VM with pcie Wifi AX200
QNAP NAS solution for server virtualization and clustering/HA/FT
swr85
Post by swr85 » Thu Mar 18, 2021 4:22 am
I'm trying to connect a VM thought a virtual switch with the Pcie Wifi AX200 card
Wifi adaptor is available in the Physical Adapter but not in the Network Interface Card(Physical) selection ; it is not available?
Can you please help me?
swr85
Re: VM with pcie Wifi AX200
Post by swr85 » Fri Mar 19, 2021 3:28 am
Can someone help me?
dolbyman
Post by dolbyman » Fri Mar 19, 2021 10:55 am
probably a case for qnap support (ticket)...most forum users probably keep wifi far away from their nas units
swr85
Post by swr85 » Sat Mar 20, 2021 5:11 am
ok, I opened a ticket, let's see what will be the output
swr85
Post by swr85 » Sat Mar 27, 2021 1:41 am
I get the answer from support, Official Wifi 6 PCIE from QNAP is not supported to create a virtual switch. This is completely crazy
dolbyman
Post by dolbyman » Sat Mar 27, 2021 1:44 am
if you need to have a VM exclusively on Wifi, assign it to a physical NIC and use a Wifi bridge on that interface.
swr85
Post by swr85 » Tue May 04, 2021 6:31 pm
Hi dolbyman,
I turned around your answer and was not able to find out the solution.
I can't select the Wifi adaptor or Nic
any clue?
dolbyman
Post by dolbyman » Tue May 04, 2021 8:21 pm
so you bought a wifi bridge ? (wont be visible there)
Mandorr92
First post
Post by Mandorr92 » Thu Jun 10, 2021 3:19 am
Hi
It there a workaround on this?
I real don't care if it supported or not, using my Qnap WMs for lab any way.
dolbyman
Post by dolbyman » Thu Jun 10, 2021 3:28 am
Read the posts .. get a bridge
Return to “Server Virtualization & Clustering”
