Hybrid Backup RTRR impossibly slow
Backup, Restore, Netbak Replicator, Cloud Storage Services
pekako
Re: Hybrid Backup RTRR impossibly slow
Post by pekako » Sat Mar 06, 2021 3:23 am
I have the same problem.
The last backup ( 2 months ago ) was normal - 90 MB/sec on 1Gb ethernet between 2 qnap ( TS-251+ and backup to TS-231-P2 with QTS 4.5.1.1540 build 20210107 on both machines)
Last month i installed the update QTS 4.5.2.1566 Build 20210202 - i don't look to performance.
Now, 5 days ago i started a new backup and i see only 15-17MB/sec - very slow.
Today i updated both machines to the lates level 4.5.2.1594- the same problem - backup and restore only with 15-17MB/sec.
With putty and rsync between the machines i see up to 100MB/sec.
My envireonment is unchanged since one year.
wk170
Post by wk170 » Sun Mar 07, 2021 2:44 am
Just installed the new HBS 3 version (15.1.0225) which was released yesterday.
Just ran my one-way sync job, unfortunately it is still very very slow, and unusable.
Looks like the issue still has not been fixed.
TS-453A + TR-004
TS-659 Pro II
pekako
Post by pekako » Wed Mar 10, 2021 3:19 am
my problem, reported 4 days ago, is resolved.
now i see 90 ...100Mbyte/sec.
Resolution: on source machine ,i disabled "use ssl connection" in HBS3 --> storage places --> remote NAS --> edit job profile.
After the change, speed test shows 100MByte/sec and the running job showes also 95... 105MByte/sec.
I'm happy.
tobi_bw
First post
Post by tobi_bw » Wed Mar 10, 2021 4:24 pm
I want to join in - I have this problem while syncing with HBS RTRR from my local QNAP to a USB3.1 connected external HDD on the sampe QNAP. So it is not some obscure network issue, it is literally the inability of a backup program to copy files at a decent speed. Indeed, stopping the job, changing the log file to maximum 1024 MB and restarting helps. What a shame.
autpgblds
Post by autpgblds » Thu Mar 11, 2021 10:28 am
I just don't get it. Simply spawning a shell and rsync takes like 7 minutes to copy 1.2gb.
HBS 3 doing a "sync" job takes ... well who knows, I killed it after 46min, at 1.2MB/s
Why TF cant they just write a gui for building cron files for rsync? Then parse logs and populate into the gui's alert system.
There are literally 1000's of these posts on the web about how slow this pile of garbage app is.
At the end of the day, the app should take no longer than a simply rsync does. But its on accord of 100x slower.
Amoebia
Easy as a breeze
Post by Amoebia » Sun Mar 14, 2021 5:17 pm
Same here... :roll:
4 * Seagate 3TB - Raid-10
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Sun Mar 14, 2021 7:27 pm
latest qts, latest hbs, ts-877
can someone explain what is going on with this >_>:
my settings are as follows
- one way rtrr sync from a ts-877 to a tl-d400s connected via special cable directly to each other
- ssl enabled
- check file contents enabled
- remove additional files at destination location enabled
- do not take a snapshot enabled
yes i expect with some of these settings it may be slow, but not to this extent. at least my observation of the file transfer speed seems rather slow.
I checked the internal speed is showing 150-300 MB/s read when doing the check file content if not mistaken so that at least doesn't seem to be the bottleneck. Something else is going on but i can't explain these results o-O;
*update
ran using the same settings but for ts-877 to a ts-653a, all updated to latest, but it seems fine :' hm
so basically in my example, the transfer to a ts-653a was way faster than a tl-d400s. i suspect there is a bug or something, cauz i can't explain the results :( I'll check the cable or something.
NAS
[Main Server] QNAP TS-877 w. 4tb [ 3x HGST Deskstar NAS & 1x WD RED NAS ] EXT4 Raid5 & 2 x m.2 SATA Samsung 850 Evo raid1 +16gb ddr4 Crucial+ QWA-AC2600 wireless+QXP PCIE
[Backup] QNAP TS-653A w. 5x 2TB Samsung F3 (HD203WI) EXT4 Raid5
[Backup] QNAP TL-D400S 2x 4TB WD Red Nas (WD40EFRX) 2x 4TB Seagate Ironwolf, Raid5
[^] QNAP TS-659 Pro II
[^] QNAP TS-253D
[^] QNAP TS-228
Network
Qotom Pfsense|100dl/50ul MBPS FTTH Internet | Win10, WC PC-Intel i7 920 Ivy bridge desktop (1x 512gb Samsung 850 Pro SSD + 1x 4tb HGST Ultrastar 7K4000)
Guides & articles
Marc J
Getting the hang of things
Post by Marc J » Tue Mar 30, 2021 7:33 am
Don't waste your time. I had two identical (new) external HDDs (USB3), tested with a 1Tb test file copied through File Station from NAS RAID to External HDD, swapping external disks, cables, and between front and rear USB3 ports on my TS-453D, and all gave the same results (approx 113MB/s). But when attempting any backup or sync job via HBS 3 it quickly slows to a crawl :(
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Tue Mar 30, 2021 7:50 am
not sure if i mentioned this, but i ran hbs in a few different scenarios
1. ts-877 to a tl-d400s
2. ts-877 to a ts-653a
3. ts-877 to a ts-509 pro
for 2 and 3, it seems to show the transfer speed as i normally would expect. but for 1, the transfer speeds looked awfully slow. i believe last time it worked just fine, but i don't know what changed either in hbs or qts, but it feels slower for some reason and hbs result looks slow at 1.5 MB/s transmission speed :'
i'll check again in a couple of months when i run my next backup to test again. i'll try reset the cables then.
NAS
[^] QNAP TS-253D
[^] QNAP TS-228
Network
Guides & articles
jlrx81
Post by jlrx81 » Mon Apr 05, 2021 4:45 am
Hello, we've been encountering a similar problem over the past two weeks.
We have a TS-EC880U,
Previously we've backed up 1.8TB to another volume on the device (before it is moved to external) and it takes 4 1/2 hours.
However over the last two weeks it is so slow as to never complete. It stuck at 23% with 8 days to go after several days, and now after getting to about 15% it drops to less than 10kbps transger rate.
Again, this is a volume on a local disk. I can copy files from it easily. It takes about 2 1/2 hours to copy a backup from the volume to an external drive. It should not be as slow as it's being now as to be completely unusable.
P3R
Post by P3R » Mon Apr 05, 2021 5:34 am
spikemixture
Been there, done that
Post by spikemixture » Thu Apr 08, 2021 10:38 am
To add to this discussion
I have 2 main back ups
1. Media ~30TB and mostly mp4
2. Data ~4tb - lots of small files.
I have tried SMB, FTP and RTRR from Qnap to Qnap AND Qnap to Synology.
All get the same results - Media (30TB)takes a few hours depending on changes.
Data (4TB) - extremely slow and takes about 15 hours using SMB , FTP and RTRR
The Data (4tb) job does not finish completely but appears near the end and gives an error message they tells me nothing.
To my non technical knowledge it appears to be trying to copy the whole 4TB everytime.(And not doing a very good job)
Qnap TS-1277 1700 (48gb RAM) 6x8TB WD White, 2x8TB WD Red - Raid5, 2x M.2 Crucial 1TB (Raid 1 VM),
2x SSD 860 EVO 500gb (Raid1 QTS), 2x SSD 860 EVO 250GB (Cache), 2x M.2 PCIe 970 500gb NVME (Raid1 Plex and Emby server)
GTX 1050 TI
Qnap TVS-1282 i7 (32GB RAM) 8x10TB WD White - Raid 6, 2x M.2 Crucial 500gb (Raid1 VM),
2x SSD EVO 500gb (Raid1 QTS), 2x SSD EVO 250gb (Raid1 Cache), 2x M.2 PCIe Intel 512GB NVME (Raid1-Servers)
Synology -1817+ - 2x10,2x8,2x6 (Ironwolf) 2x6 (WD Red) - SHR
Drobo 5n - 3x2TB WD Green, 2x3TB WD Red - Drobo Raid
ProBox 8 Bay USB3 - 8x4TB Seagate - JBOD
All software is updated asap.
I give my opinion from my experience i.e. I have (or had) that piece of equipment/software and used it! :roll:
P3R
Post by P3R » Sat Apr 17, 2021 12:56 am
What do you think about the HBS version 16.0 out now that is said to resolve the issue?
pekako
Post by pekako » Sat Apr 17, 2021 4:22 pm
- ssl enabled
*update
please try to disable ssl.
this helped me.
after the change i have 90MegaByte/sec
P3R
Post by P3R » Sat Apr 17, 2021 5:44 pm
- ssl enabled
Did you set it up as local or remote storage? Local would definitely be preferred and doing that I don't even understand how SSL could be enabled.
Return to “Backup & Restore”
