine in Chrome 87 & Chromium 83 on Debian Buster, but I've just tried Safari 14.0.1 on Big Sur, and got the same "certificate revoked" message as FireFox. :(
doubter13
Post by doubter13 » Sat Nov 28, 2020 9:10 pm
funny enough i get the same error on my iphone with safari and chrome, but can open the file with firefox on iphone.... not that this would help me in any way....
i found a way to ignore the warning, but only using a windows VM with internet explorer.
if someone has a way to ignore the warning for safari, chrome or firefox on mac i would very much appreciate it.
townskeith6
Post by townskeith6 » Sun Dec 06, 2020 8:14 am
A workaround for chrome, after the page loads with the error type thisisunsafe . The page should load correctly after that.
amkrafie
First post
Post by amkrafie » Sat Dec 12, 2020 4:58 pm
installed this and when loading the page I just get a message
"message": "NotFound"
Anyone have any ideas ?
Return to “Community Apps”
