New Plex will not auto scan library
Plex allows you to aggregate all your personal media and access it anywhere you go. Enjoy your own media on all your devices with the Plex Media Server.
bokr71
Easy as a breeze
Post by bokr71 » Sat Apr 10, 2021 7:25 am
I just started using Plex, and part of that was upgrading to the latest version of the software - Version 1.22.2.4282 - on my TVS-872XT.
I have a number of libraries, and I can watch/see/listen to the files from Plex on my iPad and my Mac.
One thing that I have noticed is that I cannot get the auto scan of libraries to work. I have the function selected, yet when I add files into folders from my Mac Pro (direct connected via SMB/10GbE), they do not show up in Plex until I manually trigger "Scan Library Files"...
Am I missing something, or is this supposed to work?
Apple: MP 3.3GHz 12c/160GB/2TB/Pro Vega II - nMP 3.5GHz 6C/64GB/1TB/D700 - 2 x ATD - Echo Express 1TB Accelsior/2x500GB Sonnet Tempo - MBP 13" 4c i7/16GB/512GB - MBA 13" 2c i7/8GB/250GB - MB 12" 4c i7/16GB/512GB - MMI 6c i5/8GB/500GB - 2 x TC 3TB - iPhone Xs - iPad Mini - iPad Pro - 2 x HomePod - 42mm Apple Watch
Primary NAS: QNAP TVS-872XT 6x10TB + 2x512GB NVMe SSD. BackUp NAS: ReadyNAS Pioneer Pro 6x4TB
Network: 2 x HP2915 - LinkSys Velop AC6600
dolbyman
Re: New Plex will not auto scan library
Post by dolbyman » Sat Apr 10, 2021 7:26 am
bokr71
Easy as a breeze
Post by bokr71 » Sat Apr 10, 2021 7:29 am
No - it will play/display new files, I just have to trigger the library scan manually. No issues except the auto scan not working.
holger_kuehn
Easy as a breeze
Post by holger_kuehn » Sat Apr 10, 2021 11:53 pm
Have you set an partial scan on your music / audio-file library? If so how large is it?
On large ones the partial scan scan could be blocking automatic updates as the number of monitored files is somewhat limited.
You could setup a refresh every couple of time to avoid that.
NAS (production): TS-1635AX FW: 4.5.3.1670 build 20210515
NAS (backup): TS-1635AX FW: 4.5.3.1697 build 20210611
Data (QTier): [RAID-6] 4 x 500GB Samsung Evo 860 Sata
Data (HDD): [RAID-6] 5 x 18TB Exos
RAM: 8 GB (QNAP shipped)
UPS: CyberPower CP900EPFCLCD
NAS: TS-873U-RP FW: 4.5.3.1670 build 20210515
BACKUP: 4TB Synology DS214 FW: DSM 6.2.4.25556
bokr71
Easy as a breeze
Post by bokr71 » Sun Apr 11, 2021 1:40 am
Here you see what I have selected in the Plex server setup:
Anything I should set differently?
holger_kuehn
Easy as a breeze
Post by holger_kuehn » Sun Apr 11, 2021 4:48 am
I've selected the second option (partial scans) as well, otherwise it's the same here.
mr_r1cardo
First post
Post by mr_r1cardo » Wed May 12, 2021 3:03 am
I can't add anything other than it's the same here (TS251+ running latest version of Plex) and has been for a while now. I've tried all the obvious combinations but it still wont update automagically.
Return to “Plex Media Server”
