HOWTO: QNAP Direct to USB Copy for newbs
buggy82
Getting the hang of things
Re: HOWTO: QNAP Direct to USB Copy for newbs
Post by buggy82 » Sun Jul 02, 2017 7:17 pm
Imho, this thread should be archived and/or unpinned from the Misc forums for these reasons:
  • Discussion of available options is completely outdated.
  • It merely explains how to copy files in any linux OS, which is trivial. Just read the first pages of any "Linux-for-Dummies" guide online.
  • Today, QNAP and partners provide many very comfortable ways to do that within QTS web UI. (Web File Manager, QNAP/3rd party Apps)
buggy82
TS 409 Pro - decommissioned
TS 559 Pro+ - degraded to an iSCSI target, disabled all services
TS 651 + UX 800P 3xRAID5 (as Storage Pool 1), actually RAID50 + 1 Single Drive (test VMs/temp data, QTS apps)
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Sun Jul 02, 2017 7:34 pm
newbie guide for using the external storage backup
https://www.qnap.com/en/how-to/tutorial ... backup-job
probably want to install hybrid backup sync which replaces default backup station though first.
for one touch button refer here
https://www.qnap.com/en/how-to/faq/arti ... hould-i-do
NAS
[Main Server] QNAP TS-877 w. 4tb [ 3x HGST Deskstar NAS (HDN724040ALE640) & 1x WD RED NAS ] EXT4 Raid5 & 2 x m.2 SATA Samsung 850 Evo raid1 +16gb ddr4 Crucial+ QWA-AC2600 wireless+QXP PCIE
[Backup] QNAP TS-653A w. 5x 2TB Samsung F3 (HD203WI) EXT4 Raid5
[Backup] QNAP TL-D400S 2x 4TB WD Red Nas (WD40EFRX) single disks.
[^] QNAP TS-659 Pro II
[^] QNAP TS-228
[^] QNAP TS-128
Network
Asus AC68U Router|100dl/50ul MBPS FTTH Internet | Win10, WC PC-Intel i7 920 Ivy bridge desktop (1x 512gb Samsung 850 Pro SSD + 1x 4tb HGST Ultrastar 7K4000)
Guides & articles
buggy82
Post by buggy82 » Tue Jul 04, 2017 5:52 pm
BenlyHar
Post by BenlyHar » Sun Jul 09, 2017 7:30 pm
If you guys can help me on this thread. Please do viewtopic.php?f=185&t=1182&p=625283#p625283
P3R
Post by P3R » Mon Jul 10, 2017 4:12 am
Moogle Stiltzkin wrote:probably want to install hybrid backup sync which replaces default backup station though first.
Still very bad as general advice as software still in beta testing like Hybrid Backup Sync shouldn't be used on live data unless confirmed stable for the actual specific use case in a pure test environment with dummy data first.
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Mon Jul 10, 2017 8:45 am
only reason i recommended because i tested myself as working for my rtrr settings as i detailed (but even then i would not normally recommend beta either... however), other users are being told by qnap support to use it over backup station. Thats why i recommend it since thats what qnap support is telling others :S
well aliaos backup setting didn't work on either solution. i didn't really keep track of his case, but for the qts firmware, hbs version, qnap model, my rtrr settings i tested myself working. I did some checking in diagnose report and the files but did not see any destructive issues when doing the backup. thats why i link to my own hbs test cause thats the only scenario which i verified as working for me :)
alios wrote:is there another backup app that can be installed on a QNAP 459 Pro II 4.2.6 firmware ???
i had the standard Backup Station app, wich worked PERFECTLY for 7 years, until last year, when it stopped making backups from a windows SMB share...
so i installed Hybrid Backup Beta after beeing suggested by qnap support in my submitted ticket
this app has lots of bugs but still, i`m doing my backup jobs...
now i want to set up another SMB/CIFS sync from a windows server share... on the connection tab it says FAILURE every time, the job doesn`t work, and i`m beeing frustrated AF
so please somebody, is there another app for QNAP drives that does RSYNC, FTP and SMB backups ?
i`m getting really desperate with qnap devices... and i was planning to change the unit this year, maybe go with something rack mountable, but if the software keeps on beeing buggy.... i aren`t think that... i want something that i don`t have to babysit every day
vampyren wrote:@Moogle Stiltzkin:
Sorry for late answer but you found it anyway :). The QNAP support told me
Hybrid backup Sync will replace the old Backup station and recommended using it.
It works fine
for now.
I have also updated to 4.3.3.0229 which seems stable.
Maybe just luck, i dont know. Either way i would stay away from old Backupstation.
well i'll make a ticket then to qnap to get an official answer whether hbs is more stable than backup station for future use. :S for now i'll edit that out from faq till then. so then if anything don't work on backup station, they'll probably still get referred to HBS by support despite the beta status :shock:
*there updated :)
NAS
[^] QNAP TS-228
[^] QNAP TS-128
Network
Guides & articles
P3R
Post by P3R » Tue Jul 11, 2017 6:54 am
Moogle Stiltzkin wrote:only reason i recommended because i tested myself as working for my rtrr settings as i detailed (but even then i would not normally recommend beta either... however), other users are being told by qnap support to use it over backup station. Thats why i recommend it since thats what qnap support is telling others
Backup Station and even more so Hybrid Backup Sync can be used in many, many very different ways that may each be affected by specific issues with certain usage. In fact both Backup Station and Hybrid Backup Sync should be considered more of portals to many different backup apps than single purpose apps. NAS to NAS, Rsync, RTRR, External Drive and now all the cloud services are very different and will probably be affected by different bugs.
Qnap support have insight into each specific case reported to them by each customer. You don't have the information and knowledge they have. Qnap support probably have good reasons for the handful isolated recommendations they've made. To interpret those as a general recommendation to everyone to switch to Hybrid Backup Sync is just plain wrong.
That's a waste of resources that would be much better used helping customers with problems!
It's very simple, if HBS was the actual general Qnap recommendation for a majority of users becuase it have less severe bugs than Backup Station, HBS would simply have been declared released and stable software.
Qnap didn't do that at all. Instead what they did is that they had HBS go out for yet another beta period because it needs more testing to sort out the bugs. When you as a long time active community member recommend HBS to everyone it's in my opinion bad. When you're not even telling people it's still in beta testing status it's even worse.
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Tue Jul 11, 2017 7:05 am
P3R wrote:When you as a long time active community member recommend HBS to everyone it's in my opinion bad. When you're not even telling people it's still in beta testing status it's even worse.
thx for the feedback. i did take your suggestion to mind and updated faq a while ago with further clarification, in case you missed it :) chillax. and for such a simple question hardly take much time to resolve, and if anything priority is probably low anyway. won't impact you, me asking questions, helpdesk is meant for everyone to use 8)
NAS
[^] QNAP TS-228
[^] QNAP TS-128
Network
Guides & articles
Locked
Return to “Miscellaneous”
